Help Center/ Cloud Container Engine/ User Guide/ Networking/ Container Networks/ Pod Network Settings/ Configuring Network Policies to Restrict Pod Access
Updated on 2026-08-26 GMT+08:00
Network policies are designed by Kubernetes to restrict pod access. Like a firewall at the application layer, network policies enhance network security. The capabilities supported by network policies depend on the capabilities of the network add-ons of the cluster.
By default, if a namespace does not have any policy, pods in the namespace accept traffic from any source and send traffic to any destination.
The following selectors are available for network policies:
  • namespaceSelector: selects particular namespaces for which all pods should be allowed as ingress sources or egress destinations.
  • podSelector: selects particular pods in the same namespace as the network policy which should be allowed as ingress sources or egress destinations.
  • ipBlock: selects particular CIDR blocks to allow as ingress sources or egress destinations.
    In addition to service ports and CIDR blocks, you must account for ports and CIDR blocks required by critical cluster components such as CoreDNS and NodeLocal DNSCache. Omitting these may affect service stability.
Relationships Between Network Policies and Cluster Types
Cluster Type
CCE Standard Cluster
CCE Turbo Cluster
Network Model
Tunnel Network
VPC Network
Cloud Native Network 2.0
Network policies
Enabled by default
Disabled by default (To use network policies, enable DataPlane V2 when creating a cluster.)
Data plane implementation
OpenvSwitch
eBPF
eBPF
Cluster versions for ingress rules
All versions
v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, or later
Clusters v1.34.3-r10 or later
Cluster versions for egress rules
v1.23 and later
Selector for ingress rules
namespaceSelector
podSelector
namespaceSelector
podSelector
ipBlock
namespaceSelector
podSelector
ipBlock
Selector for egress rules
namespaceSelector
podSelector
ipBlock
Maximum number of NetworkPolicy objects that can be applied to a pod
15
Not limited. It is recommended to keep the number below 100.
Supported OS
EulerOS
CentOS
Huawei Cloud EulerOS 2.0
Huawei Cloud EulerOS 2.0 is supported.
Clusters v1.28.15-r70, v1.29.15-r30, v1.30.14-r30, v1.31.10-r30, v1.32.6-r30, v1.33.5-r20, v1.34.1-r0, and later versions support Ubuntu 22.04.
IPv6 network policies
Not supported
Not supported
Supported
Secure containers
Not supported
Not supported
Not supported
IPBlock scope
No limitations
Subnets within the pod CIDR block, Service CIDR block, and node IP addresses
Limiting ClusterIP access through workload labels
Not supported
Supported
Supported
Limiting the internal cloud server CIDR block of 100.125.0.0/16
Supported
Supported
Supported
SCTP
Not supported
Supported
Supported
Always allowing access to pods on a node from other nodes
Supported
Supported
Supported
Configuring EndPort in network policies
Not supported
Supported
Supported
  • If you upgrade a CCE standard cluster with a tunnel network to a version that supports egress rules in in-place mode, the rules will not work because the node OS is not upgraded. In this case, reset the node.
  • When a network policy is enabled for a cluster with a tunnel network, a pod's source IP address is embedded in the optional field of packets it sends to any Service CIDR block. This enables the configuration of network policy rules on the destination pod, taking into account the source IP address of the pod.
Using Ingress Rules
Scenario 1: Allowing Only Pods with Specified Labels to Access the Target Pod
Figure 1 podSelector
For example, a pod labeled role=db exposes port 6379 and accepts traffic only from pods labeled role=frontend. To achieve this, take the following steps:
  2. Choose Policies in the navigation pane, click the Network Policies tab, and click Create Network Policy in the upper right corner.
  3. Configure network policy parameters.
    Table 1 Parameters for creating a network policy
    Example
    Policy Name
    Customize the name for the network policy.
    access-ingress1
    Namespace
    Select the namespace where the policy applies.
    default
    Selector
    Enter a label selector for the target pod and click Add. If left empty, all pods in the namespace are selected. Click Reference Workload Label to use an existing workload's label.
    Key: role
    Value: db
    Inbound Rule
    Click to add an inbound rule.
