Updated on 2026-06-16 GMT+08:00
Obtaining Pod Network Interfaces in a CCE Turbo Cluster
In a CCE Turbo cluster, the network model add-on automatically binds an independent network interface or supplementary network interface to each pod. If there are a large number of pods in the cluster, the number of network interfaces also increases accordingly. In some scenarios, you may need to obtain network interface details of pods based on service requirements. For example, during network monitoring or troubleshooting, you can obtain the network interface ID of a pod to more accurately locate the fault. In some scenarios, you can specify custom configuration management based on network interface details.
This section describes how to obtain network interface details of pods from the pod annotations. This function supports the following configurations:
  • Global configuration: Network interface details of all pods will be displayed. This means you can enable enablePodNetworkStatus in YangtseConfiguration. For details, see Global Configuration.
    Do not modify other YangtseConfiguration parameters. Doing so may cause serious issues, including cluster unavailability.
  • On-demand configuration: You can configure the yangtse.io/enable-pod-network-status annotation for a pod to display its network interface details. For details, see On-demand Configuration.
The following table lists the logic of displaying network interface details when you configure switches at different levels.
Network Interface Details Displayed
Enabled (true)
Enabled (true)
Yes
Enabled (true)
Disabled (false)
No
Enabled (true)
Not set
Yes
Disabled (false)
Enabled (true)
Yes
Disabled (false)
Disabled (false)
No
Disabled (false)
Not set
No
Notes and Constraints
  • This function is only available in CCE Turbo clusters of the following versions:
    • v1.27: v1.27.16-r50 or later
    • v1.28: v1.28.15-r40 or later
    • v1.29: v1.29.15-r0 or later
    • v1.30: v1.30.14-r0 or later
    • v1.31: v1.31.10-r0 or later
    • v1.32: v1.32.6-r0 or later
    • v1.33 or later
  • This function affects the pod startup performance when a large number of pods are created in a batch.
Use one of the following methods.
After the global configuration is enabled or disabled, network interface details of existing pods can be displayed or not displayed only after the pods are restarted.
  1. Connect to your cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
  2. Edit the YangtseConfiguration resource:
    kubectl patch yc default --type='merge' -p '{"spec":{"eni":{"enablePodNetworkStatus":true}}}'
    To disable the global configuration, change the preceding command to the following:
    kubectl patch yc default --type='merge' -p '{"spec":{"eni":{"enablePodNetworkStatus":false}}}'
  3. Create a file named nginx.yaml. You can change the file name as required.
    vi nginx.yaml
    Example YAML:
    apiVersion: v1
    kind: Pod
      containers:
      - image: nginx:latest
        resources:
          limits:
            cpu: 100m
            memory: 200Mi
          requests:
            cpu: 100m
            memory: 200Mi
      imagePullSecrets:
      - name: default-secret
  4. Create a pod.
    kubectl create -f nginx.yaml
    Command output:
    pod/nginx created
  5. Query the pod status. Network interface details are automatically obtained and displayed in the pod annotation.
    kubectl get pod nginx -o yaml
    Command output:
    In this command:
    • name: indicates the container network configuration name used by the pod.
    • portID: indicates the ID of the network interface used by the pod.
    • ips: indicates the IP address of the network interface.
  2. Create a file named nginx.yaml. You can change the file name as required.
    vi nginx.yaml
    Example YAML:
    apiVersion: v1
    kind: Pod
      annotations:
        yangtse.io/enable-pod-network-status: "true"  # Displays network interface details.
      containers:
        resources:
          limits:
            cpu: 100m
            memory: 200Mi
          requests:
            cpu: 100m
            memory: 200Mi
      imagePullSecrets:
  3. Create a pod.
    Command output:
    pod/nginx created
  4. Query the pod status. Network interface details are automatically obtained and displayed in the pod annotation.
    Command output:
    In this command:
