Help Center/ Cloud Container Engine/ User Guide/ Permissions/ Namespace Permissions (Kubernetes Resource Permissions)/ Using the AccessPolicy API to Manage Namespace Permissions (Kubernetes RBAC-based)
Updated on 2026-09-21 GMT+08:00
In multi-user scenarios, it is often necessary to grant specific levels of cluster resource access permissions to different user groups. However, IAM permissions lack the capability for fine-grained authorization based on cluster resource types. As a result, you must first grant permissions to users in IAM and then separately configure namespace permissions using Kubernetes RBAC authorization within the cluster. This dual-system approach creates additional complexity and leads to a significant maintenance workload.
CCE offers a streamlined solution by enabling the use of AccessPolicy API to manage namespace permissions. By integrating IAM permissions with Kubernetes cluster permissions, you can use IAM to oversee Kubernetes resource access for various users. This approach simplifies the management process of IAM permissions and Kubernetes cluster permissions, allowing permissions to be assigned efficiently across multiple clusters or users in batches and significantly reducing the workload for cluster administrators.
This feature is still in OBT. Fully verify it before using it in a production environment.
  • Before assigning permissions to users or user groups, you need to review the information provided in Configuring Namespace Permissions (Kubernetes RBAC-based).
  • To use an access policy, an IAM user or user group must have the specific permissions. These include CreateAccessPolicy, UpdateAccessPolicy, DeleteAccessPolicy, ListAccessPolicy, and GetAccessPolicy. Learn about the CCE system policies that can be added to a user group and select appropriate ones as needed. For details about how to assign permissions to a user group, see Cluster Permissions (IAM-based Authorization).
Configuring Namespace Permissions Through APIs
You can regulate users' or user groups' access to Kubernetes resources in a single namespace based on their Kubernetes RBAC roles. Users with the configuration permission can configure access policies through APIs.
  1. Call the API to create an access policy. For details, see Making an API Request.
    POST /api/v3/access-policies
    The request body is as follows:
        "kind": "AccessPolicy",
        "apiVersion": "v3",
        "name": "policy-test",
        "clusters": [ "*" ],
        "accessScope": {
            "namespaces": [ "default" ]
        "policyType": "CCEClusterAdminPolicy",
        "principal": {
            "type": "user",
            "ids": ["id1", "id2" ]
    Item
    name
    Name
    Name of the access policy.
    clusters[]
    Cluster list
    ID list of clusters for which access policies need to be added. A maximum of 200 clusters can be authorized at a time. For details about how to obtain a cluster ID, see How to Obtain Parameters in the API URI.
    The wildcard character (*) is supported, indicating that access policies are added to all clusters.
    CAUTION:
    The cluster to which an access policy is applied must be in a normal state. If the cluster is hibernated or abnormal, API request delivery may fail or behave unexpectedly.
    accessScope.namespaces[]
    Namespace
    List of namespaces for which access policies need to be added. A maximum of 500 namespaces can be authorized at a time.
    The wildcard character (*) is supported, indicating that access policies are added to all namespaces.
    • When an access policy is added to a specific namespace, a RoleBinding is created within that namespace, and the assigned permissions become effective there. Once the creation process is complete, the corresponding RoleBinding can be obtained within the namespace.
    • When an access policy is added to all namespaces, a ClusterRoleBinding is created, and the assigned permissions become effective within the entire cluster.
    policyType
    Permission type
    Permission type. Options:
    • CCEClusterAdminPolicy: administrator permissions, including read and write permissions on all resources in all namespaces.
    • CCEAdminPolicy: O&M permissions, including read and write permissions on most resources in all namespaces and read-only permissions on nodes, storage volumes, namespaces, and quota management.
    • CCEEditPolicy: developer permissions, including read-write permissions on most resources in all or selected namespaces. When configured for all namespaces, these permissions are equivalent to O&M permissions.
    • CCEViewPolicy: read-only permissions, including read-only permissions on most resources in all or selected namespaces.
    principal.type
    User or user group type.
    Type of the user or user group authorized by the access policy. Options:
    • user: IAM user
    • group: user group
    • agency: agency account
    principal.ids[]
    User or user group list
    List of IDs of IAM users, user groups, or agencies to be authorized. A maximum of 500 IDs can be entered at a time.
    For details about how to obtain an ID, see Obtaining Account, IAM User, Group, Project, Region, and Agency Information.
  2. The CCE management plane automatically synchronizes the access policies to the associated cluster. Run the kubectl command. Then, RoleBinding or ClusterRoleBinding will be created in the cluster.
    The synchronization will take several minutes to take effect.
    In this example, the administrator permissions of the default namespace are granted to an IAM user. You can obtain the corresponding RoleBinding in the default namespace.
    1. Check RoleBinding in the cluster.
      kubectl get rolebinding -n default
      In the following command output, role_access_policy_2abf31fc-cd7a-11ef-9ed5-0255ac100047 specifies the automatically created RoleBinding.
      NAME                                                      ROLE                        AGE
      role_access_policy_2abf31fc-cd7a-11ef-9ed5-0255ac100047   ClusterRole/cluster-admin   27s
    2. Check RoleBinding details.
      kubectl get rolebinding role_access_policy_2abf31fc-cd7a-11ef-9ed5-0255ac100047 -n default -o yaml
      Command output:
      kind: RoleBinding
        annotations:
          CCE.com/IAM: "true"
        creationTimestamp: "2025-03-26T07:58:24Z"
        labels:
          rbac.kubernetes.io/GeneratedByAccessPolicy: "true"
        namespace: default
        resourceVersion: "1086"
        uid: 7000328f-c91c-4731-b3a6-807713c29f35
      roleRef:
        apiGroup: rbac.authorization.k8s.io
        kind: ClusterRole
      subjects:
      - apiGroup: rbac.authorization.k8s.io
        kind: User
        kind: User
  3. Log in to the CCE console as the newly authorized IAM user for verification. For more information, see Logging In as an IAM User.
    In the service list, choose Cloud Container Engine. On the CCE console, access the cluster and choose the target namespace. If only the default namespace is authorized and the kube-system namespace is unavailable, the access policy has taken effect.
