CCE Events
CCE can report a range of events to AOM when a cluster is running. You can add event alarms as required to monitor the health of cluster data plane and control plane components. This helps you quickly identify and resolve problems, ensuring cluster stability and reliability.
- Data Plane Events: user operation events, such as workload, network, node, storage, and auto scaling events.
- Control Plane Events: master node events, which are usually caused by faults or upgrades of control plane components.
Data Plane Events
| Category | Event Name | Severity | Description |
| Pod | PodOOMKilling | Major | Check whether the pod exits due to OOM. This event is reported by CCE Node Problem Detector (1.18.41 or later) and Cloud Native Log Collection (1.3.2 or later). |
| Pod | FailedStart | Major | Check whether the pod is started. |
| Pod | FailedPullImage | Major | Check whether the pod has pulled an image. |
| Pod | BackOffStart | Major | Check whether the pod fails to restart. |
| Pod | FailedScheduling | Major | Check whether the pod has been scheduled. |
| Pod | BackOffPullImage | Major | Check whether the pod has pulled an image after a retry. |
| Pod | FailedCreate | Major | Check whether the pod is created. |
| Pod | FailedMount | Major | Check whether the volume mount to the pod failed. |
| Pod | AllocationFailed | Major | Check whether resource allocation to the pod failed. |
| Pod | Unhealthy | Minor | Check whether the pod health check is successful. |
| Pod | FailedDelete | Minor | Check whether the workload is deleted. |
| Pod | ErrImageNeverPull | Minor | Check whether the workload has pulled an image. |
| Pod | FailedScaleOut | Minor | Check whether replicas can be increased for scaling the workload. |
| Pod | FailedStandBy | Minor | Check whether the pod enters the standby state. |
| Pod | FailedReconfig | Minor | Check whether the pod configuration is updated. |
| Pod | FailedActive | Minor | Check whether the pod is activated. |
| Pod | FailedRollback | Minor | Check whether the pod is rolled back. |
| Pod | FailedUpdate | Minor | Check whether the pod is updated. |
| Pod | FailedScaleIn | Minor | Check whether the pod scale-in fails. |
| Pod | FailedRestart | Minor | Check whether the pod is restarted. |
| ReplicaSet | FailedCreate | Major | Check whether the ReplicaSet creation failed. |
| ReplicaSet | FailedDelete | Major | Check whether the ReplicaSet deletion failed. |
| ReplicationController | FailedCreate | Major | Check whether the ReplicationController creation failed. |
| ReplicationController | FailedDelete | Major | Check whether the ReplicationController deletion failed. |
| Deployment | SelectorOverlap | Minor | Check whether label selectors in the cluster conflict. |
| Deployment | ReplicaSetCreateError | Minor | Check whether a workload ReplicaSet can be created. |
| Deployment | DeploymentRollbackRevisionNotFound | Minor | Check whether the Deployment rollback version is available. |
| StatefulSet | FailedCreate | Major | Check whether the StatefulSet creation failed. |
| StatefulSet | FailedDelete | Major | Check whether the StatefulSet deletion failed. |
| DaemonSet | FailedCreate | Major | Check whether the DaemonSet creation failed. |
| DaemonSet | FailedDelete | Major | Check whether a DaemonSet deletion failed. |
| DaemonSet | FailedPlacement | Major | Check whether the DaemonSet placement failed. |
| DaemonSet | SelectingAll | Minor | Check whether the workload label selector is correctly configured. |
| Job | FailedCreate | Major | Check whether the job creation failed. |
| Job | TooManyActivePods | Minor | Check whether there are still active pods after the number of pods in a job reaches the preset value. |
| Job | TooManySucceededPods | Minor | Check whether there are extra running pods after the number of pods in a job reaches the preset value. |
| CronJob | FailedGet | Minor | Check whether the CronJob can be obtained. |
| CronJob | FailedList | Minor | Check whether the list of pods can be obtained. |
| CronJob | UnexpectedJob | Minor | Check whether there are any unknown jobs. |
| Service | CreatingLoadBalancerFailed | Minor | Check whether the load balancer is created. |
| Service | DeletingLoadBalancerFailed | Minor | Check whether the load balancer is deleted. |
| Service | UpdateLoadBalancerFailed | Minor | Check whether the load balancer is updated. |
| Node | Rebooted | Major | Check whether the node is restarted. |
| Node | NodeNotSchedulable | Major | Check whether the node is schedulable. |
| Node | NodeNotReady | Major | Check whether the node is running normally. |
| Node | NodeCreateFailed | Major | Check whether the node is created. |
| Node | FailedToAttachDetach | Major | Check whether there are disks that fail to be attached or detached on the node. |
| Node | InitializedConditionTimeout | Major | Check whether the custom node condition timed out. |
