High-Risk Operations
During service deployment or running, you may trigger high-risk operations at different levels, causing service faults or interruption. To help you better estimate and avoid operation risks, this section introduces the consequences and solutions of high-risk operations from multiple dimensions, such as clusters, nodes, networking, load balancing, logs, and EVS disks.
Clusters and Nodes
| Category | Operation | Impact | Solution |
| Cluster | Using kube-apiserver to retrieve large volumes of data at a time. For example, a large number of LIST requests are initiated at a time, or a single LIST request is used to retrieve a large amount of data. | The master node's memory is overloaded, affecting system stability. | Stop executing a large number of queries. To prevent a cluster from being overloaded, increase the cluster size. For details, see Resizing a Cluster. |
| Master node | Modifying the security group of master nodes in a cluster NOTE: Naming rule for a master node's security group: cluster-name-cce-control-random-ID | The master nodes may become unavailable. | Restore the security group by referring to "Creating a Cluster" and allow traffic from and to the master nodes. For details, see How Do I Modify Cluster Security Group Rules? |
| Allowing a master node to expire or destroying a master node | The master node will become unavailable. | This operation cannot be undone. | |
| Reinstalling the OS | The master node components will be deleted. | This operation cannot be undone. | |
| Upgrading master node components or the etcd version | The cluster may become unavailable. | Roll back to the original version. | |
| Deleting or formatting core directories (such as /etc/kubernetes) on a node | The master node will become unavailable. | This operation cannot be undone. | |
| Changing the IP address of a master node | The master node will become unavailable. | Change the IP address back to the original one. | |
| Modifying parameters of core components (such as etcd, kube-apiserver, or Docker) | The master node may become unavailable. | Restore the parameters to their recommended values. For details, see Modifying Cluster Configurations. | |
| Replacing a master node or etcd certificate | The cluster may become unavailable. | This operation cannot be undone. | |
| Worker node | Modifying the security group of worker nodes in a cluster NOTE: Naming rule of a worker node's security group: cluster-name-cce-node-random-ID | The node may become unavailable. | Restore the security group by referring to "Creating a Cluster" and allow traffic from and to the worker nodes. For details, see How Do I Modify Cluster Security Group Rules? |
| Modifying the DNS configuration (/etc/resolv.conf) of a node | Internal domain names cannot be accessed. Basic functions such as add-on management and node reset upgrades may fail. NOTE: If your service needs to use an on-premises DNS server, configure the DNS in the workload. Do not change the node's DNS address. For details, see DNS Configuration. | Restore the DNS configuration to match that of a new node. | |
| Deleting a node | The node will become unavailable. | This operation cannot be undone. | |
| Deleting the elastic network interface used by a node | The pod network on that node becomes unavailable. | This operation cannot be undone. | |
| Reinstalling the OS | Node components are deleted, and the node becomes unavailable. | Reset the node. For details, see Resetting a Node. | |
| Upgrading the kernel or platform-dependent components (such as Open vSwitch, IPvlan, docker, or containerd) | The node may become unavailable, or the network may behave abnormally. NOTE: Node operation depends on the system kernel version. Do not use yum update to update or reinstall a node's kernel unless necessary. (Reinstalling the OS kernel, whether from the original image or another image, is a high-risk operation.) | Reset the node. For details, see Resetting a Node. | |
| Changing the IP address of a node | The node will become unavailable. | Change the IP address back to the original one. | |
| Modifying parameters of core components (such as kubelet and kube-proxy) | The node may become unavailable. If security-related configurations are modified, components may become insecure. Even if neither issue occurs immediately, the modified parameters may still be reset during subsequent cluster upgrades. For details, see Precautions. | If a node becomes unavailable, restore it to the recommended parameter settings. For details, see Configuring a Node Pool. Make configuration changes on the CCE console so that they are automatically preserved during cluster upgrades. | |
| Modifying OS configurations | The node may become unavailable. | Restore the configuration items or reset the node. For details, see Resetting a Node. | |
| Deleting or modifying the /opt/cloud/cce and /var/paas directories, or deleting a data disk | The node will become unavailable. | Reset the node. For details, see Resetting a Node. | |
