Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Routing and Forwarding Policies/ Configuring Forwarding Rule Priorities for a LoadBalancer Ingress with a Redirect Listener
Updated on 2026-09-21 GMT+08:00
When multiple ingresses share the same load balancer, particularly in HTTP-to-HTTPS redirection scenarios, the execution order of forwarding rules is critical. Incorrect priorities can cause redirection logic to interfere with normal ingress traffic, or cause ingresses to be unexpectedly intercepted by the redirection rule. This section describes how to configure forwarding rule priorities for a LoadBalancer ingress with a redirect listener.
  • This feature is available only for dedicated load balancers.
  • The priority configuration for HTTP-to-HTTPS redirection rules is supported only in clusters v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later.
Default Priority Rules
When configuring forwarding rule priorities for a LoadBalancer ingress, use the kubernetes.io/elb.ingress-order annotation to sort forwarding rules across different ingresses. The rules are as follows:
  • The kubernetes.io/elb.ingress-order value ranges from 1 to 1000. A smaller value indicates a higher priority.
  • Ingresses with the kubernetes.io/elb.ingress-order annotation take priority over those without it.
In the default scenario, ingress priorities are ordered as follows (highest to lowest):
  1. kubernetes.io/elb.ingress-order configured with a small value
  2. kubernetes.io/elb.ingress-order configured with a large value
  3. kubernetes.io/elb.ingress-order not configured
For more information about ingress-order, see Configuring Forwarding Rule Priorities for LoadBalancer Ingresses.
If the ingress-order annotation is not configured, the HTTP-to-HTTPS redirection rule has the highest priority by default. For details, see Example 2: Not Configuring ingress-order in Redirect Scenarios.
Scenario-specific Examples
Example 1: Configuring ingress-order in Redirect Scenarios
Consider four ingresses (ingress-a, ingress-b, ingress-c, and ingress-d) sharing a dedicated load balancer.
Ingress
ingress-order Value
Port
Rule
ingress-a
Rule A (host: a.com, path: /A)
HTTP forwarding on port 80
ingress-b
2
80 -> 443
Rule B (host: b.com, path: /B)
Redirecting HTTP/80 to HTTPS/443
ingress-c
3
443
Rule C (host: c.com, path: /C)
HTTPS forwarding on port 443
ingress-d
Not configured
80
Rule D (host: d.com, path: /D)
The following figure shows a successful creation.
Check the priorities of the forwarding rules on ELB listener port 80. The forwarding order is as follows.
Forwarding Rule Priority
Rule
Ingress
ingress-order
ingress-a
ingress-b
2
3
ingress-d
Not configured
Check the priorities of the forwarding rules on ELB listener port 443. The forwarding order is as follows.
Rule
Ingress
ingress-order
ingress-b
2
2
ingress-c
3
To adjust the priority of a redirection rule, do as follows:
  1. Move ingress-a on port 80 behind ingress-b.
    Update the YAML file of ingress-a and change the kubernetes.io/elb.ingress-order value from 1 to 3.
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '80'    # Port on the associated load balancer
        kubernetes.io/elb.id: fef427e4-6d2c-4c63-bf26-270daa******    # ID of the existing load balancer
        kubernetes.io/elb.class: performance    # Type of the existing load balancer, which must be performance
        kubernetes.io/elb.ingress-order: '3'    # Changed from 1 to 3.
      rules:
        - host: 'a.com'
          http:
            paths:
              - path: /A  # Define forwarding rule A.
                backend:  # The backend Service associated with the rule. The value provided is only an example and can be modified as needed.
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: cce
    Rule
    Ingress
    ingress-order
    ingress-b
    2
    2
    ingress-a
    3
    3
    ingress-d
    Not configured
  2. Move ingress-c on port 443 ahead of ingress-b.
    Update the YAML file of ingress-c and change the kubernetes.io/elb.ingress-order value from 3 to 1.
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '443'    # Port on the associated load balancer
        kubernetes.io/elb.ingress-order: '1'    # Priority of forwarding rules across different ingresses
        kubernetes.io/elb.tls-certificate-ids: fd12a22d3ea64ae697066b78d9******,e981aee11f074c8d89c8eaa023******
      rules:
        - host: 'c.com'
          http:
            paths:
              - path: /C  # Define forwarding rule C.
                  service:
                    port:
                      number: 80
                property:
    Rule
    Ingress
    ingress-order
    ingress-c
    ingress-b
    2
Consider three ingresses (ingress-a, ingress-b, and ingress-c) sharing a dedicated load balancer.
Ingress
ingress-order Value
Port
Rule
ingress-a
Not configured
80 -> 443
ingress-b
ingress-c
2
80
Rule
Ingress
ingress-order
ingress-a
Not configured
2
ingress-b
ingress-c
2