| Node | InsufficientLocalStorage | Minor | Check whether local storage pool resources on the node are running low. |
| Node | InvalidStoragePool | Minor | Check whether the node storage pool configuration is correct. |
| Node | KUBELETIsDown | Minor | Check whether kubelet is running normally on the node. |
| Node | NodeHasInsufficientMemory | Minor | Check whether the node memory is sufficient. |
| Node | UnregisterNetDevice | Minor | Check whether the node is associated with any unregistered network device. |
| Node | NetworkCardNotFound | Minor | Check the node network interface status. |
| Node | KUBEPROXYIsDown | Minor | Check whether kube-proxy is running normally on the node. |
| Node | NodeOutOfDisk | Minor | Check whether the node disk space is normal. |
| Node | TaskHung | Minor | Check whether there are any suspended tasks on the node. |
| Node | CIDRNotAvailable | Minor | Check whether the node CIDR block is available. |
| Node | ConntrackFull | Minor | Check whether the connection tracking table on the node is full. |
| Node | NodeHasDiskPressure | Minor | Check whether the node disk space is sufficient. |
| Node | NodeInstallFailed | Minor | Check whether the node is managed in the cluster. |
| Node | KernelOops | Minor | Check whether the OS kernel of the node becomes faulty. |
| Node | OOMKilling | Minor |
| Node | DOCKERIsDown | Minor | Check whether the container runtime of the node is normal. |
| Node | CIDRAssignmentFailed | Minor | Check whether a CIDR block is allocated to the node. |
| Node | DockerHung | Minor | Check whether the Docker process on the node is suspended. |
| Node | FilesystemIsReadOnly | Minor | Check whether the file system of the node is read-only. |
| Node | NTPIsDown | Minor | Check whether NTP is running normally on the node. |
| Node | NodeUninstallFailed | Minor | Check whether the node is uninstalled. |
| Node | AUFSUmountHung | Minor | Check whether detaching the node disk is suspended. |
| Node | CNIIsDown | Minor | Check whether the CNI add-on on the node becomes faulty. |
| Namespace | DeleteNodeWithNoServer | Minor | Check whether the discarded node is cleared. |
| PV | DetachVolumeFailed | Minor | Check whether the block storage is detached. |
| PV | VolumeUnknownReclaimPolicy | Minor | Check whether a volume reclaim policy is specified. |
| PV | SetUpAtVolumeFailed | Minor | Check whether the volume is mounted. |
| PV | VolumeFailedRecycle | Minor | Check whether the volume is reclaimed. |
| PV | WaitForAttachVolumeFailed | Minor | Check whether the block storage is attached to the node. |
| PV | VolumeFailedDelete | Minor | Check whether the volume is deleted. |
| PV | MountDeviceFailed | Minor | Check whether the volume is mounted. |
| PV | TearDownAtVolumeFailed | Minor | Check whether the volume is unmounted. |
| PV | UnmountDeviceFailed | Minor | Check whether the device is unmounted. |
| PV | AttachVolumeFailed | Minor | Check whether block storage is detached from the node. |
| PVC | VolumeResizeFailed | Minor | Check whether the volume capacity is expanded. |
| PVC | ClaimLost | Minor | Check whether the PVC is normal. |
| PVC | ProvisioningFailed | Minor | Check whether the volume is created. |
| PVC | ProvisioningCleanupFailed | Minor | Check whether the volume has been cleared. |
| PVC | ClaimMisbound | Minor | Check whether the PVC is bound to an incorrect volume. |
| Autoscaler | ScaleUpTimedOut | Major | Check whether scaling out nodes in the node pool timed out. |
| Autoscaler | NodePoolAvailable | Major | Check whether the node pool resources are sufficient. |
| Autoscaler | ScaleDown | Major | Nodes in the cluster are being scaled in. |
| Autoscaler | NotTriggerScaleUp | Major | Check whether node scale-out is triggered. |
| Autoscaler | DeleteUnregistered | Major | Check whether unregistered nodes are deleted. |
| Autoscaler | ScaleDownEmpty | Major | Check whether idle nodes are scaled in. |
| Autoscaler | ScaleDownFailed | Major | Check whether nodes are scaled in. |
| Autoscaler | FailedToScaleUpGroup | Major | Check whether an error occurs during node scale-out in the node pool. |
| Autoscaler | ScaledUpGroup | Major | Check whether the node pool is scaled out. |
| Autoscaler | ScaleUpFailed | Major | Check whether the node is scaled out. |
| Autoscaler | FixNodeGroupSizeDone | Major | Check whether the number of nodes in the node pool is restored. |
| Autoscaler | NodeGroupInBackOff | Major | Check whether there are any rollback retries during node pool scaling. |
| Autoscaler | FixNodeGroupSizeError | Major | Check whether the number of nodes in the node pool is restored. |
| Autoscaler | NodePoolSoldOut | Major | Check whether the node pool resources are sufficient. |
| Autoscaler | TriggeredScaleUp | Major | Check whether node scale-out is triggered. |
| Autoscaler | StartScaledUpGroup | Major | Check whether node pool scale-out is started. |
| Autoscaler | DeleteUnregisteredFailed | Major | Check whether unregistered nodes are deleted. |
