Updated on 2026-09-21 GMT+08:00
DNS Configuration
Every Kubernetes cluster has a built-in DNS add-on (Kube-DNS or CoreDNS) to provide domain name resolution for workloads in the cluster. When handling a high concurrency of DNS queries, Kube-DNS/CoreDNS may encounter a performance bottleneck, that is, it may fail occasionally to fulfill DNS queries. Kubernetes workloads occasionally generate unnecessary DNS queries, which can overload the DNS system during periods of high query concurrency. Tuning DNS configuration for workloads will reduce the risks of DNS query failures to some extent.
For more information about DNS, see CoreDNS.
DNS Configuration Items
Run the cat /etc/resolv.conf command on a Linux node or container to view the DNS resolver configuration file. The following is an example DNS resolver configuration of a container in a Kubernetes cluster:
nameserver 10.247.x.x
search default.svc.cluster.local svc.cluster.local cluster.local
options single-request-reopen timeout:2 ndots:5
Configuration Options
  • nameserver: an IP address list of a name server that the resolver will query. If the IP address falls within the cluster's service CIDR (for example, 10.247.x.x in the preceding example), it is the CoreDNS ClusterIP, and Kube-DNS/CoreDNS resolution is used. Otherwise, an external DNS (cloud-managed or self-hosted) is used.
  • search: a search list for host-name lookup. When a domain name cannot be resolved, DNS queries will be attempted combining the domain name with each domain in the search list in turn until a match is found or all domains in the search list are tried. For CCE clusters, the search list is currently limited to three domains per container. When a nonexistent domain name is being resolved, eight DNS queries will be initiated because each domain name (including those in the search list) will be queried twice, once for IPv4 and once for IPv6.
  • options: Additional settings in a DNS configuration file. Common options include timeout and ndots.
    The value ndots:5 means that if a domain name has fewer than 5 periods (.), DNS queries will be attempted by combining the domain name with each domain in the search list in turn. If no match is found after all the domains in the search list are tried, the domain name is then used for DNS queries. If the domain name has 5 or more periods, it will be tried first for DNS queries. In case that the domain name cannot be resolved, DNS queries will be attempted by combining the domain name with each domain in the search list in turn.
    For example, the domain name www.***.com contains only two periods (fewer than the ndots value). Therefore, the DNS resolution sequence is: as follows: www.***.com.default.svc.cluster.local, www.***.com.svc.cluster.local, www.***.com.cluster.local, and www.***.com. This means at least seven DNS queries are initiated before the domain resolves to an IP address. This configuration results in a large number of redundant DNS queries when accessing external domain names, indicating clear opportunities for optimization.
For details about the configuration items in the Linux DNS resolver configuration file, see https://man7.org/linux/man-pages/man5/resolv.conf.5.html.
Configuring DNS for a Workload Through the Console
Kubernetes provides DNS-related configuration options for applications. The use of application's DNS configuration can effectively reduce unnecessary DNS queries in certain scenarios and improve service concurrency. The following procedure uses an Nginx application as an example to describe how to add DNS configurations for a workload on the console.
  2. In the navigation pane, choose Workloads. In the upper right corner, click Create Workload.
  3. Configure basic information about the workload. For details, see Creating a Workload.
  4. In the Advanced Settings area, click the DNS tab and set the following parameters as required:
    • DNS Policy: The DNS policies provided on the console correspond to the dnsPolicy field in the YAML file. For details, see Table 1.
      • Supplement defaults: corresponds to dnsPolicy=ClusterFirst. Containers can resolve both the cluster-internal domain names registered by a Service and the external domain names exposed to public networks.
      • Replace defaults: corresponds to dnsPolicy=None. You must configure IP Address and Search Domain. Containers only use the user-defined IP address and search domain configurations for domain name resolution.
      • Inherit defaults: corresponds to dnsPolicy=Default. Containers use the domain name resolution configuration from the node that pods run on and cannot resolve the cluster-internal domain names.
    • Optional Objects: The options parameters in the dnsConfig field. Each object may have a name property (required) and a value property (optional). After setting the properties, click confirm to add.
      • timeout: Timeout interval, in seconds.
      • ndots: Number of periods (.) that must be present in a domain name. If a domain name has fewer periods than this value, the operating system will look up the name in the search domain. If not, the name is a fully qualified domain name (FQDN) and will be tried first as an absolute name.
