Configuring a Shared Bandwidth for Dual-Stack Pods in a CCE Turbo Cluster
Application Scenarios
By default, pods with IPv6 dual-stack network interfaces can access only the IPv6 private network. To access the public network, configure shared bandwidth for such pods.
- Only CCE Turbo clusters are supported and the following constraints must be met:
- IPv6 dual stack has been enabled for the cluster.
- The cluster version is v1.23.8-r0, v1.25.3-r0, or later.
- The number of IPv6 network interfaces that can be added to a shared bandwidth is limited by the tenant quota. The default value is 20.
- hostNetwork Pods are not supported.
- All types of workloads are supported. When configuring IPv6 shared bandwidth for workloads with the replicas attribute, such as Deployment and StatefulSet, ensure that the number of replicas and the maximum number of pods during the upgrade are less than the remaining quota of IPv6 network interfaces that can be added to the shared bandwidth.
- IPv6 dual-stack pod configured with shared bandwidth: When a pod is created, the CNI returns a success message only after the IPv6 dual-stack network interface is inserted into the shared bandwidth. When a pod is deleted, the IPv6 dual-stack network interface is removed from the shared bandwidth after the pod is completely deleted or the pod is in the deleting status for 30 seconds.
- If the IPv6 dual-stack network interface corresponding to the pod fails to be added to the shared bandwidth, an alarm event FailedIPv6InsertBandwidth is generated on the pod, for example, when the quota is exceeded or flow control is triggered. Rectify the fault based on the alarm event.
- On the Shared Bandwidths page of the EIP console, go to the target shared bandwidth details page and click the IPv6 Addresses tab. The IPv6 dual-stack network interface whose associated instance is CCE is displayed. Do not remove the network interface directly on the page or using VPC APIs, or your services may be affected.
Using the CCE Console
When creating a workload, you can set the IPv6 shared bandwidth on the Advanced Settings > Network Configuration area.
Using kubectl
You can add annotations to a Deployment to specify the shared bandwidth to be added to the IPv6 dual-stack network interface of the pod. The following is an example:
selector:
matchLabels:
app: demo
version: v1
template:
annotations:
yangtse.io/ipv6-bandwidth-id: "xxx" - yangtse.io/ipv6-bandwidth-id: specifies the ID of the shared bandwidth. The IPv6 dual-stack network interfaces corresponding to the pod will be added to the shared bandwidth. You can obtain the ID on the Shared Bandwidths page on the EIP console.
