DataPlane V2 Network Acceleration
DataPlane V2 can be enabled for clusters that use a VPC network or Cloud Native Network 2.0. Once enabled, eBPF redirection is supported, which allows the use of network policies.
CCE DataPlane V2 is released with restrictions. To use this feature, submit a service ticket to CCE.
DataPlane V2 |
Description |
Technical implementation |
DataPlane V2 integrates open-source Cilium to provide capabilities such as network policies. |
Supported cluster versions |
CCE standard clusters (using the VPC networks) of v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, or later CCE Turbo clusters of v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, or later |
Usage |
NOTICE:
Supported OS |
Only Huawei Cloud EulerOS 2.0 is supported. |
Performance optimization |
Bandwidth |
After DataPlane V2 network acceleration is enabled, pods on the nodes running Huawei Cloud EulerOS 2.0 use EDT to limit the egress bandwidth. The ingress bandwidth limitation is not supported. In other network modes, a TBF qdisc is used to limit the bandwidth. For details, see Configuring QoS for a Pod. |
NetworkPolicy |
Resource consumption |
The resident cilium-agent process on each node is responsible for eBPF network acceleration. Each cilium-agent process may occupy 80 MiB of memory. Each time a pod is added, the cilium-agent memory consumption may increase by 10 KiB. |
Components
After DataPlane V2 is enabled, components listed in the following table are installed.
Component |
Description |
Resource Type |
cilium-operator |
Deployment |
yangtse-cilium |
DaemonSet |
Change History
Add-on Version |
Cluster Version |
New Feature |
Community Version |
2.0.2 |
v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
1.0.15 |
1.08 |
v1.27 v1.28 v1.29 v1.30 v1.31 |
