Updated on 2026-09-21 GMT+08:00
Collecting Audit Logs
CCE allows you to collect the logs of master nodes. On the Logging page, choose Kubernetes Audit Logs and determine whether to report Kubernetes audit logs to LTS.
  • The cluster version must be v1.21.7-r0 or later, v1.23.5-r0 or later, or 1.25.
  • The LTS resource quota must be sufficient. For details about the default LTS quota, see Basic Resources.
Audit Logs
Table 1 Audit logs
Log Type
Component
Log Stream
audit
audit-{{clusterID}}
An audit log is a chronological record of user operations on Kubernetes APIs and control plane activities for security.
By default, audit logs do not record resource query (get) and update (update) operations in the kube-system namespace. You can enable kube-system-audit to record audit logs. For details, see Modifying Cluster Configurations.
Enabling Kubernetes Audit Logging for a Cluster
Enabling Audit Logging During Cluster Creation
  1. Log in to the CCE console.
  2. Click Buy Cluster. Configure the parameters and click Next: Select Add-on.
  3. On the displayed page, select Cloud Native Log Collection and click Next: Configure Add-on.
  4. On the displayed page, select Kubernetes Audit Logs for Cloud Native Log Collection.
    Figure 1 Enabling audit logging during cluster creation
  5. Click Next: Confirm Settings.
Enabling Audit Logging for an Existing Cluster
  2. In the navigation pane, choose Logging.
  3. Click the Kubernetes Audit Logs tab, select the audit component, and click Enable.
    Figure 2 Enabling audit logging for an existing cluster
Viewing Kubernetes Audit Logs of a Cluster
Viewing Kubernetes Audit Logs of the Target Cluster on the CCE Console
  3. Click the Kubernetes Audit Logs tab to view the audit logs of the cluster. For details about related operations, see LTS User Guide.
    Figure 3 Viewing Kubernetes Audit Logs of the Target Cluster on the CCE Console
Viewing Kubernetes Audit Logs of the Target Cluster on the LTS Console
  1. Log in to the LTS console and choose Log Management.
  2. Search for the log group by cluster ID and click the log group name to view the log streams. For details, see Log Tank Service User Guide.
    Figure 4 Viewing Kubernetes audit logs on the LTS console
Disabling Kubernetes Audit Logging
  3. Click the Kubernetes Audit Logs tab. Click Configure Control Plane Audit Logging in the upper right corner and determine whether to enable control plane audit logging.
    Figure 5 Disabling audit logging
  4. Deselect audit and click OK.
    After you disable audit logging, logs are no longer written to the original log stream, but the existing logs will not be deleted and expenditures may be incurred for this.
