Configuring Cross-Origin Access for Nginx Ingresses
The same-origin policy of browsers prevents a web page loaded by one origin from directly requesting resources from another origin in web development. Cross-origin resource sharing (CORS) is a secure solution that allows cross-origin requests.
CORS can be used in the following scenarios:
- Separated frontend and backend: In web development, frontend applications are often deployed under a domain name (for example, frontend.example.com), while the backend API service uses a different domain name (for example, api.example.com). This can cause cross-origin resource sharing to be blocked, but CORS can help resolve this issue by allowing the frontend to obtain data from the API service.
- Third-party service integration: If your website needs to call third-party APIs (for example, the APIs of a map service or social media login platform), configure CORS to enable cross-origin resource sharing.
- CDN: If your website is using a CDN to provide static resources from a domain name that differs from the primary domain, you can use CORS to load these resources.
Configuration Example
This section uses the communication between a frontend application (frontend.example.com) and a backend API service (api.example.com) as an example to describe how to add an annotation to the ingress for cross-origin access. For details about the annotation, see Enable CORS.
Example configuration:
kind: Ingress
namespace: default
annotations:
nginx.ingress.kubernetes.io/enable-cors: "true" # Enable CORS.
nginx.ingress.kubernetes.io/cors-allow-origin: "*" # Configure the origin that can be accessed.
nginx.ingress.kubernetes.io/cors-allow-methods: "GET, PUT, POST, DELETE, PATCH, OPTIONS" # Allowed HTTP request methods
nginx.ingress.kubernetes.io/cors-allow-headers: "DNT,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range" # Allowed request headers
nginx.ingress.kubernetes.io/cors-expose-headers: "Content-Length,Content-Range" # Response headers to be exposed
nginx.ingress.kubernetes.io/cors-max-age: "3600" # Cache duration of a pre-check request
rules:
- host: api.example.com
http:
paths:
- path: /
backend:
service:
port:
number: 80
property:
ingressClassName: nginx
Parameter |
Description |
Example |
nginx.ingress.kubernetes.io/enable-cors |
Enable CORS to allow cross-origin access. |
nginx.ingress.kubernetes.io/enable-cors: "true" |
nginx.ingress.kubernetes.io/cors-allow-origin |
Specify Access-Control-Allow-Origin for the origin that can be accessed. The parameter value is in the format of http(s)://example.com or http(s)://example.com:port. You can enter multiple values by separating them with commas (,). Wildcards are also supported. For example:
NOTICE:
To enhance security, specify a domain name to prevent unauthorized access to sensitive resources from other domains. |
nginx.ingress.kubernetes.io/cors-allow-origin: "https://example.com" |
nginx.ingress.kubernetes.io/cors-allow-methods |
Specify Access-Control-Allow-Methods for allowed HTTP request methods. You can enter multiple values by separating them with commas (,). |
nginx.ingress.kubernetes.io/cors-allow-methods: "GET, PUT, POST, DELETE, PATCH, OPTIONS" |
nginx.ingress.kubernetes.io/cors-allow-headers |
Specify Access-Control-Allow-Headers for allowed request headers. You can enter multiple values by separating them with commas (,). |
nginx.ingress.kubernetes.io/cors-allow-headers: "DNT,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range" |
nginx.ingress.kubernetes.io/cors-allow-credentials |
Specify Access-Control-Allow-Credentials to control the sending of credentials (such as cookies). Options:
NOTICE:
For security purposes, if Access-Control-Allow-Credentials is set to true, the wildcard (*) cannot be used for Access-Control-Allow-Origin. This prevents unauthorized domains from accessing sensitive resources, such as cookies or authorization headers containing user credentials. |
nginx.ingress.kubernetes.io/cors-allow-credentials: "true" |
nginx.ingress.kubernetes.io/cors-expose-headers |
Specify Access-Control-Expose-Headers for custom response headers that can be accessed by a cross-origin request. This allows you to retrieve non-standard response headers using client-side JavaScript code. For security purposes, browsers can only access standard response headers including Cache-Control, Content-Language, Content-Type, Expires, Last-Modified, and Pragma, when handling cross-origin requests, unless otherwise specified. You can enter multiple values by separating them with commas (,). |
nginx.ingress.kubernetes.io/cors-expose-headers: "Content-Length,Content-Range" |
nginx.ingress.kubernetes.io/cors-max-age |
Specify Access-Control-Max-Age for the cache duration of a CORS pre-check request. Properly configure this parameter based on service requirements. If the value is too low, pre-check requests may happen frequently. If the value is too high, the CORS policy may not take effect immediately. |
nginx.ingress.kubernetes.io/cors-max-age: "3600" |
Verifying Cross-Origin Access
Use curl to send a cross-origin request and check the response header.
curl -X OPTIONS -H 'Origin: {Origin}' {Accessed ingress URL} -i
For example, if the origin is frontend.example.com and the accessed ingress URL is api.example.com, run the following command:
curl -X OPTIONS -H 'Origin: frontend.example.com' api.example.com -i
The Access-Control-** request header will be added to the original backend response.
HTTP/1.1 200 OK Access-Control-Allow-Origin: * Access-Control-Allow-Methods: GET, PUT, POST, DELETE, PATCH, OPTIONS Access-Control-Allow-Headers: DNT,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range Access-Control-Expose-Headers: Content-Length,Content-Range Access-Control-Allow-Credentials: true Content-Type: application/json
Helpful Link
This section describes the common CORS configuration of Nginx ingresses. For more information, see Enable CORS.
