Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ Nginx Ingresses/ Creating an Nginx Ingress Using kubectl
Updated on 2026-09-21 GMT+08:00
This section uses an Nginx workload as an example to describe how to create an Nginx ingress using kubectl.
  • An ingress provides network access for backend workloads. Ensure that a workload is available in a cluster. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A ClusterIP or NodePort Service has been configured for the workload. For details about how to configure the Service, see ClusterIP or NodePort.
  • To add Nginx Ingress, ensure that the NGINX Ingress Controller add-on has been installed in the cluster. For details, see Installing the Add-on.
  • It is not recommended that you modify any configuration of a load balancer on the ELB console. Otherwise, the Service will be abnormal. If you have modified the configuration, uninstall the nginx-ingress add-on and reinstall it.
  • The URL registered in an ingress forwarding policy must be the same as the URL used to access the backend Service. Otherwise, a 404 error will be returned.
  • The selected or created load balancer must be in the same VPC as the current cluster, and it must match the load balancer type (private or public network).
  • The load balancer has at least two listeners, and ports 80 and 443 are not occupied by listeners.
  • In CCE standard clusters, when the NGINX Ingress Controller is bound to a dedicated load balancer, the node hosting the cceaddon-nginx-ingress-controller pod, and any other containers on that same node, cannot use the load balancer's private IP to access the ingress.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. You can change the file name if you want to.
    vi ingress-test.yaml
    Starting from cluster v1.23, the ingress version is switched from networking.k8s.io/v1beta1 to networking.k8s.io/v1. For details about the differences between v1 and v1beta1, see Ingress API Version Upgrade in CCE Clusters v1.23.
    The following uses HTTP as an example to describe how to configure the YAML file:
    For clusters v1.23 or later:
    kind: Ingress
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with your target Service name.
                    port:
                      number: <your_service_port>  # Replace it with your target Service port.
                property:
      ingressClassName: nginx   # Nginx ingresses are used. If multiple NGINX Ingress Controllers are installed in the cluster, replace nginx with the custom names of the controllers associated with the ingresses.
    For clusters v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/ingress.class: nginx   # Nginx Ingress is used.
      rules:
        - host: ''
          http:
            paths:
              - path: '/'
                backend:
                  serviceName: <your_service_name>  # Replace it with your target Service name.
                  servicePort: <your_service_port>  # Replace it with your target Service port.
    Table 1 Key parameters
    Mandatory
    Type
    Yes (only for clusters v1.21 or earlier)
    String
    nginx: indicates that Nginx Ingress is used. This option is available only after the NGINX Ingress Controller add-on is installed.
    This parameter is mandatory when you create an Nginx ingress. If it is not specified, a LoadBalancer ingress will be created by default.
    ingressClassName
    Yes
    (only for clusters v1.23 or later)
    String
    Multiple NGINX Ingress Controller add-ons can be installed in a single cluster if the add-on version is 2.5.4 or later. In this case, the value of this parameter must be the controller name customized during controller installation, indicating that the ingress is managed by that specific controller.
    host
    No
    String
    Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
    path
    Yes
    String
    User-defined route path. All external access requests must match host and path.
    • The access path matching rule of Nginx Ingress is based on the path prefix separated by the slash (/) and is case-sensitive. If the subpath separated by a slash (/) matches the prefix, the access is normal. However, if the prefix is only a part of the character string in the subpath, the access is not matched. For example, if the URL is set to /healthz, /healthz/v1 is matched, but /healthzv1 is not matched.
    • The access path added here must exist in the backend application. Otherwise, the forwarding fails.
      For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
    No
    String
    Route matching policy.
    Default: STARTS_WITH (prefix match)
    Options:
    • EQUAL_TO: exact match
    • STARTS_WITH: prefix match
    pathType
    Yes
    String
    Path type. This field is supported only by clusters v1.23 or later.
    • ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
    • Exact: exact matching of the URL, which is case-sensitive.
    • Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally.
      • During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
      • When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
    See examples of ingress path matching.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS   HOSTS     ADDRESS          PORTS   AGE
    ingress-test  nginx   *         121.**.**.**     80      10s
  5. Enter http://121.**.**.**:80 in the address bar of the browser to access the workload (for example, Nginx workload).
    121.**.**.** indicates the IP address of the unified load balancer.
Helpful Links
