Updated on 2026-08-13 GMT+08:00
Configuring gRPC Backend Services for a LoadBalancer Ingress
Ingresses can interconnect with backend services of different protocols. By default, the backend proxy channel of an ingress is HTTP-compliant. To create a gRPC channel, add the following configuration to the annotations field:
kubernetes.io/elb.pool-protocol: grpc
This function requires ELB listeners and is available only in certain regions. Obtain these regions on the CCE console.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.10-r20 or later
    • v1.25: v1.25.5-r20 or later
    • v1.27: v1.27.2-r20 or later
    • v1.28: v1.28.1-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
  • You can obtain a trusted certificate from a certificate provider. For details, see Purchasing an SSL Certificate.
  • Ingresses can interconnect with gRPC backend services only when dedicated load balancers are used.
  • When an ingress interconnects with a gRPC backend service, the ingress protocol must be HTTPS and HTTP/2 must be enabled.
  • Load balancers do not support updating backend service protocols. Modifications are not allowed after an ingress is created.
Configuring a gRPC Backend Service
You can configure a gRPC backend Service for an ingress using either the CCE console or kubectl.
  2. Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring gRPC backend Services. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
    Dedicated
    Listener
    • Frontend Protocol: Select HTTPS for a gRPC backend Service of an ingress.
    • External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
    • Certificate Source: Select ELB server certificate.
    • Server Certificate: Use a certificate created on ELB.
      If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
    • Backend Protocol: Select gRPC.
    Only dedicated load balancers support gRPC, and HTTP/2 must be enabled. After HTTP/2 is enabled, CCE will automatically add the kubernetes.io/elb.http2-enable:true annotation.
    gRPC is available only in certain regions. Obtain these regions on the CCE console.
    • Frontend Protocol: HTTPS
    • External Port: 443
    • Certificate Source: ELB server certificate
    • Server Certificate: cert-test
    • Backend Protocol: gRPC
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
    • Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
    • Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
    • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
    • Destination Service Port: Select the access port of the destination Service.
    • (Optional) Set ELB: Set the health check protocol to gRPC. Click Customize, enable health check, and select gRPC.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Configuring a gRPC backend Service
    Figure 2 Setting the health check protocol to gRPC
  4. Click OK.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '443'
        kubernetes.io/elb.id: <your_elb_id>    # In this example, an existing dedicated load balancer is used. Replace its ID with the ID of your dedicated load balancer.
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.pool-protocol: grpc  # Interconnected gRPC backend service
        kubernetes.io/elb.http2-enable: 'true' # Enable HTTP/2.
        kubernetes.io/elb.tls-ciphers-policy: tls-1-2
      tls:
        - secretName: ingress-test-secret
      rules:
        - host: ''
          http:
            paths:
              - path: '/'
                backend:
                  service:
                    name: <your_service_name>  # Replace it with your target Service name.
                    port:
                      number: 80
                property:
      ingressClassName: cce
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
