Help Center/ Cloud Container Engine/ User Guide/ Networking/ DNS/ Using NodeLocal DNSCache to Improve DNS Performance
Updated on 2026-09-21 GMT+08:00
Challenges
When the number of DNS requests in a cluster increases, the load of CoreDNS increases and the following issues may occur:
  • Increased delay: CoreDNS needs to process more requests, which may slow down the DNS query and affect service performance.
  • Increased resource usage: To ensure DNS performance, CoreDNS requires higher specifications.
Solution
To minimize the impact of DNS delay, deploy NodeLocal DNSCache in the cluster to improve the networking stability and performance. NodeLocal DNSCache runs a DNS cache proxy on cluster nodes. All pods with DNS configurations use the DNS cache proxy running on nodes instead of the CoreDNS service for domain name resolution. This reduces CoreDNS's load and improves the cluster DNS performance.
After NodeLocal DNSCache is enabled, a DNS query goes through the path as shown below.
Figure 1 NodeLocal DNSCache query path
The resolution rules are as follows:
  • 1. By default, the pods with DNSConfig injected use NodeLocal DNSCache to resolve requested domain names.
  • 2. If NodeLocal DNSCache cannot resolve domain names, it will ask CoreDNS for resolution.
  • 3. CoreDNS uses the DNS server in the VPC to resolve the domain names out of the cluster.
  • 4. If a pod with DNSConfig injected cannot access NodeLocal DNSCache, CoreDNS will resolve the domain name.
  • 5. By default, CoreDNS resolves domain names for the pods without DNSConfig injected.
  • Only clusters v1.19 or later support the NodeLocal DNSCache add-on.
  • CCI does not support NodeLocal DNSCache. When the workload is dynamically scaled to CCI, pods on CCI cannot access NodeLocal DNSCache. As a result, domain name resolution times out. Therefore, when creating a workload that is scaled to CCI, add the node-local-dns-injection: disabled label to the pod to prevent automatic injection of DNSConfig. For details, see FAQ.
  • The node-local-dns-injection label is the system label used by NodeLocal DNSCache. Use this label only to prevent an automatic DNSConfig injection.
Installing the Add-on
CCE provides add-on NodeLocal DNSCache that simplifies the installation of NodeLocal DNSCache.
NodeLocal DNSCache serves as a transparent caching proxy for CoreDNS and does not provide plug-ins such as hosts or rewrite. If you want to enable these plug-ins, modify the CoreDNS configurations.
  1. (Optional) Modify the CoreDNS configuration so that the CoreDNS preferentially uses UDP to communicate with the upstream DNS server.
    The NodeLocal DNSCache uses TCP to communicate with the CoreDNS. The CoreDNS communicates with the upstream DNS server based on the protocol used by the request source. However, the cloud server does not support TCP. To use NodeLocal DNSCache, modify the CoreDNS configuration so that UDP is preferentially used to communicate with the upstream DNS server, preventing resolution exceptions.
    To configure CoreDNS to prefer UDP for upstream communication in the forward add-on, you need to add the prefer_udp option in the CoreDNS configuration file. To do so, perform the following operations:
    2. In the navigation pane, choose Add-ons. Then, click Edit under CoreDNS.
    3. Edit extended parameters in Parameters and modify the following content in the plugins field:
          "configBlock": "prefer_udp",
          "name": "forward",
          "parameters": ". /etc/resolv.conf"
      Corefile:
      Corefile: |-
        .:5353 {
            bind {$POD_IP}
            cache 30 {
                servfail 5s
            errors
            health {$POD_IP}:8080
            kubernetes cluster.local in-addr.arpa ip6.arpa {
                pods insecure
                fallthrough in-addr.arpa ip6.arpa
            loadbalance round_robin
            prometheus {$POD_IP}:9153
            forward . /etc/resolv.conf {
                prefer_udp
            reload
            ready {$POD_IP}:8081
    4. Click Next. After the upgrade check is complete, click OK.
  2. Choose Add-ons in the navigation pane, find the NodeLocal DNSCache add-on on the right, and click Install.
  3. On the Install Add-on page, select the add-on specifications and set related parameters.
    • DNSConfig: After this function is enabled, a DNSConfig admission controller will be created. The controller intercepts pod creation requests in the namespace labeled with node-local-dns-injection=enabled based on admission webhooks and automatically configures DNSConfig for pods. If this function is disabled or the pods to be created are not in the target namespace, you must manually configure DNSConfig for the pods.
      After this function is enabled, you can customize the ConfigMaps below for DNSConfig (supported when the add-on version is 1.6.7 or later):
      In scenarios where DNSConfig is enabled, the DNS configuration specified within the pod overrides any injected DNSConfig settings.
      • (Optional) IP Address of DNS Server: an IP address list of the DNS server obtained when the container resolves the domain name. NodeLocal DNSCache and CoreDNS IP addresses are added by default. You have the option to add one extra IP address, but any duplicates will be removed.
