Updated on 2026-09-21 GMT+08:00
Configuring an Image Pull Policy
When a workload is created, the container image is pulled from the image repository to the node. The image is also pulled when the workload is restarted or upgraded.
By default, imagePullPolicy is set to IfNotPresent, indicating that if the image exists on the node, the existing image is used. If the image does not exist on the node, the image is pulled from the image repository.
The image pull policy can also be set to Always, indicating that the image is pulled from the image repository and overwrites the image on the node regardless of whether the image exists on the node.
apiVersion: v1
kind: Pod
  containers:
  - image: nginx:alpine
    resources:
      limits:
        cpu: 100m
        memory: 200Mi
      requests:
        cpu: 100m
        memory: 200Mi
    imagePullPolicy: Always
  imagePullSecrets:
  - name: default-secret
An image pull policy can also be configured on the CCE console. When creating a workload, configure Pull Policy. If Always is selected, images are always pulled. If Always is not selected, images are pulled as needed.
Figure 1 Configuring an update policy
If you do not update the tag when creating an image, CCE considers that the image with that tag already exists on the node. Consequently, if the pull policy is set to IfNotPresent, CCE will not pull the image again. You are advised to use a new tag for each image creation.