    Table 2
    Outbound Rule
    Click to add an outbound rule.
    N/A
    Table 2 Parameters for adding an inbound rule
    Example
    Protocol & Port
    Select the protocol type and port. TCP and UDP are supported.
    Protocol: TCP
    Port: 6379
    Source CIDR Block
    For clusters v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, or later versions with DataPlane V2 enabled, you can configure the source CIDR block.
    The specified source CIDR block allows traffic from a destination CIDR block (multiple exception CIDR blocks can be specified). Separate the destination and exception CIDR blocks using a vertical bar (|). If there are multiple exception CIDR blocks, separate them using commas (,). For example, 172.17.0.0/16|172.17.1.0/24,172.17.2.0/24 allows traffic from 172.17.0.0/16 except 172.17.1.0/24 and 172.17.2.0/24.
    N/A
    Source Namespace
    Select a namespace whose objects can be accessed. It defaults to the policy's namespace if unspecified.
    default
    Source Pod Label
    Enter a label selector for the allowed source pods and click Add. If left empty, all pods in the source namespace are permitted.
    Key: role
    Value: frontend
  4. Click OK.
  1. Create the access-ingress1.yaml file.
    vim access-ingress1.yaml
    File content:
    kind: NetworkPolicy
      namespace: default
      podSelector:                  # This rule applies only to pods labeled role=db.
        matchLabels:
          role: db
      ingress:                      # This is an ingress rule.
        - podSelector:              # Allow access only from pods labeled role=frontend.
            matchLabels:
              role: frontend
        ports:                      # Only TCP can be used to access port 6379.
        - protocol: TCP
          port: 6379
  2. Run the following command to create the network policy defined in the access-ingress1.yaml file:
    kubectl apply -f access-ingress1.yaml
    Expected output:
    networkpolicy.networking.k8s.io/access-ingress1 created
Scenario 2: Allowing Only Pods in a Specific Namespace to Access the Target Pod
Figure 2 namespaceSelector
The pod labeled role=db only permits access to its port 6379 from pods in the namespace labeled project=myproject. To achieve this, take the following steps:
    Table 3 Parameters for creating a network policy
    Example
    Policy Name
    access-ingress2
    Namespace
    default
    Selector
    Key: role
    Value: db
    Inbound Rule
    Table 4
    Outbound Rule
    N/A
    Table 4 Parameters for adding an inbound rule
    Example
    Protocol & Port
    Protocol: TCP
    Port: 6379
    Source CIDR Block
    N/A
    Source Namespace
    myproject
    Source Pod Label
    N/A
  4. Click OK.
  1. Create the access-ingress2.yaml file.
    vim access-ingress2.yaml
    File content:
    kind: NetworkPolicy
        matchLabels:
          role: db
        - namespaceSelector:        # Allow access only from pods in namespaces labeled project=myproject.
            matchLabels:
              project: myproject
        - protocol: TCP
          port: 6379
  2. Run the following command to create the network policy defined in the access-ingress2.yaml file:
    kubectl apply -f access-ingress2.yaml
    Expected output:
    networkpolicy.networking.k8s.io/access-ingress2 created
Scenario 3: Allowing Only Pods with Specific Labels in a Specific Namespace to Access the Target Pod
Figure 3 Using both podSelector and namespaceSelector
The pod labeled role=db only allows access to its port 6379 from pods with label role=frontend in the namespace labeled project=myproject. To achieve this, take the following steps:
