Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a PV from an Existing OBS Bucket
CCE allows you to use an existing OBS bucket to create a PersistentVolume (PV). You can create a PersistentVolumeClaim (PVC) and bind it to the PV.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Log in to the OBS console, create an OBS bucket, and record the bucket name and storage class.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create two YAML files for creating the PV and PVC. Assume that the file names are pv-obs-example.yaml and pvc-obs-example.yaml.
    touch pv-obs-example.yaml pvc-obs-example.yaml
    Kubernetes Cluster Version
    YAML Example
    1.11 ≤ K8s version ≤ 1.13
    Clusters from v1.11 to v1.13
    Example YAML
    K8s version = 1.9
    Clusters of v1.9
    Example YAML
    • Example YAML file for the PV:
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: flexvolume-huawei.com/fuxiobs
        accessModes:
        - ReadWriteMany
        capacity:
          storage: 1Gi
        claimRef:
          apiVersion: v1
          kind: PersistentVolumeClaim
          namespace: default
        flexVolume:
          driver: huawei.com/fuxiobs
          fsType: obs
          options:
            fsType: obs
            region: ap-southeast-1
            storage_class: STANDARD
            volumeID: test-obs
        persistentVolumeReclaimPolicy: Delete
        storageClassName: obs-standard
      Table 1 Key parameters
      driver
      Storage driver used to mount the volume. Set the driver to huawei.com/fuxiobs for the OBS volume.
      storage_class
      Storage class, including STANDARD (standard bucket) and STANDARD_IA (infrequent access bucket).
      region
      Region where the cluster is located.
      volumeID
      OBS bucket name.
      To obtain the name, log in to the CCE console, choose Resource Management > Storage, click the PVC name in the OBS tab page, and copy the PV name on the PV Details tab page.
      storage
      Storage capacity, in Gi. The value is fixed at 1Gi.
      storageClassName
      Storage class supported by OBS, including obs-standard (standard bucket) and obs-standard-ia (infrequent access bucket).
      spec.claimRef.apiVersion
      The value is fixed at v1.
      spec.claimRef.kind
      The value is fixed at PersistentVolumeClaim.
      spec.claimRef.name
      The value is the same as the name of the PVC created in the next step.
      spec.claimRef.namespace
      The value is the same as the namespace of the PVC created in the next step.
    • Example YAML file for the PVC:
      apiVersion: v1
        annotations:
          volume.beta.kubernetes.io/storage-class: obs-standard
          volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxiobs
        namespace: default
        accessModes:
        - ReadWriteMany
        resources:
          requests:
            storage: 1Gi
        volumeName: pv-obs-example
      Table 2 Key parameters
      Storage class supported by OBS, including obs-standard and obs-standard-ia.
      Must be set to flexvolume-huawei.com/fuxiobs.
      volumeName
      Name of the PV.
      storage
    Clusters of v1.9
      apiVersion: v1
        namespace: default
        accessModes:
        - ReadWriteMany
        capacity:
          storage: 1Gi
        flexVolume:
          fsType: obs
          options:
            fsType: obs
            kubernetes.io/namespace: default
            volumeID: test-obs
      Table 3 Key parameters
      driver
      storage_class
      region
      volumeID
      OBS bucket name.
      storage
      storageClassName
      apiVersion: v1
        annotations:
        namespace: default
        accessModes:
        - ReadWriteMany
        resources:
          requests:
            storage: 1Gi
        volumeNamespace: default
      Table 4 Key parameters
      volumeName
      Name of the PV.
      storage
  4. Create a PV.
    kubectl create -f pv-obs-example.yaml
  5. Create a PVC.
    kubectl create -f pvc-obs-example.yaml
