Help Center/ Cloud Container Engine/ User Guide/ O&M/ Logging/ Collecting Kubernetes Events
Updated on 2026-08-13 GMT+08:00
The Cloud Native Log Collection add-on of CCE works with LTS to collect and store Kubernetes events and works with AOM to generate alarms.
During Kubernetes event collection, the events generated in the following scenarios will not be collected:
  • Before otel-collector-event is started
  • During the active/standby otel-collector-event switchover
  • During configuration changes, for example, the following changes:
    • An event collection policy is created or deleted.
    • The blacklist and whitelist of Kubernetes events reported to AOM are modified.
  • During otel-collector-event listening interruption. You need to restart the interrupted listening.
Reporting Kubernetes Events to LTS
To enable Kubernetes event collection in different scenarios, take the following steps.
If logging has been enabled for a cluster but Kubernetes event collection has not been enabled, or the corresponding log collection policy has been deleted, you can manually create a log collection policy by taking the following steps:
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. In the navigation pane, choose Logging.
  3. In the upper right corner, click View Log Collection Policies.
    All log collection policies in the current cluster are displayed.
  4. Click Create Log Collection Policy. Then, select Kubernetes events and click OK.
    Figure 3 Creating a log collection policy
  5. (After the creation is complete, you can view logs on the Logging page.) Select the log stream configured in the log collection policy to view the events reported to LTS.
    Figure 4 Viewing event details
Reporting Kubernetes Events to AOM
In 1.3.2 and later versions, Cloud Native Log Collection reports all warning events and some normal events to AOM by default. The reported events can be used to configure alarms. If the cluster version is v1.19.16, v1.21.11, v1.23.9, v1.25.4, or later, after Cloud Native Log Collection is installed, events are reported to AOM by this add-on instead of the control plane component. After this add-on is uninstalled, events will not be reported to AOM.
After a Kubernetes event is generated, only the status at the time of the fault is recorded. Even if the fault is rectified, the event status is not automatically updated. Instead, the event is automatically deleted by the system after it expires. Therefore, AOM event alarms are not automatically cleared when the fault is rectified. They are cleared based on the timeout mechanism. By default, the system automatically clears expired alarms every 10 minutes.
Custom Event Reporting
If the reported events cannot meet requirements, you can modify the settings for the events.
  2. Click the cluster name to access the cluster console. In the navigation pane, choose Settings.
  3. Click the Monitoring tab. In the Log Settings area, modify the policy for reporting Kubernetes events to AOM. Configure event reporting. To check event names, see CCE Events.
    • Reporting of abnormal events
      • Enabled (default): All abnormal events except blacklisted ones are reported.
      • Disabled: No abnormal events are reported.
    • Reporting of common events: controls supplementary reporting of whitelisted events. (Note: System-default common events are not controlled by this setting.)
      • Enabled (default): Only whitelisted normal events are reported.
      • Disabled: No normal events are reported.
  4. Click Confirm configuration.
  1. Run the following command on the cluster to modify the event collection settings:
    kubectl edit logconfig -n kube-system default-event-aom
  2. Modify the event collection settings as required.
    apiVersion: logging.openvessel.io/v1
    kind: LogConfig
      annotations:
        helm.sh/resource-policy: keep
      namespace: kube-system
      inputDetail:    # Settings on CCE from which events are collected
        type: event    # Type of logs to be collected from CCE. Do not change the value.
        event:
          normalEvents:    # Used to configure normal events
            enable: true    # Whether to enable normal event collection
            includeNames:    # Names of events to be collected. If this parameter is not specified, all events will be collected.
            - NotTriggerScaleUp
            excludeNames:    # Names of events that are not collected. If this parameter is not specified, all events will be collected.
            - ScaleDown
          warningEvents:    # Used to configure warning events
            enable: true    # Whether to enable warning event collection
            - NotTriggerScaleUp
            - ScaleDown
      outputDetail:
        type: AOM    # Type of the system that receives the events. Do not change the value.
        AOM:
          events:
          - name: DeleteNodeWithNoServer    # Event name. This parameter is mandatory.
            resourceType: Namespace    # Type of the resource that operations are performed on.
            severity: Major    # Event severity after an event is reported to AOM, which can be Critical, Major, Minor, or Info. The default value is Major.
