Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ Memory Resource Limit of Kubernetes Components
Updated on 2025-11-06 GMT+08:00
Check Items
Check whether the resources of Kubernetes components, such as etcd and kube-controller-manager, exceed the limits.
- Solution 1: Reduce Kubernetes resources that are needed.
- Solution 2: Modify cluster specifications. For details, see Changing a Cluster Scale.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
