Updated on 2026-09-21 GMT+08:00
Configuring Tolerance Policies
Tolerations allow the scheduler to schedule pods to nodes with target taints. Tolerances work with node taints. Each node allows one or more taints. If no tolerance is configured for a pod, the scheduler will schedule the pod based on node taint policies to prevent the pod from being scheduled to an inappropriate node. For more examples, see Taints and Tolerations.
The following table shows how taint policies and tolerations affect pod running.
Taint Policy
No Taint Toleration Configured
NoExecute
  • Pods running on the node will be evicted immediately.
  • Inactive pods will not be scheduled to the node.
  • If the tolerance time window tolerationSeconds is not specified, pods can always run on this node.
  • If the tolerance time window tolerationSeconds is specified, pods still run on the node with taints within the time window. After the time expires, the pods will be evicted.
PreferNoSchedule
  • Pods running on the node will not be evicted.
  • Inactive pods will not be scheduled to the node to the best extent.
Pods can always run on this node.
NoSchedule
Configuring Tolerance Policies on the Console
  2. When creating a workload, click Toleration in the Advanced Settings area.
  3. Add a taint tolerance policy.
    Table 1 Parameters for configuring a taint tolerance policy
    Taint key
    Key of a node taint
    Operator
    • Equal: Exact match for the specified taint key (mandatory) and taint value. If the taint value is left blank, all taints with the key the same as the specified taint key will be matched.
    • Exists: matches only the nodes with the specified taint key. In this case, the taint value cannot be specified. If the taint key is left blank, all taints will be tolerated.
    Taint value
    Taint value specified if the operator is set to Equal.
    Taint Policy
    • All: All taint policies are matched.
    • NoSchedule: Only the NoSchedule taint is matched.
    • PreferNoSchedule: Only the PreferNoSchedule taint is matched.
    • NoExecute: Only the NoExecute taint is matched.
    Toleration Time Window
    tolerationSeconds, which is configurable only when Taint Policy is set to NoExecute.
    Within the tolerance time window, pods still run on the node with taints. After the time expires, the pods will be evicted.
Default Tolerance Policy
Kubernetes automatically adds tolerances for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints to pods, and sets the tolerance time window (tolerationSeconds) to 300s. These default toleration policies indicate that when either of the preceding taints is applied to a node running these pods, the pods can remain on that node for 5 minutes.
tolerations:
  - key: node.kubernetes.io/not-ready
    operator: Exists
    effect: NoExecute
    tolerationSeconds: 300
  - key: node.kubernetes.io/unreachable
    operator: Exists
    effect: NoExecute
Helpful Links
