Updated on 2026-08-13 GMT+08:00
Cluster Secrets
By default, CCE creates the following secrets in each namespace:
  • default-secret
  • paas.elb
  • default-token-xxxxx (xxxxx is a random number.)
The functions of these secrets are described as follows.
default-secret
The type of default-secret is kubernetes.io/dockerconfigjson. The data is the credential for logging in to the SWR image repository and is used to pull images from SWR. To pull an image from SWR when creating a workload on CCE, set imagePullSecrets to default-secret.
apiVersion: v1
kind: Pod
  containers:
  - image: nginx:alpine
    resources:
      limits:
        cpu: 100m
        memory: 200Mi
      requests:
        cpu: 100m
        memory: 200Mi
  imagePullSecrets:
  - name: default-secret
The data of default-secret is updated periodically, and the current data will expire after a certain period of time. You can run the describe command to view the expiration time in default-secret.
Use default-secret directly instead of copying the secret content to create a new one. The credential in the copied secret will expire and the image cannot be pulled.
kubectl describe secret default-secret
Command output:
Namespace:    default
Labels:       secret-generated-by=cce
Annotations:  swr-auth-may-expires-at: 2021-11-26 20:55:31.380909 +0000 UTC
Type:  kubernetes.io/dockerconfigjson
Data
.dockerconfigjson:  347 bytes
paas.elb
The paas.elb data stores a temporary AK/SK that is used when a node is created or a load balancer is automatically created. The paas.elb data is updated periodically and has a specific time limit before it expires.
In practice, you will not directly use paas.elb. Do not delete it, as doing so will result in the failure of creating a node or load balancer.
default-token-xxxxx
By default, Kubernetes creates a service account named default for each namespace. default-token-xxxxx is the key of the service account, and xxxxx is a random number.
In clusters v1.25 or later, a secret is not created automatically for each ServiceAccount. For details, see Service Account Token Security Improvement.
  1. Check the service account in the cluster.
    kubectl get sa
    Command output:
    NAME     SECRETS   AGE
    default  1         30d
  2. Run the following command to view the secret:
    kubectl describe sa default
    Command output:
    Namespace:           default
    Labels:              <none>
    Annotations:         <none>
    Image pull secrets:  <none>
    Mountable secrets:   default-token-xxxxx
    Tokens:              default-token-xxxxx
    Events:              <none>
Helpful Links
CCE has strengthened credential source security in clusters v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, and later. These clusters no longer rely on temporary credentials statically stored as secrets. You can disable the temporary credentials to improve cluster security. For details, see Disabling a Statically Stored Temporary Credential in a Cluster.
