Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Routing and Forwarding Policies/ Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress
Updated on 2026-09-21 GMT+08:00
Dedicated load balancer ingresses support custom header forwarding policies. You can configure different header key-value pairs to determine the backend Service to which data is forwarded.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.16-r0 or later
    • v1.25: v1.25.11-r0 or later
    • v1.27: v1.27.8-r0 or later
    • v1.28: v1.28.6-r0 or later
    • v1.29: v1.29.2-r0 or later
    • Other clusters of later versions
  • The cluster can be accessed using kubectl. For details, see Accessing a Cluster Using kubectl.
  • Some functions of the custom header forwarding policy (kubernetes.io/elb.headers.<svc-name>) overlap with those of the advanced forwarding policy (kubernetes.io/elb.conditions.<svc-name>). Therefore, the two policies cannot be configured together. Advanced forwarding policies support header-based forwarding. Use advanced forwarding policies to avoid conflicts. For details, see Scenario 1: Configuring Advanced Forwarding Rules for a LoadBalancer Ingress.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress created using an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.id: 08eab934-1636-4d90-a4cd-cb3fa4330411
        kubernetes.io/elb.class: performance  # A dedicated load balancer is required.
        # Path /a can be accessed only through Header key1=value1 or key1=value2. The accessed Service is svc-a:80.
        kubernetes.io/elb.headers.svc-a: |
              "key": "key1",
              "values": [
                  "value1",
                  "value2"
        # Path /b can be accessed only through Header key2=value1 or key2=value2. The accessed Service is svc-b:81.
        kubernetes.io/elb.headers.svc-b: |
              "key": "key2",
              "values": [
                  "value1",
                  "value2"
      rules:
        - host: ''
          http:
            paths:
              - path: /a
                backend:
                  service:
                    port:
                      number: 80
                property:
              - path: /b
                backend:
                  service:
                    port:
                      number: 81
                property:
      ingressClassName: cce
    Table 1 Annotations for configuring a custom header forwarding policy
    Type
    kubernetes.io/elb.headers.${svc_name}
    String
    Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
    Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
    • A key-value pair represents the key and value of a custom header. You can configure up to nine values. However, if a header with the key host is specified, only eight values can be configured.
      Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
      Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
    • After a custom header forwarding policy is configured for an ingress, a grayscale release policy cannot be created for the ingress.
    • Enter 1 to 51 characters for ${svc_name}.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