    Table 5 Parameters for creating a network policy
    Example
    Policy Name
    access-ingress3
    Namespace
    default
    Selector
    Key: role
    Value: db
    Inbound Rule
    Table 6
    Outbound Rule
    N/A
    Table 6 Parameters for adding an inbound rule
    Example
    Protocol & Port
    Protocol: TCP
    Port: 6379
    Source CIDR Block
    N/A
    Source Namespace
    myproject
    Source Pod Label
    Key: role
    Value: frontend
  4. Click OK.
  1. Create the access-ingress3.yaml file.
    vim access-ingress3.yaml
    File content:
    kind: NetworkPolicy
        matchLabels:
          role: db
            matchLabels:
              project: myproject
            matchLabels:
              role: frontend
        - protocol: TCP
          port: 6379
  2. Run the following command to create the network policy defined in the access-ingress3.yaml file:
    kubectl apply -f access-ingress3.yaml
    Expected output:
    networkpolicy.networking.k8s.io/access-ingress3 created
Using Egress Rules
Scenario 1: Restricting Pods to Access Only Specified Addresses
Figure 4 ipBlock
The pods labeled role=db only allow access to 172.16.0.0/16, excluding 172.16.0.40/32. To achieve this, take the following steps:
    Table 7 Parameters for creating a network policy
    Example
    Policy Name
    access-ingress3
    Namespace
    default
    Selector
    Key: role
    Value: db
    Inbound Rule
    N/A
    Outbound Rule
    Table 8
    Table 8 Parameters for adding an outbound rule
    Example
    Protocol & Port
    Select the protocol type and port. TCP and UDP are supported. If unspecified, all protocols and ports are permitted.
    N/A
    Destination CIDR Block
    Allow requests to be routed to a specified CIDR block (and not to the exception CIDR blocks). Separate the destination and exception CIDR blocks using a vertical bar (|). If there are multiple exception CIDR blocks, separate them using commas (,). For example, 172.17.0.0/16|172.17.1.0/24,172.17.2.0/24 allows 172.17.0.0/16 except 172.17.1.0/24 and 172.17.2.0/24.
    172.16.0.0/16|172.16.0.40/32
    Destination Namespace
    N/A
    Destination Pod Label
    Label selector for the target pod permitted by this rule. If left empty, all pods in the destination namespace are allowed.
    N/A
  4. Click OK.
  1. Create the access-egress1.yaml file.
    vim access-egress1.yaml
    File content:
    kind: NetworkPolicy
      namespace: default
      policyTypes:                  # Must be specified for egress rules.
        - Egress
        matchLabels:
          role: db
      egress:                       # This is an egress rule.
      - to:
        - ipBlock:
            cidr: 172.16.0.0/16    # Allows outbound traffic to this CIDR block.
            except:
            - 172.16.0.40/32        # Blocks access to this CIDR block, which is in the range specified by the cidr parameter.
  2. Run the following command to create the network policy defined in the access-egress1.yaml file:
    kubectl apply -f access-egress1.yaml
    Expected output:
    networkpolicy.networking.k8s.io/access-egress1 created
Scenario 2: Restricting a Pod to Be Accessed Only by Pods with Specified Labels
Figure 5 Using both ingress and egress
The pod labeled role=db only permits access to its port 6379 from pods labeled role=frontend, and this pod can only access the pods labeled role=web. You can use the same rule to configure both ingress and egress in a network policy. To achieve this, take the following steps:
    Table 9 Parameters for creating a network policy
    Example
    Policy Name
    access-ingress3
    Namespace
    default
    Selector
    Key: role
    Value: db
    Inbound Rule
    Table 10
    Outbound Rule
    Table 11
    Table 10 Parameters for adding an inbound rule
    Example
    Protocol & Port
    Protocol: TCP
    Port: 6379
    Source CIDR Block
    N/A
    Source Namespace
    default
    Source Pod Label
    Key: role
    Value: frontend
    Table 11 Parameters for adding an outbound rule
    Example
    Protocol & Port
    N/A
    N/A
    default
    Key: role
    Value: web
  4. Click OK.
  1. Create the access-egress2.yaml file.
    vim access-egress2.yaml
    File content:
    kind: NetworkPolicy
      namespace: default
      policyTypes:
      - Ingress
      - Egress
        matchLabels:
          role: db
            matchLabels:
              role: frontend
        - protocol: TCP
          port: 6379
      - to:
        - podSelector:              # The rule takes effect for pods with the role=web label.
            matchLabels:
              role: web
  2. Run the following command to create the network policy defined in the access-egress2.yaml file:
    kubectl apply -f access-egress2.yaml
    Expected output:
    networkpolicy.networking.k8s.io/access-egress2 created
