Situation Awareness
Connecting to a Cluster Using kubectl
Updated on 2024-01-26 GMT+08:00
This section uses a CCE cluster as an example to describe how to connect to a CCE cluster using kubectl.
Permissions
When you access a cluster using kubectl, CCE uses kubeconfig.json generated on the cluster for authentication. This file contains user information, based on which CCE determines which Kubernetes resources can be accessed by kubectl. The permissions recorded in a kubeconfig.json file vary from user to user.
For details about user permissions, see Cluster Permissions (IAM-based) and Namespace Permissions (Kubernetes RBAC-based).
Using kubectl
To connect to a Kubernetes cluster from a PC, you can use kubectl, a Kubernetes command line tool. You can log in to the CCE console, click the name of the cluster to be connected, and view the access address and kubectl connection procedure on the cluster details page.
CCE allows you to access a cluster through a private network or a public network.
  • Intranet access: The client that accesses the cluster must be in the same VPC as the cluster.
  • Public access: The client that accesses the cluster must be able to access public networks and the cluster has been bound with a public network IP.
    NOTICE:
    To bind a public IP (EIP) to the cluster, go to the cluster details page and click Bind next to EIP in the Connection Information pane. In a cluster with an EIP bound, kube-apiserver will be exposed to public networks and may be attacked. You are advised to configure Advanced Anti-DDoS (AAD) for the EIP of the node where kube-apiserver resides.
Download kubectl and the configuration file. Copy the file to your client, and configure kubectl. After the configuration is complete, you can access your Kubernetes clusters. Procedure:
  1. Download kubectl.
    Prepare a computer that can access the public network and install kubectl in CLI mode. You can run the kubectl version command to check whether kubectl has been installed. If kubectl has been installed, skip this step.
    This section uses the Linux environment as an example to describe how to install and configure kubectl. For details, see Installing kubectl.
    1. Log in to your client and download kubectl.
      cd /home
      curl -LO https://dl.k8s.io/release/{v1.25.0}/bin/linux/amd64/kubectl
      {v1.25.0} specifies the version number. Replace it as required.
    2. Install kubectl.
      chmod +x kubectl
      mv -f kubectl /usr/local/bin
  2. Obtain the kubectl configuration file (kubeconfig).
    In the Connection Information pane on the cluster details page, click Configure next to kubectl. On the window displayed, download the configuration file.
    • The kubectl configuration file kubeconfig.json is used for cluster authentication. If the file is leaked, your clusters may be attacked.
    • By default, two-way authentication is disabled for domain names in the current cluster. You can run the kubectl config use-context externalTLSVerify command to enable two-way authentication. For details, see Two-Way Authentication for Domain Names. For a cluster that has been bound to an EIP, if the authentication fails (x509: certificate is valid) when two-way authentication is used, bind the EIP again and download kubeconfig.json again.
    • The Kubernetes permissions assigned by the configuration file downloaded by IAM users are the same as those assigned to the IAM users on the CCE console.
    • If the KUBECONFIG environment variable is configured in the Linux OS, kubectl preferentially loads the KUBECONFIG environment variable instead of $home/.kube/config.
  3. Configure kubectl.
    Configure kubectl (A Linux OS is used).
    1. Log in to your client and copy the kubeconfig.json configuration file downloaded in 2 to the /home directory on your client.
    2. Configure the kubectl authentication file.
      cd /home
      mkdir -p $HOME/.kube
      mv -f kubeconfig.json $HOME/.kube/config
    3. Switch the kubectl access mode based on service scenarios.
      • Run this command to enable intra-VPC access:
        kubectl config use-context internal
      • Run this command to enable public access (EIP required):
      • Run this command to enable public access and two-way authentication (EIP required):
        For details about the cluster two-way authentication, see Two-Way Authentication for Domain Names.
CCE supports two-way authentication for domain names.
  • Two-way authentication is disabled for domain names by default. You can run the kubectl config use-context externalTLSVerify command to switch to the externalTLSVerify context to enable it.
  • When an EIP is bound to or unbound from a cluster, or a custom domain name is configured or updated, the cluster server certificate will be added the latest cluster access address (including the EIP bound to the cluster and all custom domain names configured for the cluster).
  • Asynchronous cluster synchronization takes about 5 to 10 minutes. You can view the synchronization result in Synchronize Certificate in Operation Records.
  • For a cluster that has been bound to an EIP, if the authentication fails (x509: certificate is valid) when two-way authentication is used, bind the EIP again and download kubeconfig.json again.
  • If the domain name two-way authentication is not supported, kubeconfig.json contains the "insecure-skip-tls-verify": true field, as shown in Figure 1. To use two-way authentication, you can download the kubeconfig.json file again and enable two-way authentication for the domain names.
    Figure 1 Two-way authentication disabled for domain names
Common Issues
  • Error from server Forbidden
    When you use kubectl to create or query Kubernetes resources, the following output is returned:
    # kubectl get deploy Error from server (Forbidden): deployments.apps is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "deployments" in API group "apps" in the namespace "default"
    The cause is that the user does not have the permissions to operate the Kubernetes resources. For details about how to assign permissions, see Namespace Permissions (Kubernetes RBAC-based).
  • The connection to the server localhost:8080 was refused
    The connection to the server localhost:8080 was refused - did you specify the right host or port?
    The cause is that cluster authentication is not configured for the kubectl client. For details, see 3.