| Modifying node directory permissions and container directory permissions Affected directories: /usr/lib/systemd/system/kubelet.service /usr/lib/systemd/system/containerd-monit.service /usr/lib/systemd/system/docker-monit.service /opt/cloud/cce /var/paas /var/paas/script /var/paas/sys/log /var/paas/kubernetes /var/script/docker /var/script/kubelet /etc/containerd /etc/rc.local /etc/sudoers.d/sudoerspaas /etc/sysconfig/docker /etc/docker/daemon.json /var/lib/docker /mnt/paas/kubernetes /mnt/paas/runtime | Permissions will become abnormal. | Do not modify these permissions. If modified, restore them. | |
| Formatting or partitioning disks on a node, including the system disk and data disks used by the container runtime and kubelet | The node may become unavailable. | Reset the node. For details, see Resetting a Node. | |
| Installing other software on a node | This may cause exceptions in Kubernetes components installed on the node, and the node may become unavailable. | Uninstall the software and restore or reset the node. For details, see Resetting a Node. | |
| Modifying NetworkManager configurations | The node will become unavailable. | Reset the node. For details, see Resetting a Node. | |
| Deleting system images such as cce-pause from a node | Containers cannot be created, and system images cannot be pulled. | Copy the image from a healthy node. | |
| Changing a node's flavor in a node pool on the ECS console | If a node's flavor differs from that specified in its node pool, the number of nodes added during a node pool scale-out will differ from the expected count. | Change the node flavor to match the node pool specification, or delete the node and scale out the node pool again. | |
| Deleting or moving binaries and configuration files required for running containerd /etc/containerd/config.toml /etc/crictl.yaml /usr/bin/runc /usr/lib/systemd/system/containerd.service /usr/local/bin/containerd /usr/local/bin/containerd-shim-runc-v2 /usr/local/bin/crictl /usr/local/bin/ctr | If /usr/local/bin/crictl is deleted, the containerd health check will fail and containerd will restart repeatedly. Deleting other files may cause containers to fail to start and nodes to become unavailable. | Reset the node to restore containerd binaries and configuration files. For details, see Resetting a Node. | |
| Modifying or manually creating the paas user or user group | CCE components and service pods will be affected. For details, see paas User and User Group. | Reset the node. For details, see Resetting a Node. |
Network
| Changing the value of the kernel parameter net.ipv4.ip_forward to 0 | The network becomes inaccessible. | Change the value to 1. |
| Changing the value of the kernel parameter net.ipv4.tcp_tw_recycle to 1 | The NAT service becomes abnormal. | Change the value to 0. |
| Changing the value of the kernel parameter net.ipv4.tcp_tw_reuse to 1 | The network becomes abnormal. | Change the value to 0. |
| Not configuring the node security group to allow UDP traffic to port 53 of the pod CIDR blocks | The DNS in the cluster cannot work properly. | Restore the security group by referring to Creating a Cluster and allow traffic from and to the cluster nodes. For details, see How Do I Modify Cluster Security Group Rules? |
| Deleting network-attachment-definitions CRD resources of default-network | The container network is disconnected, or the cluster fails to be deleted. | If the resources are deleted by mistake, use the correct configurations to create the default-network resources. |
| Enabling the iptables firewall | By default, the iptables firewall is disabled on CCE. Enabling the firewall can leave the network inaccessible. NOTE: Do not enable the iptables firewall. If the iptables firewall must be enabled, check whether the rules configured in /etc/sysconfig/iptables and /etc/sysconfig/ip6tables in the test environment will affect the network. | Disable the iptables firewall and check the rules configured in /etc/sysconfig/iptables and /etc/sysconfig/ip6tables. |
| Upgrading the kernel or Open vSwitch on the nodes in a cluster that uses the tunnel network | The container network is disconnected. NOTE: The data plane of the cluster uses the Open vSwitch component optimized by Huawei and cannot be upgraded to Open vSwitch provided by the OS. |
| Configuring privileged containers for a workload and directly operating the host hardware. There may be misoperations on the system files of the node. For example, if you set the startup command to /usr/sbin/init and run systemctl in containers, the system files in the /lib directory of the node may be damaged. | All mount points of the node will be unmounted. As a result, the node malfunctions, resulting in failed pods and affected storage add-on functions. | Do not remove the mount points in the /lib directory of a node. Reset the node for recovery. For details, see Resetting a Node. |
