SDK Overview
This document describes different SDK runtimes supported by Cloud Container Engine (CCE) and provides the addresses for obtaining the latest SDK versions.
SDK List
Before you start, make sure you have installed the latest SDKs. Earlier SDK versions may cause compatibility issues or lack the latest features. To obtain the version, see SDK Center.
Table 1 lists SDKs supported by each CCE cloud service. You can view the SDK updates, obtain the SDK installation packages, and view SDK user guides in GitHub.
If GitHub cannot be visited, check whether you can access the public network.
