Agency Permissions
O&M modules work closely with cloud services for cluster monitoring, alarm reporting, and notification. When you access the O&M modules for the first time, the system will request permissions to access the cloud services in the region where you run your applications.
To minimize authorization, CCE fine-grained permissions are optimized. The permissions defined by system policies are now defined using API actions. (Each API has one API action.) If you have authorized the cloud services, you can optimize the permissions in one click.
- cia_admin_trust
This agency is used to delegate the permissions required by the O&M modules to access other cloud services.
To use O&M modules in multiple regions, you need to apply for the Tenant Guest, CCE Administrator, and SWR Administrator permissions in each region. (Go to the IAM console, choose Agencies, and click cia_admin_trust to view the authorization records in each region.)
 - aom_admin_trust
For details about this agency, see Authorizing AOM to Access Other Cloud Services.
    O&M modules may fail to run as expected if the required permissions are not granted. When using O&M modules, do not delete or modify cia_admin_trust and aom_admin_trust.
Permissions Before Optimization
         Granted To  |
         Policy/Role  |
         Description  |
         CCE  |
         IAM ReadOnlyAccess  |
         IAM users need to be able to access Monitoring Center and Alarm Center.  |
         CCE  |
         Tenant Guest  |
         Monitoring Center and Alarm Center check the configurations of global resources (for example OBS or DNS) associated with clusters to identify invalid or inappropriate configurations.  |
         CCE  |
         CCE Administrator  |
         Monitoring Center and Alarm Center need to be able to access CCE to obtain information about clusters, nodes, workloads, and other resources, so that they can help ensure resource health.  |
         CCE  |
         SWR Administrator  |
         Monitoring Center and Alarm Center need to be able to access SWR to obtain image information.  |
         CCE  |
         SMN Administrator  |
         Monitoring Center and Alarm Center need to be able to access SMN to obtain contact groups.  |
         CCE  |
         AOM Administrator  |
         Monitoring Center and Alarm Center need to be able to access AOM to obtain metrics.  |
         CCE  |
         LTS Administrator  |
         Monitoring Center and Alarm Center need to be able to access LTS to obtain logs.  |
         Granted To  |
         Policy/Role  |
         Description  |
         AOM  |
         DMS UserAccess  |
         AOM obtains subscription data from DMS.  |
         AOM  |
         ECS CommonOperations  |
         AOM obtains system metrics and logs using UniAgents and ICAgents installed on ECSs.  |
         AOM  |
         CES ReadOnlyAccess  |
         AOM synchronizes metrics from Cloud Eye.  |
         AOM  |
         CCE FullAccess  |
         AOM synchronizes container metrics from CCE.  |
         AOM  |
         RMS ReadOnlyAccess  |
         AOM CMDB manages cloud service instances.  |
         AOM  |
         ECS ReadOnlyAccess  |
         AOM  |
         LTS FullAccess  |
         AOM obtains logs from LTS.  |
         AOM  |
         CCI FullAccess  |
         AOM synchronizes container metrics from CCI.  |
Permissions After Optimization
         Policy Name  |
         Policy Type  |
         Policy Scope  |
         Permission Set  |
         Description  |
         CCE Administrator  |
         System-defined policy  |
         Project  |
         cce:*:*  |
         CCE administrator permissions  |
         CIAMonitorProjectPolicy  |
         Custom policy  |
         Project  |
         cce:cluster:get  |
         Obtains details about a cluster.  |
         cce:cluster:list  |
         Lists all clusters.  |
         cce:addonInstance:list  |
         Lists all add-on instances.  |
         cce:addonInstance:create  |
         Creates an add-on instance.  |
         cce:addonInstance:delete  |
         Deletes an add-on instance.  |
         cce:addonInstance:update  |
         Updates an add-on instance.  |
         cce:node:get  |
         Obtains details about a node.  |
         cce:node:list  |
         Lists nodes.  |
         cce:nodepool:list  |
         Lists all node pools in a cluster.  |
         aom:metric:set  |
         Modifies monitoring configuration.  |
         aom:metric:get  |
