Deploying an Application Through the Helm v3 Client
- The Kubernetes cluster created on CCE has been connected to kubectl. For details, see Step 1: Download kubectl.
- To pull a public image when deploying with Helm, ensure an EIP has been bound to the node.
Installing Helm v3
This section uses Helm v3.3.0 as an example.
For other versions, visit https://github.com/helm/helm/releases.
- Download the v3.3.0 Helm client from the VM connected to the cluster.
wget https://get.helm.sh/helm-v3.3.0-linux-amd64.tar.gz
- Decompress the Helm package.
tar -xzvf helm-v3.3.0-linux-amd64.tar.gz
- Copy Helm to the system path, for example, /usr/local/bin/helm.
mv linux-amd64/helm /usr/local/bin/helm
- Query the Helm version.
helm version
Command output:version.BuildInfo{Version:"v3.3.0", GitCommit:"e29ce2a54e96cd02ccfce88bee4f58bb6e2a28b6", GitTreeState:"clean", GoVersion:"go1.13.4"}
Installing the Helm Chart
You can use Helm to install a chart. Before using Helm, you may need to understand the following concepts to better use Helm:
- Chart: contains resource definitions and a large number of configuration files of Kubernetes applications.
- Repository: stores shared charts. You can download charts from the repository to a local path for installation or install them online.
- Release: running result of after a chart is installed in a Kubernetes cluster using Helm. A chart can be installed multiple times in a cluster. A new release will be created for each installation. A MySQL chart is used as an example. To run two databases in a cluster, install the chart twice. Each database has its own release and release name.
For more details, see Using Helm.
- Search for a chart from the Artifact Hub repository recommended by Helm and configure the Helm repository.
helm repo add {repo_name} {repo_addr}
The following uses the WordPress chart as an example:helm repo add bitnami https://charts.bitnami.com/bitnami
- Run the helm install command to install the chart.
helm install {release_name} {chart_name} --set key1=val1
For example, to install WordPress, the WordPress chart added in 1 is bitnami/wordpress, the release name is my-wordpress, and mandatory parameters have been configured.
helm install my-wordpress bitnami/wordpress \ --set mariadb.primary.persistence.enabled=true \ --set mariadb.primary.persistence.storageClass=csi-disk \ --set mariadb.primary.persistence.size=10Gi \ --set persistence.enabled=falseRun the helm show values {chart_name} command to view the configurable options of the chart. For example, to view the configurable items of WordPress, run the following command:helm show values bitnami/wordpress
- View the installed chart release.
helm list
Common Issues
- When you run the yum install socat –y command on a node running EulerOS 2.9 or Huawei Cloud EulerOS, the following error message is displayed:
No match for argument: socat Error: Unable to find a match: socat
The node image does not contain socat. In this case, manually download the RPM chart and run the following command to install it (replace the RPM chart name with the actual one):
rpm -i socat-1.7.3.2-8.oe1.x86_64.rpm
- Storage creation fails after you have connected to cloud storage services.
This issue may be caused by the annotation field in the created PVC. Change the chart name and install the chart again.
- If kubectl is not properly configured, the error message "Error: Kubernetes cluster unreachable..." will be displayed when you install Helm.
Example:
helm install prometheus/ --generate-name
Error information:WARNING: This chart is deprecated Error: Kubernetes cluster unreachable: Get "http://localhost:8080/version?timeout=32s": dial tcp [::1]:8080: connect: connection refused
Solution: Configure kubeconfig for the node. For details, see Step 1: Download kubectl.
