Dynamically Mounting an EVS Disk to a StatefulSet
Dynamic mounting is available only for creating a StatefulSet. It is implemented through a PVC template (the volumeClaimTemplates field) and depends on dynamic creation of PVs through StorageClass. In this mode, each pod in a StatefulSet is associated with a unique PVC and PV. After a pod is rescheduled, the original data can still be mounted to it based on the PVC name. In the common mounting mode for a Deployment, if ReadWriteMany is supported, multiple pods of the Deployment will be mounted to the same underlying storage.
When updating a StatefulSet in Kubernetes, it is not allowed to add or delete the volumeClaimTemplates field. This field can only be configured during the creation of the StatefulSet.
Working Principles
- Workload creation or scale-out
When a StatefulSet is created or scaled out, a dedicated PVC is created for each pod (for example, web-0) based on the volumeClaimTemplates template. The PVC is named in the format: <template-name>-<StatefulSet-name>-<pod-sequence-number>. Parameters such as the storage class and resource request in the template are reused, and Kubernetes automatically binds the matched PV to the PVC. In this case, each pod has a PVC bound. The storage resources are configured when the pod is initialized, ensuring that each pod has independent and persistent storage.
- Scale-in
When a StatefulSet is scaled in (for example, the StatefulSet is scaled from three pods to two pods), Kubernetes deletes only the pod with the largest sequence number (for example, web-2). The associated PVC and PV are not automatically deleted, which means that the storage resources are retained. Even if the pod is removed, the associated PVC still exists, and data is not lost. This provides a data basis for subsequent pod restoration.
- Scale-out or fault recovery again
If a StatefulSet is scaled out again (for example, the StatefulSet is scaled from two pods to three instances) or the fault is rectified, the StatefulSet re-creates the web-2 pod and preferentially associates the retained PVC with the same name (for example, data-web-2). The original PV is directly mounted to the new pod. You do not need to reconfigure the storage, and data is fully reused. This process ensures that the expanded pods can still connect to the original storage resources, ensuring data consistency of stateful applications.
- You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
CCE allows you to dynamically mount EVS volumes to workloads using the console or kubectl.
- Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
- Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > VCT.
- Click Create PVC. On the slide-out panel, configure PVC parameters. Click Create.
PVC Type
In this example, select EVS.
PVC Name
Enter the name of the PVC. After a PVC is created, a suffix is automatically added based on the number of pods. The format is <Custom PVC name>-<Serial number>, for example, example-0.
Creation Method
You can select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
Storage Classes
The default StorageClasses for EVS disks are csi-disk and csi-disk-topology.
NOTE:If you use the csi-disk (EVS) StorageClass, a PVC and PV will be created immediately. The EVS disk is created with the PV, and then the PVC is bound to the PV.
If you use the csi-disk-topology (EVS created with a delay) StorageClass, a PV will not be immediately created when a PVC is created. Instead, the pods that will be associated with the PVC are scheduled first, and then the EVS disk and PV are created, and finally the PV is bound to the PVC.
You can customize a StorageClass and configure its reclaim policy and binding mode. For details, see Basic StorageClass Settings.
(Optional) Storage Volume Name Prefix
Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "Storage volume name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
AZ
Select the AZ of the EVS disk. The AZ must be the same as that of the cluster node.
NOTE:An EVS disk can only be mounted to a node in the same AZ. After an EVS disk is created, its AZ cannot be changed.
Disk Type
Select an EVS disk type. EVS disk types vary depending on regions. Obtain the available EVS types on the console.
NOTE:If the Everest version is 2.4.4 or later, general-purpose SSD V2 EVS disks are supported. General Purpose SSD V2 disks allow you to specify the disk IOPS and throughput. For details, see EVS performance data.
Capacity (GiB)
Capacity of the requested storage volume.
Billing Mode
Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.16 or later is installed in the cluster. Options:- Yearly/Monthly
Resources will be billed on a yearly/monthly basis. To use the yearly/monthly billing mode, you need to select the required duration, and auto-renewal is enabled by default. Your order will automatically renew on a monthly or yearly basis, depending on whether you purchased by month or by year.
- Pay-per-use
Resources will be billed based on usage duration. You can provision or delete resources at any time.
Access Mode
EVS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode. For details, see Volume Access Modes.
Encryption
Configure whether to encrypt the underlying storage. If you select Enable, select the target key or enter the key ID. Before using encryption, check whether the region where the EVS disk is located supports disk encryption.
