Help Center/ Cloud Container Engine/ User Guide/ Networking/ Container Networks/ Cloud Native Network 2.0 Settings/ Configuring a Static EIP for a Pod in a CCE Turbo Cluster
Updated on 2026-09-21 GMT+08:00
Application Scenarios
In Cloud Native Network 2.0, static public IP addresses (EIPs) can be assigned to StatefulSets or pods created directly.
Notes and Constraints
  • You can configure a static EIP for a pod only in CCE Turbo clusters of the following versions:
    • v1.19: v1.19.16-r20 or later
    • v1.21: v1.21.10-r0 or later
    • v1.23: v1.23.8-r0 or later
    • v1.25: v1.25.3-r0 or later
    • Versions later than v1.25
  • The static EIP function must be enabled together with the function of automatically allocating an EIP for a pod. For details, see Configuring an EIP for a Pod in a CCE Turbo Cluster.
  • Only StatefulSet pods or pods created directly can be bound with static EIPs. Deployments, DaemonSets, and other types of workloads cannot be bound with static EIPs.
  • After a static EIP is allocated, the EIP attributes cannot be modified through the pod within the EIP lifecycle (before the EIP expires or it is still being used by the pod).
  • Do not configure a static EIP for services that do not have specific requirements on pod EIPs. Otherwise, the pod rebuilding takes a longer time.
When creating a pod to be bound with a static IP address, configure the EIP annotations. Then, an EIP will be automatically allocated and bound to the pod.
For an automatically allocated EIP with a dedicated bandwidth when you create a StatefulSet, you do not need to specify the bandwidth ID. The following shows an example:
apiVersion: apps/v1
kind: StatefulSet
  serviceName: nginx
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      annotations:
        yangtse.io/static-eip: 'true'   # Static EIP bound to the pod
        yangtse.io/static-eip-expire-no-cascading: 'false'   # Deleting the EIP with the associated workload
        yangtse.io/static-eip-expire-duration: 5m   # Interval for reclaiming expired EIPs
        yangtse.io/pod-with-eip: 'true'   # An EIP will be automatically allocated when the pod is created.
        yangtse.io/eip-bandwidth-size: '5'    # EIP bandwidth
        yangtse.io/eip-network-type: 5_bgp    # EIP type
        yangtse.io/eip-charge-mode: bandwidth    # EIP billing mode
      containers:
        - name: container-0
          image: nginx:alpine
          resources:
            limits:
              cpu: 100m
              memory: 200Mi
            requests:
              cpu: 100m
              memory: 200Mi
      imagePullSecrets:
        - name: default-secret
Table 1 Annotations of the pod's static EIP
Annotation
Mandatory
Default Value
Value Range
Yes
false
Whether to enable the static EIP for a pod. This function is available only for StatefulSet pods or pods without ownerReferences. This function is disabled by default.
false or true
No
5m
Specifies the interval for reclaiming the expired static EIP after the pod with a static EIP is deleted.
The time format is Go time type, for example, 1h30m and 5m. For details, see Go time type.
No
false
Specifies whether to disable cascading reclamation of StatefulSet workloads.
The default value is false, indicating that the corresponding static EIP will be deleted with the StatefulSet workload. If you want to retain the static EIP for a new StatefulSet with the same name during the interval for reclaiming the expired EIP, set the value to true.
false or true
Table 2 Annotations of an EIP with a dedicated bandwidth
Annotation
Mandatory
Default Value
Value Range
Yes
false
Whether to allocate an EIP with a pod and bind the EIP to the pod
false or true
No
5
Bandwidth, in Mbit/s
The value range varies depending on the region and bandwidth billing mode. For details, see the purchase page on the EIP console.
For example, in the AP-Singapore region, if an EIP is billed by bandwidth, the bandwidth ranges from 1 Mbit/s to 2000 Mbit/s; if an EIP is billed by traffic, the bandwidth ranges from 1 Mbit/s to 300 Mbit/s.
No
5_bgp
EIP type
The type varies depending on the region. For details, see the purchase page on the EIP console.
For example, the following options are available in the AP-Singapore region:
  • 5_bgp: dynamic BGP
No
None
EIP billing mode
You are advised to configure this parameter. If this parameter is left blank, no billing mode is specified. In this case, the default value of the EIP API in the region is used.
  • bandwidth: billed by bandwidth
  • traffic: billed by traffic
yangtse.io/eip-bandwidth-name
No
Pod name
Bandwidth name
  • Enter 1 to 64 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
  • Minimum length: 1 character
  • Maximum length: 64 characters
yangtse.io/eip-enterprise-project-id
No
'0'
ID of the enterprise project for creating an EIP. You can view the enterprise project ID on the Project Management page of the EPS console.
This function is available in clusters v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later.
If this parameter is left empty, 0 is used, indicating the default enterprise project.
In other cases, enter the actual enterprise project ID.
yangtse.io/eip-user-tags
No
Left empty
Resource tags of the EIP.
The value is written in JSON format. For example:
'[{"key":"Project","value":"Migration-2024"},{"key":"Owner","value":"DevOps-Team"},{"key":"IsTemporary","value":"True"}]'
You can add a maximum of 17 custom tags. The key and value ranges must follow the EIP constraints.
For an automatically allocated EIP with a shared bandwidth when you create a StatefulSet, you are required to specify the bandwidth ID. The following shows an example:
apiVersion: apps/v1
kind: StatefulSet
  serviceName: nginx
  replicas: 3
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      annotations:
        yangtse.io/eip-bandwidth-id: <eip_bandwidth_id>    # Shared bandwidth ID of the EIP
      containers:
        - name: container-0
          image: nginx:alpine
          resources:
            limits:
              cpu: 100m
              memory: 200Mi
            requests:
              cpu: 100m
              memory: 200Mi
      imagePullSecrets:
Table 3 Annotations of the pod's static EIP
Annotation
Mandatory
Default Value
Value Range
Yes
false
false or true
No
5m
No
false
false or true
Table 4 Annotations of an EIP with a shared bandwidth
Annotation
Mandatory
Default Value
Value Range
Yes
false
false or true
No
5_bgp
EIP type
  • 5_bgp
  • 5_union
  • 5_sbgp
The types vary by region. For details, see the EIP console.
Mandatory when a shared bandwidth is used
None
ID of an existing bandwidth
  • If this parameter is not specified, the EIP with a dedicated bandwidth is used by default. For details about how to configure parameters for an EIP with a dedicated bandwidth, see Table 1.
  • Only the yangtse.io/eip-network-type field can be specified concurrently, and this field is optional.
None
No
'0'
No
Left empty
Deleting a Static EIP
After a pod is deleted, if another pod with the same name is created before the static EIP expires, the EIP can still be used. The static EIP is deleted only if there is no new pod with the name the same as that of the deleted pod before the EIP expires, or the function of deleting the EIP with the associated StatefulSet is enabled and the StatefulSet is deleted.
