Updated on 2026-09-21 GMT+08:00
Priority-based Scheduling and Preemption
A pod priority indicates the importance of a pod relative to other pods. Volcano supports pod PriorityClasses in Kubernetes. After PriorityClasses are configured, the scheduler preferentially schedules high-priority pods. When cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods.
Overview
The services running in a cluster are diversified, including core services, non-core services, online services, and offline services. You can configure priorities for different services based on service importance and SLA requirements. For example, configure a high priority for core services and online services so that such services preferentially obtain cluster resources. When cluster resources are used by non-core services and the remaining resources are insufficient for new core services, the scheduler evicts certain pods of non-core services to release the resources for scheduling the pods of the core services.
Table 1 lists the priority-based scheduling supported by CCE clusters.
Table 1 Priority-based scheduling
Scheduling Type
The scheduler preferentially guarantees the running of high-priority pods, but will not evict low-priority pods that are running. Priority-based scheduling is enabled by default and cannot be disabled.
Priority-based preemption
Configuring Priority-based Scheduling and Preemption Policies
After Volcano is installed, you can enable or disable priority-based scheduling on the Scheduling page.
  2. Choose Settings in the navigation pane and click the Scheduling tab.
  3. In the Service Priority-based Scheduling area, configure priority-based scheduling.
    • Priority-based Scheduling: The scheduler preferentially guarantees the running of high-priority pods, but will not evict low-priority pods that are running. Priority-based scheduling is enabled by default and cannot be disabled.
    • Priority-based Preemption: If Volcano Scheduler is used as the default scheduler of the cluster, priority-based preemption is supported. When cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods.
      • After priority-based preemption is enabled, delayed pod creation is not allowed.
      • Priority-based preemption is not allowed on custom network interface/supplementary network interface resources or host ports.
    Figure 1 Priority-based scheduling
  4. Click Confirm.
  5. After the configuration, you can use PriorityClasses to schedule the pods of workloads or Volcano jobs based on priorities.
    1. Create one or more PriorityClasses.
      apiVersion: scheduling.k8s.io/v1
      kind: PriorityClass
      value: 1000000
      globalDefault: false
      description: ""
    2. Create a workload or Volcano job and specify its PriorityClass name.
      • Workload
        apiVersion: apps/v1
        kind: Deployment
          labels:
            app: high-test
          replicas: 5
          selector:
            matchLabels:
              app: test
          template:
              labels:
                app: test
              priorityClassName: high-priority
              schedulerName: volcano
              containers:
              - name: test
                image: busybox
                imagePullPolicy: IfNotPresent
                command: ['sh', '-c', 'echo "Hello, Kubernetes!" && sleep 3600']
                resources:
                  requests:
                    cpu: 500m
                  limits:
                    cpu: 500m
      • Volcano job
        apiVersion: batch.volcano.sh/v1alpha1
        kind: Job
          minAvailable: 4
          tasks:
            - replicas: 4
              template:
                  containers:
                    - image: alpine
                      command: ["/bin/sh", "-c", "sleep 1000"]
                      resources:
                        requests:
                          cpu: "1"
                  restartPolicy: OnFailure
Example of Priority-based Scheduling
For example, if there are two idle nodes and high-, medium-, and low-priority Volcano jobs in the cluster, run the high-priority job first to exhaust the cluster resources. Then, run the medium- and low-priority jobs. The medium- and low-priority jobs are pending because the high-priority Volcano job is using all cluster resources. After the high-priority job completes, the medium-priority job is scheduled next.
  1. Add three PriorityClasses (high-priority, med-priority, and low-priority) in priority.yaml.
    Example configuration of priority.yaml:
    kind: PriorityClass
    value: 100
    description: "This priority class should be used for volcano job only."
    kind: PriorityClass
    value: 50
    kind: PriorityClass
    value: 10
    Create PriorityClasses.
    kubectl apply -f priority.yaml
  2. Check PriorityClasses.
    kubectl get PriorityClass
    Command output:
    NAME                      VALUE        GLOBAL-DEFAULT   AGE
    high-priority             100          false            97s
    low-priority              10           false            97s
    med-priority              50           false            97s
    system-cluster-critical   2000000000   false            6d6h
    system-node-critical      2000001000   false            6d6h
  3. Create a high-priority Volcano job to exhaust all cluster resources.
    high-priority-job.yaml
    kind: Job
      minAvailable: 4
      tasks:
        - replicas: 4
          template:
              containers:
                - image: alpine
                  resources:
                    requests:
                      cpu: "1"
    Run the following command to issue the job:
    kubectl apply -f high-priority-job.yaml
    Run the kubectl get pod command to check pod statuses:
    NAME                   READY   STATUS    RESTARTS   AGE
    priority-high-test-0   1/1     Running   0          3s
    priority-high-test-1   1/1     Running   0          3s
    priority-high-test-2   1/1     Running   0          3s
    priority-high-test-3   1/1     Running   0          3s
    The command output shows that all cluster resources have been used up.