Enterprise Project
An enterprise project manages multiple resources by category. Resources and projects across cloud service regions can be grouped into a single enterprise project. For example, an enterprise can classify resources by department or project group, and place relevant resources in the same enterprise project for unified management.
This parameter is available only for enterprise accounts with enterprise projects enabled.
Resource Tag
You can add resource tags to classify resources. This function is supported only when the Everest version in the cluster is 2.1.39 or later.
You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
CCE automatically creates system tags CCE-Cluster-ID=<cluster-ID>, CCE-Cluster-Name=<cluster-name>, and CCE-Namespace=<namespace-name>. These tags cannot be modified.
NOTE:After a dynamic PV of the EVS type is created, the resource tags cannot be updated on the CCE console. To update these resource tags, go to the EVS console.
- Yearly/Monthly
- Enter the path to which the volume is mounted.
Table 1 Mounting a storage volume Parameter
Mount Path
Enter a mount path, for example, /tmp.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
Permission
- Read-only: You can only read the data in the mounted volumes.
- Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the EVS disk.
- Dynamically mount and use storage volumes. For details about other parameters, see Creating a StatefulSet. After the configuration, click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
- Use kubectl to access the cluster.
- Create a file named statefulset-evs.yaml. In this example, the EVS volume is mounted to the /data path.
apiVersion: apps/v1 kind: StatefulSet metadata: name: statefulset-evs namespace: default spec: selector: matchLabels: app: statefulset-evs template: metadata: labels: app: statefulset-evs spec: containers: - name: container-1 image: nginx:latest # Replace it with the correct image path for your application. volumeMounts: - name: pvc-disk # The value must be the same as that in the volumeClaimTemplates field. mountPath: /data # Location where the storage volume is mounted imagePullSecrets: - name: default-secret serviceName: statefulset-evs # Headless Service name replicas: 2 volumeClaimTemplates: - apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-disk namespace: default annotations: everest.io/disk-volume-type: SAS # EVS disk type everest.io/crypt-key-id: <your_key_id> # (Optional) Encryption key ID. Mandatory for an encrypted disk. everest.io/enterprise-project-id: <your_enterprise_project_id> # (Optional) Enterprise project ID of the new EVS disk everest.io/disk-volume-tags: '{"key1":"value1","key2":"value2"}' # (Optional) Custom resource tags everest.io/disk-iops: '3000' # (Optional) IOPS of only a GPSSD2 EVS disk everest.io/disk-throughput: '125' # (Optional) Throughput of only a GPSSD2 EVS disk everest.io/csi.charging-mode: prePaid # Mandatory if the billing mode is set to Yearly/Monthly everest.io/csi.period-type: month # Mandatory if the billing mode is set to Yearly/Monthly. month indicates that resources will be billed on a monthly basis. everest.io/csi.period-num: '1' # Mandatory if the billing mode is set to Yearly/Monthly. '1' indicates that the required duration is one month. everest.io/csi.volume-name-prefix: test # (Optional) Volume name prefix of the automatically-created underlying storage labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce # The value must be ReadWriteOnce for EVS disks. resources: requests: storage: 10Gi # EVS disk capacity, ranging from 1 to 32768 storageClassName: csi-disk # The StorageClass is EVS. --- apiVersion: v1 kind: Service metadata: name: statefulset-evs # Headless Service name namespace: default labels: app: statefulset-evs spec: selector: app: statefulset-evs clusterIP: None ports: - name: statefulset-evs targetPort: 80 nodePort: 0 port: 80 protocol: TCP type: ClusterIPTable 2 Key parameters Parameter
Mandatory
Yes
Region where the cluster is located.
For details about its value, see Regions and Endpoints.
Yes
AZ where the EVS volume is created. It must be the same as the AZ planned for the workload.
Yes
EVS disk type. All letters are in uppercase.- SAS: High I/O
- SSD: Ultra-high I/O
- GPSSD: General Purpose SSD
- ESSD: Extreme SSD
- GPSSD2: General Purpose SSD v2, which is supported when the Everest version is 2.4.4 or later and the everest.io/disk-iops and everest.io/disk-throughput annotations are configured
No
Preconfigured IOPS, which is supported only by General Purpose SSD v2 EVS disks.- The IOPS of General Purpose SSD v2 disks ranges from 3000 to 128000, and the maximum value is 500 times the capacity (GiB).