| Autoscaler | QuotaInsufficient | Major | Check whether the node pool has sufficient resource quotas. |
| Autoscaler | InstancesAboveServerGroup | Major | Check whether the ECS group has reached its maximum node count. |
| Autoscaler | StartScaleDownEmpty | Major | Check whether node scale-in has started. |
| Autoscaler | WaitClaimForDeletionTimeout | Major | Check whether node scale-in is working. |
| Autoscaler | NodeCountReachClusterMaxSize | Major | Check whether the cluster has reached its maximum node count. |
| Autoscaler | FixNodeCoresAndMem | Major | Check whether CPU and memory resources have been restored successfully. |
| HPA | InvalidTargetRange | Major |
| HPA | FailedGetScale | Major | HPA failed to obtain the resource object to be scaled. |
| HPA | FailedComputeMetricsReplicas | Major | An error occurred while calculating the desired replica count for the resource. For example, metrics-server was unavailable, resource metric collection failed, or CPU usage was configured incorrectly. You can run the following command to view details: kubectl describe horizontalpodautoscaler <hpa-name> |
| HPA | FailedGetObjectMetric | Major | Failed to obtain the metrics of the specified object (such as PVC and ConfigMaps). |
| HPA | FailedGetPodsMetric | Major | Failed to obtain pod resource metrics (resource usages of a pod). |
| HPA | FailedGetResourceMetric | Major | Failed to obtain cluster resource metrics (resource usages of a cluster). |
| HPA | FailedGetContainerResourceMetric | Major | Failed to obtain the resource metrics of a container. |
| HPA | FailedGetExternalMetric | Major | Failed to obtain external metrics. |
| HPA | FailedRescale | Major | Failed to update the desired number of replicas of the resource object to be scaled. |
| HPA | SuccessfulRescale | Minor | The desired number of replicas of the resource object to be scaled has been updated. |
| CronHPA | ScaleFailed | Major | CronHPA failed to update the desired number of replicas of the resource object to be scaled. |
| CronHPA | FailedGetHorizontalPodAutoscaler | Major | CronHPA failed to query the associated HPA object. (Typically indicates kube-apiserver is unresponsive.) |
| CronHPA | FailedGetHpaScale | Major | CronHPA failed to obtain the resource object to be scaled. |
| CronHPA | UpdateHPAFailed | Major | CronHPA failed to update the associated HPA object. |
| CronHPA | UpdateHPASuccess | Minor | CronHPA has updated the associated HPA object. |
| CronHPA | SkipUpdateHPA | Minor | CronHPA skips updating the associated HPA object. |
| CronHPA | SkipUpdateTarget | Minor | CronHPA skips updating the number of replicas of the resource object to be scaled. |
| CronHPA | UpdateTargetSuccess | Minor | CronHPA has updated the number of replicas of the resource object to be scaled. |
| CustomedHPA | FailedSetPolicySettings | Major | Failed to parse the cooldown period of CustomedHPA. |
| CustomedHPA | FailedSubmitRule | Major | CustomedHPA failed to process schedule rules or metric rules. |
| CustomedHPA | FailedComputeReplicas | Major | CustomedHPA failed to trigger resource scaling based on the compute metrics. |
| CustomedHPA | FailedScale | Major | CustomHPA failed to update the desired replica count of the target resource. (Typically indicates kube-apiserver is unresponsive.) |
| CustomedHPA | MetricScaleSuccess | Minor | CustomedHPA triggers resource scaling based on the metric rule. |
| CustomedHPA | CronScaleSuccess | Minor | CustomedHPA triggers resource scaling based on the periodic rule. |
| Event ID | Severity | Description |
| Internal error | Major | Check whether an internal error occurs in the cluster. |
| External dependency error | Major | Check whether an error occurs in cluster external dependencies. |
| Failed to initialize process thread | Major | Check whether a cluster initialization thread is executed. |
| Failed to update database | Major | Check whether the database for the cluster is updated. |
| Failed to create node by nodepool | Major | Check whether nodes are created in the node pool. |
| Failed to delete node by nodepool | Major | Check whether nodes are deleted from the node pool. |
| Failed to create yearly/monthly subscription node | Major | Check whether the yearly/monthly node is created in the cluster. |
| Failed to cancel the authorization of accessing the image of the master. | Major | When creating a cluster, check whether the authorization for the resource tenant to access the master node image is canceled. |
| Failed to create the virtual IP for the master | Major | When creating a cluster, check whether the virtual IP address is allocated. |
| Failed to delete the node VM | Major | Check whether the node (VM) is deleted from the cluster. |
| Failed to delete the security group of node | Major | Check whether the node security group is deleted. |
| Failed to delete the security group of master | Major | Check whether the master node security group is deleted. |