  4. Create a medium-priority and a low-priority Volcano job.
    med-priority-job.yaml
    kind: Job
      minAvailable: 4
      priorityClassName: med-priority
      tasks:
        - replicas: 4
          template:
              containers:
                - image: alpine
                  resources:
                    requests:
                      cpu: "1"
    low-priority-job.yaml
    kind: Job
      minAvailable: 4
      priorityClassName: low-priority
      tasks:
        - replicas: 4
          template:
              containers:
                - image: alpine
                  resources:
                    requests:
                      cpu: "1"
    Run the following commands to issue the jobs:
    kubectl apply -f med-priority-job.yaml
    kubectl apply -f low-priority-job.yaml
    Run the kubectl get pod command to check the statuses of the pods for the newly created workloads. The command output shows that the pods are pending due to insufficient resources:
    priority-high-test-0     1/1     Running   0          3m29s
    priority-high-test-1     1/1     Running   0          3m29s
    priority-high-test-2     1/1     Running   0          3m29s
    priority-high-test-3     1/1     Running   0          3m29s
    priority-low-test-0      0/1     Pending   0          2m26s
    priority-low-test-1      0/1     Pending   0          2m26s
    priority-low-test-2      0/1     Pending   0          2m26s
    priority-low-test-3      0/1     Pending   0          2m26s
    priority-medium-test-0   0/1     Pending   0          2m36s
    priority-medium-test-1   0/1     Pending   0          2m36s
    priority-medium-test-2   0/1     Pending   0          2m36s
    priority-medium-test-3   0/1     Pending   0          2m36s
  5. Delete the high-priority job to release cluster resources. The medium-priority job will be scheduled next.
    Run the kubectl delete -f high-priority-job.yaml command to release cluster resources and check pod scheduling.
    priority-low-test-0      0/1     Pending   0          5m18s
    priority-low-test-1      0/1     Pending   0          5m18s
    priority-low-test-2      0/1     Pending   0          5m18s
    priority-low-test-3      0/1     Pending   0          5m18s
    priority-medium-test-0   1/1     Running   0          5m28s
    priority-medium-test-1   1/1     Running   0          5m28s
    priority-medium-test-2   1/1     Running   0          5m28s
    priority-medium-test-3   1/1     Running   0          5m28s
Example of Priority-based Preemption
  2. In the navigation pane, choose Settings and click the Scheduling tab.
  3. Modify configurations.
    1. Select Volcano scheduler as the default cluster scheduler.
    2. Enable Priority-based Preemption.
  4. Issue another high-priority Volcano job. The scheduler will evict the medium-priority job to ensure successful scheduling of the high-priority job.
    Run the kubectl apply -f high-priority-job.yaml command to issue the high-priority job. Then, check pod statuses.
    priority-high-test-0     0/1     Pending       0          2s
    priority-high-test-1     0/1     Pending       0          2s
    priority-high-test-2     0/1     Pending       0          2s
    priority-high-test-3     0/1     Pending       0          2s
    priority-low-test-0      0/1     Pending       0          14s
    priority-low-test-1      0/1     Pending       0          14s
    priority-low-test-2      0/1     Pending       0          14s
    priority-low-test-3      0/1     Pending       0          14s
    priority-medium-test-0   1/1     Terminating   0          21s
    priority-medium-test-1   1/1     Terminating   0          21s
    priority-medium-test-2   1/1     Terminating   0          21s
    priority-medium-test-3   1/1     Terminating   0          21s
    After the resources used by the medium-priority job are released, the high-priority job can be scheduled.
    priority-high-test-0     1/1     Running   0          70s
    priority-high-test-1     1/1     Running   0          70s
    priority-high-test-2     1/1     Running   0          70s
    priority-high-test-3     1/1     Running   0          70s
    priority-low-test-0      0/1     Pending   0          82s
    priority-low-test-1      0/1     Pending   0          82s
    priority-low-test-2      0/1     Pending   0          82s
    priority-low-test-3      0/1     Pending   0          82s
    priority-medium-test-0   0/1     Pending   0          37s
    priority-medium-test-1   0/1     Pending   0          36s
    priority-medium-test-2   0/1     Pending   0          37s
    priority-medium-test-3   0/1     Pending   0          37s
    When node resources are insufficient for the high-priority job, priority-based preemption by volcano-scheduler will be triggered. The medium-priority job will be evicted to deploy the high-priority job. After new nodes are added using Cluster Autoscaler, volcano-scheduler will schedule the medium-priority job to the new nodes.
    According to the preceding test results, enable node scaling if priority-based preemption is enabled so that cluster resources can be allocated on demand to ensure service SLA.
Example of Affinity and Anti-affinity for Priority-based Preemption
Do not configure inter-pod affinity on the pods with lower priorities. If a pod in the pending state is inter-pod affinity with one or more pods with lower priorities on the node, the pod affinity rule cannot be met when preemption is initiated for the pods with lower priorities, and the preemption rule conflicts with the affinity rule. In this case, the scheduler cannot ensure the scheduling of the pending pod. To resolve this issue, configure inter-pod affinity only for pods with the same or higher priority. For details, see Inter-pod affinity on lower-priority pods.
In inter-pod affinity, if priority-based preemption is enabled and deploy1 is affinity with lower-priority deploy2, volcano-scheduler will evict deploy3 and schedule deploy1 to the node to ensure service O&M. The evicted deploy3 will be scheduled to the new node after the new node is ready.
Figure 2 Inter-pod affinity on lower-priority pods
In inter-pod anti-affinity, if priority-based preemption is enabled and deploy1 is anti-affinity with deploy2 and deploy3, volcano-scheduler will not evict deploy2 and deploy3 to minimize the impact on other services. Instead, the scheduler will schedule deploy1 to a new node.
Figure 3 Inter-pod anti-affinity on lower-priority pods