If the IOPS of General Purpose SSD v2 disks is greater than 3000, extra IOPS will be billed. For details, see Price Calculator.
No
Preconfigured throughput, which is supported only by General Purpose SSD v2 EVS disks.
The value ranges from 125 MiB/s to 1,000 MiB/s. The maximum value is a quarter of the IOPS.
If the throughput is greater than 125 MiB/s, extra throughput will be billed. For details, see Price Calculator.
No
Mandatory when the EVS disk is encrypted. Enter the encryption key ID selected during EVS disk creation.
To obtain an encryption key ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab, copy the value of KMS Key ID in the Configuration Information area.
No
The ID of the enterprise project in which the EVS disk is created. It is applicable only to enterprise accounts with enterprise projects enabled. For more details, see Enterprise Center Overview.
To obtain an enterprise project ID, log in to the EPS console, click the name of the target enterprise project, and copy the enterprise project ID.
No
This parameter is mandatory when the yearly/monthly billing mode is used. If this parameter is not specified, the pay-per-use billing mode will be used by default. This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.161 or later is installed in the cluster.
Options:
- prePaid: EVS disks are billed on a yearly/monthly basis, and auto-renewal is enabled by default. Your order will automatically renew on a monthly or yearly basis, depending on whether you purchased by month or by year.
- postPaid: EVS disks are billed on a pay-per-use basis.
NOTE:- Before creating an EVS disk billed on a yearly/monthly basis, you need to grant the payment permission (bss:order:pay) to cce_cluster_agency. Use your tenant account on the CCE console to perform this operation for the first time. After confirmation, CCE will automatically authorize the agency.
- When creating yearly/monthly EVS disks in batches, limit the number of disks to 300 or fewer per batch if there are requirements on overall provisioning time. Creating more than 300 EVS disks per batch may lead to a significant increase in total provisioning time.
No
Billing cycle, which is mandatory only when the yearly/monthly billing mode is used. Options:
- month: Resources are billed on a monthly basis.
- year: Resources are billed on a yearly basis.
No
Required duration, which is mandatory only when the yearly/monthly billing mode is used. Options:
- For monthly billing, the value of this parameter ranges from 1 to 9.
- For yearly billing, the value of this parameter is 1.
No
(Optional) This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
storage
Yes
Requested PVC capacity, in Gi. The value is an integer ranging from 1 to 32768.
If storage is set to a decimal, the value will be rounded up for the EVS disk. For example, if storage is set to 10.1Gi, an 11-GiB EVS disk will be created.
storageClassName
Yes
StorageClass name, which is csi-disk for an EVS disk.
- Run the following command to create a workload to which the EVS volume is mounted:
kubectl apply -f statefulset-evs.yaml
- View the deployed application and EVS volume files.
- Run the following command to view the created pod:
kubectl get pod | grep statefulset-evs
Expected output:statefulset-evs-0 1/1 Running 0 45s statefulset-evs-1 1/1 Running 0 28s
- Run the following command to check whether the EVS volume has been mounted to the /data path:
kubectl exec statefulset-evs-0 -- df | grep data
Expected output:
/dev/sdd 10255636 36888 10202364 0% /data
- Run the following command to check the files in the /data path:
kubectl exec statefulset-evs-0 -- ls /data
Expected output:
lost+found
- Run the following command to create a file named static in the /data path:
kubectl exec statefulset-evs-0 -- touch /data/static
Expected output:
lost+found static
- Run the following command to delete the pod named statefulset-evs-0:
kubectl delete pod statefulset-evs-0
Expected output:
pod "statefulset-evs-0" deleted
- After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
Expected output:
lost+found static
The static file is retained, indicating that the data in the EVS volume can be stored persistently.
Related Operations
| Operation | Description | Procedure |
| Expanding the capacity of an EVS disk | Quickly expand the capacity of a mounted EVS volume on the CCE console. Only the capacity of pay-per-use EVS disks can be expanded on the CCE console. To expand the capacity of yearly/monthly EVS disks, click the volume name to go to the EVS console. |
| Viewing events | View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
| Viewing a YAML file | View, copy, or download the YAML file of a PVC or PV. |
| Editing Reclaim Policy | Modify the reclaim policy of a PV. |
| Synchronizing PVC capacity | When the underlying storage outgrows the PVC, resize the PVC capacity on the CCE console to match the new size. |
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