    • IP Address of DNS Server: nameservers in dnsConfig. You can configure a domain name server for a custom domain name. The value is one or a group of DNS IP addresses. A maximum of two DNS IP addresses can be added.
    • Search Domain: searches in the dnsConfig. A list of DNS search domains for hostname lookup in the pod. This property is optional. When specified, the provided list will be merged into the search domain names generated from the chosen DNS policy in dnsPolicy. Duplicate domain names are removed. A maximum of three search domains can be added.
    • Host Alias: Add the mapping between domain names and IP addresses to the local configuration file /etc/hosts of a pod for simplified local domain name resolution. For details, see Adding entries to Pod /etc/hosts with HostAliases
    Figure 1 DNS configuration of a workload
  5. Click Create Workload.
Configuring DNS Using the Workload YAML
When creating a workload using a YAML file, you can configure the DNS settings in the YAML. The following is an example for an Nginx application:
apiVersion: apps/v1
kind: Deployment
  namespace: default
  replicas: 1
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      containers:
        - name: container-1
          image: nginx:latest
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
        - name: default-secret
      dnsPolicy: None
      dnsConfig:
        options:
          - name: ndots
            value: '5'
          - name: timeout
            value: '3'
        nameservers:
          - 10.2.3.4
        searches:
          - my.dns.search.suffix
  • dnsPolicy
    The dnsPolicy field is used to configure a DNS policy for an application. The default value is ClusterFirst. The following table lists dnsPolicy configurations.
    Table 1 dnsPolicy
    ClusterFirst (default value)
    Custom DNS configuration added to the default DNS configuration. By default, the application connects to CoreDNS (CoreDNS of the CCE cluster connects to the DNS on the cloud by default). The custom dnsConfig will be added to the default DNS parameters. Containers can resolve both the cluster-internal domain names registered by a Service and the external domain names exposed to public networks. The search list (search option) and ndots: 5 are present in the DNS configuration file. Therefore, when accessing an external domain name and a long cluster-internal domain name (for example, kubernetes.default.svc.cluster.local), the search list will usually be traversed first, resulting in at least six invalid DNS queries. The issue of invalid DNS queries disappears only when a short cluster-internal domain name (for example, kubernetes) is being accessed.
    ClusterFirstWithHostNet
    By default, the applications configured with the host network are interconnected with the DNS configuration of the node where the pod is located. The DNS configuration is specified in the DNS file that the kubelet --resolv-conf parameter points to. In this case, the CCE cluster uses the DNS on the cloud. To interconnect with Kubernetes DNS or CoreDNS of the cluster, set dnsPolicy to ClusterFirstWithHostNet. In this case, the configuration of the domain name resolution file of the container is the same as that of ClusterFirst, and there are invalid DNS queries.
      containers:
      - image: nginx:latest
      restartPolicy: Always
      hostNetwork: true
      dnsPolicy: ClusterFirstWithHostNet
    Default
    The DNS configuration of the node where the pod is located is inherited, and the custom DNS configuration is added to the inherited configuration. Container's DNS configuration file is the DNS configuration file that the kubelet's --resolv-conf flag points to. In this case, a cloud DNS is used for CCE clusters. Both search and options fields are left unspecified. This configuration can resolve only external domain names registered on the internet, not cluster-internal domain names. It is not affected by invalid DNS queries.
    None
    The default DNS configuration is replaced by the custom DNS configuration, and only the custom DNS configuration is used. If dnsPolicy is set to None, the dnsConfig field must be specified because all DNS settings are supposed to be provided using the dnsConfig field.
    If the dnsPolicy field is not specified, the default value is ClusterFirst instead of Default.
  • dnsConfig
    The dnsConfig field is used to configure DNS parameters for workloads. The configured parameters are merged to the DNS configuration file generated according to dnsPolicy. If dnsPolicy is set to None, the workload's DNS configuration file is specified by the dnsConfig field. If dnsPolicy is not set to None, the DNS parameters configured in dnsConfig are added to the DNS configuration file generated according to dnsPolicy.
    Table 2 dnsConfig
    options
    An optional list of objects where each object may have a name property (required) and a value property (optional). The contents in this property will be merged with the options generated from the specified DNS policy in dnsPolicy. Duplicate entries are removed.
    nameservers
    A list of IP addresses that will be used as DNS servers. If a workload's dnsPolicy is set to None, this list must contain at least one IP address. In other cases, this parameter is optional. The servers listed will be combined with the nameservers generated from the specified DNS policy in dnsPolicy with duplicate addresses removed.
    A maximum of three DNS addresses can be configured for a nameserver in the container DNS configuration file.
    • If dnsPolicy is set to ClusterFirst and the cluster uses CoreDNS, you can add two custom DNS addresses in addition to the CoreDNS address. Excess DNS addresses are invalid.
    • If dnsPolicy is set to ClusterFirst and the cluster uses CoreDNS and NodeLocal DNSCache, you can add one custom DNS address in addition to the CoreDNS and NodeLocal DNSCache addresses. Excess DNS addresses are invalid.
    searches
Configuration Examples
The following example describes how to configure DNS for workloads.
  • Use Case 1: Using Kube-DNS/CoreDNS Built in Kubernetes Clusters
    Kubernetes in-cluster Kube-DNS/CoreDNS can resolve only cluster-internal domain names, or both cluster-internal domain names and external domain names. This is the default DNS for workloads.
    Example:
    apiVersion: v1
    kind: Pod
      namespace: default
      containers:
      - name: test
        image: nginx:alpine
      imagePullSecrets:
    Container's DNS configuration file:
    nameserver 10.247.3.10
    options timeout:2 single-request-reopen ndots:5
  • Use Case 2: Using a Cloud DNS
    This DNS type cannot resolve cluster-internal domain names. Use it for workloads that access only external domain names registered on the internet.
    Example:
    apiVersion: v1
    kind: Pod
      namespace: default
      containers:
      - name: test
        image: nginx:alpine
      dnsPolicy: Default  # The DNS configuration file that the kubelet --resolv-conf parameter points to is used. In this case, the CCE cluster uses the DNS on the cloud.
      imagePullSecrets:
    The DNS configuration file of the container is as follows: (100.125.x.x is the DNS address of the node subnet.)
    nameserver 100.125.x.x
  • Use Case 3: Using Kube-DNS/CoreDNS for Workloads Running with hostNetwork
    By default, a DNS is used for workloads running with hostNetwork. If workloads need to use Kube-DNS/CoreDNS, set dnsPolicy to ClusterFirstWithHostNet.
    Example:
    apiVersion: v1
    kind: Pod
      hostNetwork: true
      containers:
      - name: nginx
        image: nginx:alpine
        ports:
        - containerPort: 80
      imagePullSecrets:
    options ndots:5 single-request-reopen timeout:2
  • Use Case 4: Customizing Application's DNS Configuration
    You can flexibly customize the DNS configuration file for applications. Using dnsPolicy and dnsConfig together can address almost all scenarios, including the scenarios in which an on-premises DNS will be used, multiple DNSs will be cascaded, and DNS configuration options will be modified.
    Example 1: Using Your On-Premises DNS
    Set dnsPolicy to None so application's DNS configuration file is generated based on dnsConfig.
    apiVersion: v1
    kind: Pod
      namespace: default
      containers:
      - name: test
        image: nginx:alpine
      dnsPolicy: "None"
      dnsConfig:
        nameservers:
        - 10.2.3.4  # IP address of your on-premises DNS
        searches:
        - ns1.svc.cluster.local
        options:
        - name: ndots
          value: "2"
        - name: timeout
          value: "3"
      imagePullSecrets:
    nameserver 10.2.3.4
    search ns1.svc.cluster.local my.dns.search.suffix
    options timeout:3 ndots:2 single-request-reopen
    Example 2: Modifying the ndots Option in the DNS Configuration File to Reduce Invalid DNS Queries
    Set dnsPolicy to a value other than None so the DNS parameters configured in dnsConfig are added to the DNS configuration file generated based on dnsPolicy.
    apiVersion: v1
    kind: Pod
      namespace: default
      containers:
      - name: test
        image: nginx:alpine
      dnsPolicy: "ClusterFirst"
      dnsConfig:
        options:
        - name: ndots
          value: "2" # The ndots:5 option in the DNS configuration file generated based on the ClusterFirst policy is changed to ndots:2.
      imagePullSecrets:
    options ndots:2 single-request-reopen timeout:2
    Example 3: Using Multiple DNSs in Serial Sequence
    apiVersion: v1
    kind: Pod
      namespace: default
      containers:
      - name: test
        image: nginx:alpine
      dnsPolicy: ClusterFirst  # Added DNS configuration. The cluster connects to CoreDNS by default.
      dnsConfig:
        nameservers:
      imagePullSecrets:
    nameserver 10.2.3.4
