(kubectl) Creating a StatefulSet Mounted with an OBS Volume
CCE allows you to use an existing OBS volume to create a StatefulSet through a PersistentVolumeClaim (PVC).
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Create an OBS volume by referring to Automatically Creating an OBS Volume Through kubectl and obtain the PVC name.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file for creating the workload. Assume that the file name is obs-statefulset-example.yaml.
touch obs-statefulset-example.yaml
vi obs-statefulset-example.yaml
Example YAML:
apiVersion: apps/v1 kind: StatefulSet metadata: name: obs-statefulset-example namespace: default spec: replicas: 1 selector: matchLabels: app: obs-statefulset-example serviceName: qwqq template: metadata: annotations: metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]' pod.alpha.kubernetes.io/initialized: "true" creationTimestamp: null labels: app: obs-statefulset-example spec: affinity: {} containers: image: nginx:latest imagePullPolicy: Always name: container-0 volumeMounts: - mountPath: /tmp name: pvc-obs-example imagePullSecrets: - name: default-secret volumes: - name: pvc-obs-example persistentVolumeClaim: claimName: cce-obs-demoTable 1 Key parameters Parameter
replicas
Number of pods.
name
Name of the created workload.
Image used by the workload.
mountPath
Mount path in the container.
serviceName
Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
claimName
Name of an existing PVC.
- Create the StatefulSet.
kubectl create -f obs-statefulset-example.yaml
