Updated on 2026-09-21 GMT+08:00
Creating a StatefulSet
A StatefulSet is an application that needs to retain data or state while running. StatefulSets are ideal for stateful applications, such as databases, cache services, and message queues. Unlike Deployments, StatefulSets have the following features:
  • Fixed identifier: Each pod in a StatefulSet has a fixed identifier, which is associated with the pod name. The identifier is typically in the format of <StatefulSet name>-<Ordinal>. For example, in a StatefulSet named web, the pods would have the names like web-0 and web-1. This naming rule enables each pod to maintain its identity and persistent data even after restart or migration.
  • Ordered deployment and scaling: Pods in a StatefulSet are created, scaled, or deleted sequentially. For example, pods with higher ordinals are prioritized for scale-out and removed first during scale-in, which is critical to stateful applications that need to be started or stopped in sequence and ideal for scenarios like primary-secondary replication of databases.
  • Persistent storage: To ensure data persistence, you can assign stable persistent storage volumes to each StatefulSet pod by using VolumeClaimTemplate. If a pod is scheduled to other nodes, its original data volume remains intact via the PVC, preventing data loss.
  • When you delete or scale a StatefulSet, the system does not delete the storage volumes associated with the StatefulSet to ensure data security.
  • When you delete a StatefulSet, reduce the number of replicas to 0 before deleting the StatefulSet so that pods in the StatefulSet can be stopped in order.
  • When you create a StatefulSet, a headless Service is required for pod access. For details, see Headless Services.
  • When a node is unavailable, pods become Unready. In this case, manually delete the pods of the StatefulSet so that the pods can be migrated to a normal node.
You can create a StatefulSet using the console or kubectl.
  1. Log in to the CCE console.
  2. Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click Create Workload in the upper right corner.
  3. Configure basic information about the workload.
    Workload Type
    Select StatefulSet. For details about different workload types, see Workload Overview.
    Workload Name
    Enter a name for the workload. Enter 1 to 63 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    Namespace
    Select a namespace for the workload. The default value is default. You can also click Create Namespace to create one. For details, see Creating a Namespace.
    Pods
    Enter the number of workload pods.
    Container Runtime
    A CCE standard cluster uses a common runtime by default, whereas a CCE Turbo cluster supports both common and secure runtimes. For details about their differences, see Secure Runtime and Common Runtime.
    Time Zone Synchronization
    Configure whether to enable time zone synchronization. After this function is enabled, the container and node will share the same time zone. Time zone synchronization relies on the local disk mounted to the container. Do not modify or delete the local disk. For details, see Configuring Time Zone Synchronization.
  4. Configure container settings for the workload.
    • Container Information: Click Add Container on the right to configure multiple containers for the pod.
      If you configured multiple containers for a pod, ensure that the ports used by each container do not conflict with each other, or the workload cannot be deployed.
      • Basic Info: Configure basic information about the container.
        Container Name
        Enter a name for the container.
        Pull Policy
        Image update or pull policy. If you select Always, the image is pulled from the image repository each time. If you do not select Always, the existing image of the node is preferentially used. If the image does not exist, the image is pulled from the image repository.
        Image Name
        To use a third-party image, directly enter image path. Ensure that the image access credential can be used to access the image repository. For details, see Using Third-Party Images.
        Image Tag
        Select the image tag to be deployed.
        CPU Quota
        • Request: minimum number of CPU cores required by a container. The default value is 0.25 cores.
        • Limit: maximum number of CPU cores that can be used by a container. This prevents containers from using excessive resources.
        If Request and Limit are not specified, the quota is not limited. For more information and suggestions about Request and Limit, see Configuring Container Specifications.
        Memory Quota
        • Request: minimum amount of memory required by a container. The default value is 512 MiB.
        • Limit: maximum amount of memory available for a container. When memory usage exceeds the specified memory limit, the container will be terminated.
        (Optional) GPU Quota
        Configurable only when the cluster contains GPU nodes and the CCE AI Suite (NVIDIA GPU) add-on has been installed.
        • Do not use: No GPU will be used.
        • GPU card: The GPU is dedicated for the container.
        • GPU Virtualization: percentage of GPU resources used by the container. For example, if this parameter is set to 10%, the container will use 10% of GPU resources.
        For details about how to use GPUs in a cluster, see Default GPU Scheduling in Kubernetes.
        (Optional) NPU Quota
        Configurable only when the cluster contains NPU nodes and the CCE AI Suite (Ascend NPU) add-on has been installed.
        • Do not use: No NPU will be used.
        • Complete NPU allocation: mounts the entire host NPUs into containers.
        • NPU virtualization: virtualizes host NPUs to provide vNPUs, which are allocated to containers.
        For details about how to use NPUs in a cluster, see Complete NPU Allocation.
