Discarded Kubernetes Resources
Check Items
Check whether there are discarded resources in the clusters.
Solution
  • Scenario 1: The Service in the clusters of v1.25 or later has discarded annotation tolerate-unready-endpoints.
    Error log:
    some check failed in cluster upgrade: this cluster has deprecated service list: map[***] with deprecated annotation list [tolerate-unready-endpoints]
    Check whether the Service provided in the log information contains the annotation tolerate-unready-endpoint. If so, replace the annotation with the following fields in Service spec:
    publishNotReadyAddresses: true
  • Scenario 2: The Service in the clusters of v1.27 or later has discarded annotation service.kubernetes.io/topology-aware-hints.
    Error log:
    some check failed in cluster upgrade: this cluster has deprecated service list: map[***] with deprecated annotation list [service.kubernetes.io/topology-aware-hints]
    Check whether the Service provided in the log information contains the annotation service.kubernetes.io/topology-aware-hints. If so, replace it with the annotation service.kubernetes.io/topology-mode in the affected Service.
