Enabling Kubernetes' Default GPU Scheduling in GPU Virtualization
With GPU virtualization enabled, workloads can still use nvidia.com/gpu (Kubernetes' default GPU scheduling) while optionally adding fine-grained isolation via volcano.sh/gpu-mem.128Mi (memory only) or both volcano.sh/gpu-mem.128Mi and volcano.sh/gpu-core.percentage (both compute and memory).
With Kubernetes' default GPU scheduling and virtualization enabled, nvidia.com/gpu can be expressed as either a fraction or an integer.
- When nvidia.com/gpu is set to a fraction:
- If workload pods are scheduled to a node that does not support GPU virtualization (for details, see Prerequisites), all pods requesting fractions simply share the entire physical GPU, including its compute and memory resources. This is suitable for scenarios with low compute demands, such as lightweight inference tasks.
- If workload pods are scheduled to a node that supports GPU virtualization (for details, see Prerequisites), pods run in memory-isolation mode and can coexist only with other memory-isolated pods. They cannot share the GPU with pods that also isolate compute. GPU memory is allocated in 128-MiB blocks, rounded down to the nearest multiple of 128 MiB based on the requested nvidia.com/gpu ratio. For example, on a 16-GiB GPU, if nvidia.com/gpu is set to 0.5, the containers will be allocated 8 GiB of GPU memory (0.5 x 16 GiB), or 8192 MiB (64 x 128 MiB).
- If nvidia.com/gpu is set to an integer, an entire physical GPU will be exclusively allocated to the target pod. This is ideal for scenarios requiring high performance and strict isolation.
Pods requesting GPUs under different resource names cannot share a node. For example, the pods requesting nvidia.com/gpu resources and the pods requesting volcano.sh/gpu-mem.128Mi resources cannot be co-located on the same node. The scheduler treats them as distinct resource types and will not bin-pack them.
Notes and Constraints
To support Kubernetes' default GPU scheduling on GPU nodes, the CCE AI Suite (NVIDIA GPU) add-on must be of v2.0.10 or later, and the Volcano Scheduler add-on must be of v1.10.5 or later.
Example of Shared GPU Scheduling
- Use kubectl to access the cluster.
- Create a workload that uses nvidia.com/gpu resources. Create a gpu-app.yaml file. The following is an example:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu-app namespace: default spec: replicas: 1 selector: matchLabels: app: gpu-app template: metadata: labels: app: gpu-app spec: schedulerName: volcano containers: image: <your_image_address> # Replace it with your image address. name: container-0 resources: requests: cpu: 250m memory: 512Mi nvidia.com/gpu: 0.1 # The value must be the same as that of limits.nvidia.com/gpu. limits: cpu: 250m memory: 512Mi nvidia.com/gpu: 0.1 # The requested GPUs imagePullSecrets: - name: default-secret - Run the following command to create an application:
kubectl apply -f gpu-app.yaml
- Log in to the pod and check the total GPU memory allocated to the pod.
kubectl exec -it gpu-app -- nvidia-smi
Expected output:
Thu Jul 27 07:53:49 2023 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA A30 Off | 00000000:00:0D.0 Off | 0 | | N/A 47C P0 34W / 165W | 0MiB / 2304MiB | 0% Default | | | | Disabled | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+
The output shows that the total GPU memory that can be used by the pod is 2304 MiB.
In this example, the node offers 24258 MiB of GPU memory in total. A 0.1-GPU request (2425.8 MiB) is rounded down to the nearest 128 MiB block, yielding 2304 MiB (18 x 128 MiB).