        (Optional) Privileged Container
        Programs in a privileged container have certain privileges. If this option is enabled, the container will be assigned privileges. For example, privileged containers can manipulate network devices on the host machine, modify kernel parameters, access all devices on the node.
        For more information, see Pod Security Standards.
        (Optional) Init Container
        Whether to use the container as an init container. An init container does not support health check.
        An init container is a special container that runs before other app containers in a pod are started. Each pod can contain multiple containers. In addition, a pod can contain one or more init containers. Application containers in a pod are started and run only after the running of all init containers completes. For details, see Init Containers.
        (Optional) Run Option
        Add run options for the container. For details, see Pod. CCE supports the following run options:
        • stdin: allows containers to receive input from external sources, such as terminals or other input streams.
        • tty: allocates a pseudo terminal to containers, allowing you to send commands to them as if you were using a local terminal.
          In most cases, tty is enabled along with stdin, indicating that the terminal (tty) is associated with the standard input (stdin) of the container. This allows for interactive operations, similar to the kubectl exec -i -t command. The difference is that this parameter has been configured when the pod is launched.
      • (Optional) Lifecycle: Configure operations to be performed in a specific phase of the container lifecycle, such as Startup Command, Post-Start, and Pre-Stop. For details, see Configuring the Container Lifecycle.
      • (Optional) Health Check: Set the liveness probe, ready probe, and startup probe as required. For details, see Configuring Container Health Check.
      • (Optional) Environment Variables: Configure variables for the container running environment using key-value pairs. These variables transfer external information to containers running in pods and can be flexibly modified after application deployment. For details, see Configuring Environment Variables.
      • (Optional) Data Storage: Mount local storage or cloud storage to the container. The application scenarios and mounting modes vary with the StorageClass. For details, see Storage.
        • StatefulSets support dynamic attachment of EVS disks. For details, see Dynamically Mounting an EVS Disk to a StatefulSet or Dynamically Mounting a Local PV to a StatefulSet.
          Dynamic mounting is achieved by using the volumeClaimTemplates field and depends on the dynamic creation capability of StorageClass. A StatefulSet associates each pod with a PVC using the volumeClaimTemplates field, and the PVC is bound to the corresponding PV. Therefore, after the pod is rescheduled, the original data can still be mounted based on the PVC name.
        • After a workload is created, the dynamically mounted storage cannot be updated.
      • (Optional) Security Context: Assign container permissions to protect the system and other containers from being affected. Enter the user ID to assign container permissions and prevent systems and other containers from being affected.
      • (Optional) Logging: Report standard container output logs to AOM by default, without requiring manual settings. You can manually configure the log collection path. For details, see Using ICAgent to Collect Container Logs.
        To disable the collection of the standard output logs of the current workload, add the annotation kubernetes.AOM.log.stdout: [] in Labels and Annotations in the Advanced Settings area. For details about how to use this annotation, see Table 1.
    • Image Access Credential: Select the credential used for accessing the image repository. The default value is default-secret. You can use default-secret to access images in SWR Shared Edition. For details about default-secret, see default-secret.
    • (Optional) GPU: All is selected by default. The workload instance will be scheduled to the node of the specified GPU type.
  5. Configure the settings of the headless Service associated with the workload.
    A headless Service provides a fixed access domain name for every pod within a StatefulSet for mutual pod access. For details, see Headless Services.
  6. (Optional) Configure the settings of the Service associated with the workload.
    A Service provides external access for pods. With a static IP address, a Service forwards access traffic to pods and automatically balances load for these pods.
    You can also create a Service after creating a workload. For details about Services of different types, see Service Overview.
  7. (Optional) Configure advanced settings for the workload.
    Upgrade
    Specify the upgrade mode and parameters of the workload. Rolling upgrade and Replace upgrade are available. For details, see Upgrading and Rolling Back a Workload.
    Pod Management Policies
    For some distributed systems, the StatefulSet ordering guarantees are unnecessary and/or undesirable. These systems require only uniqueness and identifiers.
    • OrderedReady: This is the default policy. The StatefulSet will deploy, delete, or scale pods in order and one by one. It continues only after the previous pod is ready or deleted.
    • Parallel: The StatefulSet will create pods in parallel or delete all pods at once. Changes to the StatefulSets apply immediately on the pods.
    Scheduling
    Configure affinity and anti-affinity policies for flexible workload scheduling. Load affinity and node affinity are provided.
    • Load Affinity: Common load affinity policies are offered for quick load affinity deployment.
      • Not configured: No load affinity policy is configured.
      • Multi-AZ deployment preferred: Workload pods are preferentially scheduled to nodes in different AZs through pod anti-affinity.
      • Forcible multi-AZ deployment: Workload pods are forcibly scheduled to nodes in different AZs through pod anti-affinity (podAntiAffinity). If there are fewer AZs than pods, the extra pods will fail to run.
