Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Protocol and Listening Configuration/ Configuring a Range of Listening Ports for a LoadBalancer Ingress
Updated on 2026-09-21 GMT+08:00
Ingress allows you to customize listening ports. You can configure both HTTP and HTTPS listeners for a Service. For example, a Service can make available both HTTP port 80 and HTTPS port 443 for external access.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.14-r0 or later
    • v1.25: v1.25.9-r0 or later
    • v1.27: v1.27.6-r0 or later
    • v1.28: v1.28.4-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Multiple listening ports can be configured for an ingress only when a dedicated load balancer is used.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    The following shows an example configuration using an existing load balancer:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: 2c623150-17bf-45f1-ae6f-384b036f547e     # ID of an existing load balancer
        kubernetes.io/elb.class: performance    # Load balancer type
        kubernetes.io/elb.listen-ports: '[{"HTTP": 80},{"HTTPS": 443}]'    # Multi-listener configuration
        kubernetes.io/elb.tls-certificate-ids: 6cfb43c9de1a41a18478b868e34b0a82,6cfb43c9de1a41a18478b868e34b0a82   # HTTPS certificate configuration
      namespace: default
      ingressClassName: cce
      rules:
      - host: example.com
        http:
          paths:
          - backend:
              service:
                port:
                  number: 8888
            path: /
            property:
    Table 1 Annotations for custom listening ports
    Type
    String
    Configure multiple listening ports for an ingress. The port number ranges from 1 to 65535.
    The following is an example for JSON characters:
    kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
    • Only the listening ports that comply with both HTTP and HTTPS are allowed.
    • This function is available only for newly created ingresses in clusters earlier than v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, or v1.30.4-r0. After you configure multiple listening ports, the annotations cannot be modified or deleted. In clusters v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, the annotations can be modified and deleted.
    • If both kubernetes.io/elb.listen-ports and kubernetes.io/elb.port are configured, kubernetes.io/elb.listen-ports takes a higher priority.
    • Ingress configuration items such as the blocklist, trustlist, and timeout concurrently take effect on multiple listening ports. When HTTP/2 is enabled for an ingress, HTTP/2 takes effect only on the HTTPS port.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS           ADDRESS          PORTS   AGE
    ingress-test  cce      example.com     121.**.**.**     80,443  10s
