Configuring Time Zone Synchronization
When creating a workload, you can enable time zone synchronization, so that the container can use the same time zone as the node.
You can use either of the following ways.
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
- In the Basic Info area of the Create Workload page, enable Time Zone Synchronization so that the same time zone will be used for both the container and node. Figure 1 Enabling time zone synchronization
- Complete other settings and click Create Workload.
- Click Data Storage in the Container Information area under Container Settings and choose Add Volume > hostPath. Configure the following parameters:
- hostPath: /etc/localtime
- Mount Path: /etc/localtime
- Permission: Read-only
Figure 2 Mounting the time zone configuration file
To use time zone synchronization, you need to mount /etc/localtime on the node to /etc/localtime in the container. In this way, the node and container use the same time zone configuration file.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a file named nginx-deployment.yaml. The name is only an example. You can rename the file as needed.
vi nginx-deployment.yaml
Example YAML:
kind: Deployment apiVersion: apps/v1 metadata: name: test namespace: default spec: replicas: 2 selector: matchLabels: app: test template: metadata: labels: app: test spec: volumes: - name: date-config # Custom volume name. hostPath: # Mount the time zone configuration file of the node in hostPath mode. path: /etc/localtime # Path of the time zone configuration file on the node. containers: - name: container-0 image: 'nginx:alpine' volumeMounts: - name: date-config # Mount the volume to the container. The volume name must be the same as that you defined. readOnly: true # Mount the volume as read-only. mountPath: /etc/localtime # The path in the container where the node's time zone configuration file is mounted. imagePullPolicy: IfNotPresent imagePullSecrets: - name: default-secretPress Esc and enter :wq to save the file and exit.
- Create the workload.
kubectl create -f nginx-deployment.yaml
Verifying that the Container and Node Are in the Same Time Zone
- Log in to the node and obtain the time zone.
date -R
Information similar to the following is displayed:
Sat, 12 Apr 2025 16:58:47 +0800
- Check whether the time zone of the container is the same as that of the node.
Obtain the pod name.
kubectl get pod
Access the container. In the command, <pod_name> specifies the pod name obtained in the previous step.
kubectl exec -it <pod_name> -- /bin/bashObtain the time zone of the container.
date -R
Information similar to the following is displayed, indicating that the time zone of the container is the same as that of the node:
Sat, 12 Apr 2025 16:59:23 +0800