      • Customize affinity: Affinity and anti-affinity policies can be customized. For details, see Configuring Workload Affinity or Anti-affinity Scheduling (podAffinity or podAntiAffinity).
    • Node Affinity: Common node affinity policies are offered for quick load affinity deployment.
      • Not configured: No node affinity policy is configured.
      • Specify node: Workload pods can be deployed on specified nodes through node affinity (nodeAffinity). If no node is specified, the pods will be randomly scheduled based on the default scheduling policy of the cluster.
      • Specify node pool: Workload pods can be deployed in a specified node pool through node affinity (nodeAffinity). If no node pool is specified, the pods will be randomly scheduled based on the default scheduling policy of the cluster.
      • Customize affinity: Affinity and anti-affinity policies can be customized. For details, see Configuring Node Affinity Scheduling (nodeAffinity).
    Toleration
    Using both taints and tolerations allows (not forcibly) the pod to be scheduled to a node with the matching taints, and controls the pod eviction policies after the node where the pod is located is tainted. For details, see Configuring Tolerance Policies.
    Add labels or annotations for pods using key-value pairs. After the setting, click Confirm. For details about labels and annotations, see Configuring Labels and Annotations.
    DNS
    Configure a separate DNS policy for the workload. For details, see DNS Configuration.
    APM Settings
    Use Application Performance Management (APM) to provide more accurate problem analysis and locating for Java programs. For details, see Configuring APM Settings.
    Network Configuration
    • Pod ingress/egress bandwidth limit: You can set ingress and egress bandwidth limits for pods. For details, see Configuring QoS for a Pod.
    • Whether to enable the static IP address: available only for clusters that support this function. After this function is enabled, you can set the interval for reclaiming expired pod IP addresses. For details, see Configuring a Static IP Address for a Pod in a CCE Turbo Cluster.
    • Whether to enable a specified container network configuration: available only for clusters that support this function. After you enable a specified container network configuration, the workload will use the subnet and security group defined in the configuration. For details, see Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration.
    • Specify the container network configuration name: Only the custom container network configuration whose associated resource type is workload can be selected.
  8. Click Create Workload in the lower right corner. After a period of time, the workload enters the Running state.
In this example, a Nginx workload is used and the EVS volume is dynamically mounted to it using the volumeClaimTemplates field.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create and edit the nginx-statefulset.yaml file.
    nginx-statefulset.yaml is an example file name, and you can change it as required.
    vi nginx-statefulset.yaml
    The below content shows only an example. For details about StatefulSets, see the Kubernetes official documentation.
    apiVersion: apps/v1
    kind: StatefulSet
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
              resources:
                requests:
                  cpu: 250m
                  memory: 512Mi
                limits:
                  cpu: 250m
                  memory: 512Mi
              volumeMounts:
                - name: test
                  readOnly: false
                  mountPath: /usr/share/nginx/html
                  subPath: ''
          imagePullSecrets:
            - name: default-secret
          dnsPolicy: ClusterFirst
          volumes: []
      serviceName: nginx-svc
      replicas: 2
      volumeClaimTemplates:  # Dynamically mounts the EVS volume to the workload.
        - apiVersion: v1
          kind: PersistentVolumeClaim
            namespace: default
            annotations:
              everest.io/disk-volume-type: SAS  # SAS EVS volume type.
            labels:
              failure-domain.beta.kubernetes.io/region: ap-southeast-1  # region where the EVS volume is created.
              failure-domain.beta.kubernetes.io/zone: ap-southeast-1a   # AZ where the EVS volume is created. It must be the same as the AZ of the node.
            accessModes:
              - ReadWriteOnce  # The value must be ReadWriteOnce for the EVS volume.
            resources:
              requests:
                storage: 10Gi
            storageClassName: csi-disk # StorageClass name. The value is csi-disk for the EVS volume.
      updateStrategy:
        type: RollingUpdate
    Create the nginx-headless.yaml file.
    vi nginx-headless.yaml
    File content:
    apiVersion: v1
    kind: Service
      namespace: default
      labels:
        app: nginx
      selector:
        app: nginx
        version: v1
      clusterIP: None
      ports:
        - name: nginx
          targetPort: 80
          nodePort: 0
          port: 80
          protocol: TCP
      type: ClusterIP
  3. Create a workload.
    kubectl create -f nginx-statefulset.yaml
    If information similar to the following is displayed, the StatefulSet has been created:
    statefulset.apps/nginx created
    Create a headless Service.
    kubectl create -f nginx-headless.yaml
    If the following information is displayed, the headless service has been successfully created.
    service/nginx-svc created
  4. If the workload will be accessed through a ClusterIP or NodePort Service, configure the access mode. For details, see Networking.
Helpful Links