| Mounting the system component directory using hostPath, for example, mounting files in /var/lib/docker | After the system component is restarted, the system component directory on the node may be rebuilt, which interrupts the inode link of the mounted directory. As a result, the content in the mounted directory cannot be used in the container. | Do not mount the system component directory. |
Load Balancing
| Deleting a load balancer that has been associated with a CCE cluster | Accessing the target Service or ingress will fail. | Do not delete such load balancer. |
| Disabling a load balancer that has been associated with a CCE cluster | Accessing the target Service or ingress will fail. | Do not disable such a load balancer. If a load balancer has been disabled, enable it. |
| Changing the private IPv4 address of a load balancer |
| Do not change private IPv4 addresses of load balancers. Change them back if they have been changed. |
| Unbinding the IPv4 EIP from a load balancer | After the EIP is unbound from the load balancer, the load balancer will not be able to forward Internet traffic. | Restore the EIP binding. |
| Adding a listener to a load balancer that has been associated with a CCE cluster | If a load balancer is automatically created when a Service or an ingress is created, any listener added to the load balancer on the ELB console cannot be deleted when the Service or ingress is deleted. In this case, the load balancer cannot be automatically deleted. | Use the listener automatically created when a Service or an ingress is created. If a listener added on the ELB console is used, manually delete this load balancer. |
| Deleting a listener automatically added by CCE |
| Re-create or update the Service or ingress. |
| Modifying the basic configurations such as the name, access control, timeout, or description of a listener added by CCE | When master nodes are restarted due to reasons such as a cluster upgrade, all your modifications will be reset by CCE. | Do not modify the basic configurations of the listener created by CCE. Restore the configurations if they have been modified. |
| Modifying the backend server group of a listener added by CCE, including adding or deleting backend servers to or from the server group |
| Replacing the backend server group of a listener added by CCE |
| Modifying the forwarding policy of a listener added by CCE, including adding or deleting forwarding rules |
| Do not modify the forwarding policy of such a listener. Restore the configurations if they have been modified. |
| Replacing the certificate of the listener created by CCE on the ELB console or modifying the server certificate created by CCE using a TLS key on the Certificates page of ELB | In scenarios where a master node needs to be restarted, such as during a cluster upgrade, the modification will be reset by CCE. As a result, the Service or ingress may become inaccessible. | Use the CCE console or YAML to update the certificate associated with the Service or ingress, or update the TLS key associated with the Service or ingress. |
Logs
| Deleting the /tmp/ccs-log-collector/pos directory on the host machine | Logs are collected repeatedly. | None |
| Deleting the /tmp/ccs-log-collector/buffer directory on the host machine | Logs are lost. | None |
Monitoring
| Configuring a larger number of collection shards in Cloud Native Cluster Monitoring than the recommended value (one collection shard per 50 nodes) | Excessive shards may overload the master node's memory, affecting system stability. | Change the number of collection shards to the recommended value for Cloud Native Cluster Monitoring. |
EVS Disks
| Operation | Impact | Solution | Remarks |
| Manually unmounting an EVS disk on the console | An I/O error occurs when data is written into a pod. | Delete the mount path from the node and schedule the pod again. | The file in the pod records the location where files are to be collected. |
| Unmounting the disk mount point on the node | Pod data is written into a local disk. | Remount the corresponding path to the pod. | The buffer contains log cache files to be consumed. |
| Operating EVS disks on the node | Pod data is written into a local disk. | None | None |
| Creating a PV with parameters that are not declared in the file For example, if the YAML file contains parameters such as status, spec.claimRef, and annotation.everest.io/set-disk-metadata during PV creation, the PV may be abnormal. | This operation may bypass some standard processes for creating PVs. As a result, the created PVs may become unavailable or be deleted unexpectedly. | Before such PVs are deleted, manually delete related parameters in their YAML files. | None |
Add-ons
| Modifying add-on resources in the backend | Add-on exceptions or other unexpected issues may occur. For example, parameter settings are overwritten after an upgrade. | Perform operations on the add-on configuration page or using open add-on management APIs. |