         Queries details about a metric.  |
         aom:metric:list  |
         Lists metrics.  |
         aom:alarm:list  |
         Lists alarms.  |
         aom:alarm:put  |
         Clears AOM alarms.  |
         aom:actionRule:get  |
         Queries an alarm linkage rule by ID.  |
         aom:actionRule:list  |
         Lists alarm linkage rules.  |
         aom:actionRule:create  |
         Creates an alarm linkage rule.  |
         aom:actionRule:update  |
         Updates an alarm linkage rule.  |
         aom:actionRule:delete  |
         Deletes an alarm linkage rule.  |
         aom:alarmRule:create  |
         Adds a threshold rule.  |
         aom:alarmRule:list  |
         Lists alarm rules.  |
         aom:alarmRule:delete  |
         Delete a threshold rule.  |
         aom:agency:get  |
         Queries AOM authorization.  |
         lts:groups:get  |
         Queries a specified log group.  |
         lts:groups:list  |
         Lists log groups.  |
         lts:groups:create  |
         Creates a log group.  |
         lts:logs:list  |
         Lists logs.  |
         lts:topics:get  |
         Queries a specified log topic.  |
         lts:topics:create  |
         Creates a log topic.  |
         lts:topics:put  |
         Updates a log topic.  |
         smn:topic:list  |
         Lists topics.  |
         smn:topic:update  |
         Updates a topic, including adding subscriptions to and deleting subscriptions from a topic.  |
         smn:topic:delete  |
         Deletes a topic.  |
         smn:topic:create  |
         Creates a topic.  |
         vpc:securityGroups:get  |
         Queries security groups or details about a security group.  |
         vpc:vpcs:get  |
         Queries details about a VPC.  |
         vpc:subnets:get  |
         Queries subnets or details about a subnet.  |
         vpc:vpcs:list  |
         Lists VPCs.  |
         vpcep:endpoints:list  |
         Lists VPC endpoints.  |
         evs:quotas:get  |
         Queries EVS disk quotas.  |
         ecs:cloudServerQuotas:get  |
         Queries tenant quotas.  |
         apm:icmgr:get  |
         Obtains AOM 2.0 permissions.  |
         apm:icmgr:create  |
         Grants AOM 2.0 permissions.  |
         Policy Name  |
         Policy Type  |
         Policy Scope  |
         Permission Set  |
         Description  |
         AOM Global Access  |
         Custom policy  |
         Global  |
         rms:*:list  |
         Lists RMS resources.  |
         rms:*:get  |
         Queries details about an RMS resource.  |
         rms:resources:listTagsForResource  |
         Lists resource tags.  |
         rms:resources:listTags  |
         Lists project tags.  |
         rms:resources:listResourcesByTag  |
         List resource instances.  |
         AOM UserAccess  |
         Custom policy  |
         Project  |
         lts:topics:*  |
         Full permissions for performing operations on log topics  |
         lts:groups:*  |
         Full permissions for performing operations on log groups  |
         aom:metric:*  |
         Full permissions for performing operations on a metric (AOM)  |
         aom:cmdbSubApplication:*  |
         Full permissions for performing operations on a sub-application (AOM)  |
         aom:cmdbResources:*  |
         Full permissions for performing operations on resources (AOM)  |
         aom:cmdbEnvironment:*  |
         Full permissions for performing operations on the environment (AOM)  |
         aom:cmdbComponent:*  |
         Full permissions for performing operations on a component (AOM)  |
         aom:cmdbApplication:*  |
         Full permissions for performing operations on an application (AOM)  |
         ecs:cloudServers:showServer  |
         Queries details about an ECS.  |
         ecs:cloudServers:list  |
         Lists ECSs.  |
         dms:instance:get  |
         Queries details about a DMS instance.  |
         ces:metrics:list  |
         Lists metrics (Cloud Eye).  |
         ces:metricData:list  |
         Queries metrics (Cloud Eye).  |
         cci:namespace:list  |
         Lists all namespaces.  |
         cce:cluster:list  |
         cce:cluster:get  |
         cce:node:list  |
         Lists nodes.  |
         cce:node:get  |
         apm:icmgr:*  |
         Full permissions for performing operations on the APM collection component  |
         lts:*:*  |
         Full permissions for performing operations on LTS logs  |
         aom:*:list  |
         Lists AOM instances.  |
