Situation Awareness
On this page
Show all
Release Notes for Kubernetes 1.9 (EOM) and Earlier Versions
Updated on 2024-08-16 GMT+08:00
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. This section describes the updates in CCE Kubernetes 1.9 and earlier versions.
Table 1 Description of v1.9 and earlier version clusters
Kubernetes (CCE Enhanced Version)
v1.9.10-r2
Highlights:
  • ELB load balancing algorithms: source IP hash and sticky sessions with backend servers.
v1.9.10-r1
Highlights:
  • CCE works with SFS.
  • Enhanced ELBs can be automatically created for Services.
  • Transparent transmission of source IP addresses is supported for enhanced ELBs on the public network.
  • The maximum number of pods on a node can be set.
v1.9.10-r0
Highlights:
  • Use of ELB/ingress for Kubernetes clusters; new traffic control mechanism.
  • Features of Kubernetes v1.9.10 are incorporated.
  • Kubernetes RBAC capability authorization is supported.
Fault rectification:
  • Occasional memory leak on nodes, which is caused by kernel cgroup bugs.
v1.9.7-r1
Highlights:
  • The mechanism for reporting PVC and PV events is enhanced. Events can be viewed on the PVC details page.
  • CCE works with a third-party authentication system.
  • Physical machines that use EulerOS 2.3 can be managed.
  • Data disk allocation can be user-defined.
  • Elastic Volume Service (EVS) disks are supported for BMSs.
  • InfiniBand NICs are supported for BMSs.
  • Nodes can be created using the CM-v3 API in BMS scenarios.
v1.9.7-r0
Highlights:
  • The Docker version of new clusters is upgraded to v17.06.
  • DNS cascading is supported.
  • Add-ons can be managed.
  • Features of Kubernetes v1.9.7 are incorporated.
  • The HTTPS of layer-7 ingress is supported.
  • StatefulSets can be migrated, scheduled, updated, and upgraded.
v1.9.2-r3
Highlights:
  • Cluster nodes that use CentOS 7.4 can be created or managed.
  • DNAT Services are supported.
  • NetworkPolicy APIs are provided.
  • Multiple ports can be configured for a Kubernetes Service that uses an ELB.
  • Incomplete pod resource recycling caused by a disconnection with kube-apiserver
  • Data inaccuracy during auto node scaling
v1.9.2-r2
Highlights:
  • Custom health check ports can be configured for classic load balancers.
  • Performance of classic load balancers is enhanced.
  • Kubernetes Service ports can be configured for layer-4 load balancing.
  • Bugs in network add-ons, which cause deadlocks in health checks.
  • A limited number of HAProxy connections in an HA cluster.
v1.9.2-r1
Highlights:
  • Features of Kubernetes v1.9.2 are incorporated.
  • Cluster nodes support CentOS 7.1.
  • GPU nodes are supported and GPU resource use can be restricted.
  • The web-terminal add-on is supported.
v1.7.3-r13
Highlights:
  • OBS is supported for BMS clusters.
v1.7.3-r12
Highlights:
  • The event aging period prompt is modified. The cluster aging period is 1 hour.
v1.7.3-r11
Highlights:
  • Namespaces can be deleted.
  • EVS disks can be unbound.
  • Migration policies can be configured.
v1.7.3-r10
Highlights:
  • Overlay L2 container networks are supported.
  • Cluster nodes can be GPU-accelerated VMs.
  • Cluster nodes support CentOS 7.1 and the operating system can be selected.
  • Windows clusters support ELBs.
  • CCE allows exporting data from SFS.
  • BMS clusters support SFS.
v1.7.3-r9
Highlights:
  • Cross-AZ deployment is supported for workloads.
  • Containers support OBS.
  • Layer-7 load balancing is supported.
  • Windows clusters support EVS.
  • Device mapper in direct-lvm mode is supported in BMS scenarios.
v1.7.3-r8
Highlights:
  • Auto scaling is supported for cluster nodes.
  • Arm nodes can be managed.
v1.7.3-r7
Highlights:
  • SUSE 12 sp2 nodes can be managed in the container clusters (in the tunnel network mode).
  • Docker supports the device mapper in direct-lvm mode.
  • Clusters support the dashboard add-on.
  • Windows clusters can be created.
v1.7.3-r6
Highlights:
  • Native EVS APIs are supported for clusters.
v1.7.3-r5
Highlights:
  • HA clusters can be created.
  • Container network disconnection after a node restart
v1.7.3-r4
Highlights:
  • Cluster performance is enhanced.
  • Interconnection with ELB is allowed in BMS scenarios.
v1.7.3-r3
Highlights:
  • Storage can be attached to kernel-based virtual machines (KVMs).
v1.7.3-r2
Highlights:
  • SFS is supported to provide container storage.
  • Custom logs can be configured for workloads.
  • Graceful scaling-in is supported for workloads.
  • Expiration of Access Key ID/Secret Access Key (AK/SK) of container storage volumes.
v1.7.3-r1
Highlights:
  • External domain names can be resolved by kube-dns.
v1.7.3-r0
Highlights:
  • Features of Kubernetes v1.7.3 are incorporated.
  • Elastic Load Balance (ELB) is supported.
  • Storage can be attached to Xen VMs.
  • EVS is supported to provide container storage.