      • (Optional) Search Domain: a search list for host-name lookup. When a domain name cannot be resolved, DNS queries will be attempted combining the domain name with each domain in the search list in turn until a match is found or all domains in the search list are tried. You can add up to three extra search domains, but any duplicates will be removed.
      • (Optional) ndots: specifies that if a domain name has fewer periods (.) than the specified value of ndots, it will be combined with the search domain list for DNS query. If the domain name still cannot be resolved, it will be used for DNS query. If the number of periods (.) in a domain name is greater than or equal to the value of ndots, the system will perform a DNS query on the domain name. If the domain name cannot be resolved, the system will sequentially combine it with the search domain list and then perform a DNS query.
    • Target Namespace: This parameter is available after DNSConfig is enabled. Only NodeLocal DNSCache of 1.3.0 or later supports this function.
      • Enable All: CCE adds the node-local-dns-injection=enabled label to all created namespaces excluding built-in ones and the ones preset by some add-ons (such as kube-system, kube-public, kube-node-lease, istio-system, and monitoring), identifies namespace creation requests, and automatically adds the label to newly created namespaces.
        In add-ons of 1.6.77 or later, the node-local-dns-injection=enabled label cannot be manually deleted. You can set node-local-dns-injection to disabled to disable automatic DNSConfig injection in a namespace.
      • Manually Configure: You must manually add the node-local-dns-injection=enabled label to the namespaces requiring DNSConfig injection. For details, see Managing Namespace Labels.
  4. Click Install.
By default, application requests are sent through the CoreDNS proxy. To use node-local-dns as the DNS cache proxy, use any of the following methods:
  • Auto injection: When you create a pod, CCE will automatically configure its dnsConfig field. (This function is not available for pods in system namespaces such as kube-system.)
  • Manual configuration: You need to manually configure the pod's dnsConfig field.
To enable auto injection, perform the following operations:
  1. Install NodeLocal DNSCache. During the installation, enable DNSConfig and configure Target Namespace for auto injection. For details, see Installing the Add-on.
    Target Namespace: This parameter is available after DNSConfig is enabled. Only NodeLocal DNSCache of v1.3.0 or later supports this function.
    • Enable All: CCE adds the node-local-dns-injection=enabled label to all created namespaces excluding built-in ones (such as kube-system), identifies namespace creation requests, and automatically adds the label to newly created namespaces.
    • Manually Configure: You must manually add the node-local-dns-injection=enabled label to the namespaces requiring the injection of DNSConfig. For details, see Managing Namespace Labels.
  2. Create a workload in the namespace with auto injection enabled. For details, see Creating a Deployment.
    The pods for which auto injection is enabled must meet the following requirements:
    • The new pod does not run in system namespaces such as kube-system and kube-public.
    • The node-local-dns-injection=disabled label for disabling DNS injection is not added to the new pod.
    • The new pod's DNSPolicy is ClusterFirstWithHostNet. Alternatively, the pod does not use the host network and DNSPolicy is ClusterFirst.
  3. Run the following command to check the DNS configuration of the target pod:
    kubectl get pod <pod_name> -oyaml
    After auto injection is enabled, the following dnsConfig settings are automatically added to created pods. In addition to the NodeLocal DNSCache IP address (169.254.20.10 in this example), the CoreDNS IP address (10.247.3.10 in this example) is added to nameservers, ensuring DNS server high availability.
    The NodeLocal DNSCache addresses of different cluster types are as follows:
    • CCE standard clusters: 169.254.20.10
    • CCE Turbo cluster: 169.254.1.1
      dnsConfig:
        nameservers:
          - 169.254.20.10
          - 10.247.3.10
        searches:
          - default.svc.cluster.local
          - svc.cluster.local
          - cluster.local
        options:
          - name: timeout
            value: ''
          - name: ndots
            value: '5'
          - name: single-request-reopen
Manually add the dnsConfig settings to pods.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a pod and add the NodeLocal DNSCache IP address (169.254.20.10 in this example) to nameservers in dnsConfig.
    • CCE standard cluster: 169.254.20.10
    Create a nginx.yaml file. The following shows an example:
    apiVersion: v1
    kind: Pod
      containers:
      - image: nginx:alpine
      dnsConfig:
        nameservers:
        - 169.254.20.10
        - 10.247.3.10
        searches:
        - svc.cluster.local
        - cluster.local
        options:
        - name: ndots
          value: '2'
      imagePullSecrets:
      - name: default-secret
  3. Run the following command to create a pod:
    kubectl create -f nginx.yaml
FAQ
  • How Do I Prevent Auto DNSConfig Injection on a Specific Pod?
    Solution:
    Add node-local-dns-injection: disabled to the labels field in the pod template. Example:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: test
      template:
          labels:
            app: test
            node-local-dns-injection: disabled   # Prevent auto DNSConfig injection.
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
          imagePullSecrets:
Helpful Links
