Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a Deployment Mounted with an OBS Volume
After an OBS volume is created or imported to CCE, you can mount the volume to a workload.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following commands to configure the obs-deployment-example.yaml file, which is used to create a pod.
    touch obs-deployment-example.yaml
    vi obs-deployment-example.yaml
    Example of mounting an OBS volume to a Deployment (PVC-based, shared volume):
    apiVersion: apps/v1
    kind: Deployment
       name: obs-deployment-example                       # Workload name
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: obs-deployment-example
      template:
          labels:
          containers:
          - image: nginx
            volumeMounts:
            - mountPath: /tmp                       # Mount path
          restartPolicy: Always
          imagePullSecrets:
            - name: default-secret
          volumes:
          - name: pvc-obs-example
            persistentVolumeClaim:
              claimName: pvc-obs-auto-example       # PVC name
    Table 1 Key parameters
    name
    Name of the pod to be created.
    app
    Name of the application running in the pod.
    mountPath
    Mount path in the container.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
    Example of mounting an OBS volume to a StatefulSet (PVC template-based, dedicated volume):
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      generation: 1
      labels:
        appgroup: ''
      replicas: 1
      selector:
        matchLabels:
          app: deploy-obs-standard-in
      template:
          labels:
          annotations:
            metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
            pod.alpha.kubernetes.io/initialized: 'true'
          containers:
            - name: container-0
              image: 'nginx:1.12-alpine-perl'
              env:
                - name: PAAS_APP_NAME
                  value: deploy-obs-standard-in
                - name: PAAS_NAMESPACE
                  value: default
                - name: PAAS_PROJECT_ID
                  value: a2cd8e998dca42e98a41f596c636dbda
              resources: {}
              volumeMounts:
                - name: obs-bs-standard-mountoptionpvc
                  mountPath: /tmp
              terminationMessagePath: /dev/termination-log
              terminationMessagePolicy: File
              imagePullPolicy: IfNotPresent
          terminationGracePeriodSeconds: 30
          dnsPolicy: ClusterFirst
          securityContext: {}
          imagePullSecrets:
          affinity: {}
          schedulerName: default-scheduler
      volumeClaimTemplates:
        - metadata:
            annotations:
              volume.beta.kubernetes.io/storage-class: obs-standard
              volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxiobs
            accessModes:
              - ReadWriteMany
            resources:
              requests:
                storage: 1Gi
      serviceName: wwww
      podManagementPolicy: OrderedReady
      updateStrategy:
        type: RollingUpdate
      revisionHistoryLimit: 10
    Table 2 Key parameters
    name
    Name of the created workload.
    Image of the workload.
    mountPath
    Mount path in the container. In this example, the volume is mounted to the /tmp directory.
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
  3. Run the following command to create the pod:
    kubectl create -f obs-deployment-example.yaml
    After the creation is complete, choose Storage > OBS on the CCE console and click the PVC name. On the PVC details page, you can view the binding relationship between the OBS service and the PVC.