| Failed to delete the security group of port | Major | Check whether the security group for the network interface of the master node is deleted from the cluster. |
| Failed to delete the security group of eni or subeni | Major | Check whether the security group for the network interface or supplementary network interface is deleted from the cluster. |
| Failed to detach the port of master | Major | Check whether the network interface is detached from the master node in the cluster. |
| Failed to delete the port of master | Major | Check whether the network interface of the master node is deleted from the cluster. |
| Failed to delete the master VM | Major | Check whether the master node (VM) is deleted from the cluster. |
| Failed to delete the key pair of master | Major | Check whether the key pair of the master node is deleted from the cluster. |
| Failed to delete the subnet of master | Major | Check whether the subnet of the master node is deleted from the cluster. |
| Failed to delete the VPC of master | Major | Check whether the VPC of the master node is deleted from the cluster. |
| Failed to delete certificate of cluster | Major | Check whether the certificate is deleted from the cluster. |
| Failed to delete the server group of master | Major | Check whether the cloud server group of the master node is deleted from the cluster. |
| Failed to delete the virtual IP for the master | Major | Check whether the virtual IP address is deleted from the cluster. |
| Failed to get floating IP of the master | Major | Check whether the floating IP address of the master node is obtained. |
| Failed to get cluster flavor | Major | Check whether the cluster flavor is obtained. |
| Failed to get cluster endpoint | Major | Check whether the cluster endpoint is obtained. |
| Failed to get kubernetes connection | Major | Check whether the Kubernetes cluster connection is obtained. |
| Failed to update secret | Major | Check whether the cluster secret is updated. |
| Operation timed out | Major | Check whether the user operation timed out. |
| Connecting to Kubernetes cluster timed out | Major | Check whether connecting to the Kubernetes cluster timed out. |
| Failed to check component status or components are abnormal | Major | Check whether the statuses of cluster components can be obtained or whether the components malfunction. |
| The node is not found in kubernetes cluster | Major | Check whether the node can be found in the Kubernetes cluster. |
| The status of node is not ready in kubernetes cluster | Major | Check whether the node is running normally in the Kubernetes cluster. |
| Can't find corresponding vm of this node in ECS | Major | Check whether the node can be found on the ECS console. |
| Failed to upgrade the master | Major | Check whether the master node has been upgraded. |
| Failed to upgrade the node | Major | Check whether the node has been upgraded. |
| Failed to change flavor of the master | Major | Check whether the master node flavor has been changed. |
| Change flavor of the master timeout | Major | Check whether changing the master node flavor timed out. |
| Failed to pass verification while creating yearly/monthly subscription node | Major | Check whether creating a yearly/monthly node has been verified. |
| Failed to install the node | Major | Check whether the node is installed in the cluster. |
| Failed to clean routes of cluster container network in VPC | Major | Check whether the routes of the cluster container network in the VPC are cleared. |
| Cluster status is Unavailable | Major | Check whether the cluster is available. |
| Cluster status is Error | Major | Check whether the cluster becomes faulty. |
| Cluster status is not updated for a long time | Major | Check whether the cluster remains in a state for a long time. |
| Failed to update master status after upgrading cluster timeout | Major | Check whether the status of the master node is updated after the cluster upgrade timed out. |
| Failed to update running jobs after upgrading cluster timeout | Major | Check whether running tasks are updated after the cluster upgrade timed out. |
| Failed to update cluster status | Major | Check whether the cluster status is updated. |
| Failed to update node status | Major | Check whether the node status is updated. |
| Failed to remove the static node from database | Major | Check whether nodes are removed from the database after accepting nodes timed out. |
| Failed to update node status to abnormal after node processing timeout | Major | Check whether the node status is updated to abnormal after processing the node timed out. |
| Failed to update the cluster endpoint | Major | Check whether the cluster endpoint is updated. |
| Failed to delete the unavailable connection of the Kubernetes cluster | Major | Check whether unavailable Kubernetes connections are deleted. |
| Failed to sync the cluster cert | Major | Check whether the cluster certificate is synchronized. |
