Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Routing and Forwarding Policies/ Configuring an Advanced Forwarding Policy for a LoadBalancer Ingress
Updated on 2026-09-21 GMT+08:00
When a LoadBalancer ingress is created in a CCE cluster, CCE provisions a listener in ELB for the load balancer associated with the ingress and adds forwarding policies. By default, the ingress routes incoming client requests based on the domain name and path and directs the requests through the listener to the appropriate backend server, either a node or pod, for processing. During the LoadBalancer ingress creation, CCE allows you to define custom forwarding rules and actions for flexible, fine-grained traffic distribution.
Figure 1 How an advanced forwarding policy operates
An advanced forwarding policy operates as follows:
  1. The client initiates a request to the LoadBalancer ingress.
  2. The load balancer evaluates the request against the forwarding rules defined in the advanced forwarding policy.
  3. The load balancer forwards the request to the appropriate backend server based on the action specified in the forwarding policy.
  4. The backend server returns a response to the client.
For details about the forwarding rules and actions supported by advanced forwarding policies, see Forwarding Rules and Forwarding Actions.
  • If the annotations for forwarding rules and actions are different, the forwarding behaviors and results are different, as described in the following table.
    Annotation Setting
    Result
    Annotations for forwarding rules and actions are not configured.
    CCE does not process existing advanced forwarding rules and actions on ELB. This is to prevent the advanced forwarding rules and actions configured on ELB from being deleted by mistake.
    Annotations for forwarding rules and actions are configured and left empty ([]).
    • If forwarding rules (conditions) are left blank, all advanced forwarding rules supported by CCE are deleted.
    • If forwarding actions (actions) are left blank, all advanced forwarding actions supported by CCE are deleted.
    Annotations for forwarding rules and actions are configured and not left empty (not []).
    For advanced forwarding rules/actions that can be configured in CCE annotations, ELB generates advanced forwarding rules/actions based on the annotations. For example, if advanced forwarding rules or actions exist on the ELB but are not specified in CCE annotations, ELB deletes them accordingly. Rules or actions that cannot be configured through CCE annotations remain unaffected.
    Annotations for forwarding rules and actions are configured, but some target Services do not match the Service names specified in the annotations.
    The advanced forwarding rules or actions in the annotations only take effect for the matched Services.
    For any unmatched Service, the forwarding result is the same as that of the scenario where no annotations are configured. This means CCE does not process the original advanced forwarding policy of the Service. For example, if an advanced forwarding policy has been configured for ServiceA, and the matching relationship is lost after ServiceA is updated to ServiceB, ELB will still use the advanced forwarding policy of ServiceA. For more information about this scenario, see Common Issues.
    When updating the target Service, configure the advanced forwarding policy annotations for it.
CCE allows you to configure header writing/removal, rewriting, and limiting on requests, based on ELB's advanced forwarding for LoadBalancer ingresses. These functions are currently being rolled out, and availability depends on the actual regions that have been officially opened. To use some advanced forwarding actions that are not available on the console yet, submit a service ticket to enable required functions.
Forwarding Rules
LoadBalancer ingresses support advanced traffic routing by allowing you to configure forwarding rules using the kubernetes.io/elb.conditions.<svc-name> annotation. Incoming requests are evaluated against these rules. If the conditions are met, the requests are forwarded accordingly.
If you set up different rules for the same Service using the same annotation, they must all be matched for a request to go through. If you set multiple values for a condition, the request only needs to match one of them. For example, when both Method and QueryString rules are configured, the request must satisfy both conditions. However, if the Method rule specifies GET or POST, the request matches if either method is used and the QueryString condition is met.
You can configure up to 10 advanced forwarding conditions (including domain names and paths) per ingress. Each individual value within a rule counts as one forwarding condition.
For example, if you define a domain name and a path for an ingress, there are two forwarding conditions, leaving eight remaining. If you then specify two HTTP methods, for example, GET and POST, two more forwarding conditions are used.
Table 1 ELB advanced forwarding rules
Forwarding Rule
Reference
Cluster Version
HTTP request method
Route HTTP requests based on the HTTP request method (such as GET or POST). If a request matches the specified rule, the defined forwarding action is used.
An annotation example is as follows:
kubernetes.io/elb.conditions.<svc-name>: |
    "type": "Method",
    "methodConfig": {
      "values": [
        "GET",
        "POST"
For details about the configuration example and parameters of advanced forwarding rules, see Scenario 1: Configuring Advanced Forwarding Rules for a LoadBalancer Ingress.
  • v1.23: v1.23.18-r10 or later
  • v1.25: v1.25.16-r0 or later
  • v1.27: v1.27.16-r0 or later
  • v1.28: v1.28.13-r0 or later
  • v1.29: v1.29.8-r0 or later
  • v1.30: v1.30.4-r0 or later
  • Other clusters of later versions
HTTP request header
Route requests based on the specific information (such as User-Agent or Content-Type) in HTTP request headers. If a request matches the specified rule, the defined forwarding action is used.
    "type": "Header",
    "headerConfig": {
      "key": "gray-hello",
      "values": [
        "value1",
        "value2"
Cookie
Route requests based on the specified keys and values in cookies. If a request matches the specified rule, the defined forwarding action is used.
  "type": "Cookie",
  "cookieConfig": {
     "values": [
          "key": "cookiekey1",
          "value": "cookievalue1"
           "key": "cookiekey2",
           "value": "cookievalue2"
Query string
Route requests based on the specific parameters and values of the query strings in the URLs. If a request matches the specified rule, the defined forwarding action is used.
    "type": "QueryString",
    "queryStringConfig": {
      "key": "querykey",
      "values": [
        "queryvalue"
CIDR block
Route requests based on the source IP addresses from where the requests originate. If a request matches the specified rule, the defined forwarding action is used.
    "type": "SourceIp",
    "sourceIpConfig": {
      "values": [
        "192.168.0.0/16",
        "172.16.0.0/16"
Forwarding Actions
LoadBalancer ingresses allow you to define multiple forwarding actions through annotations. This gives you flexible control over how requests are handled. The supported forwarding actions include:
  • (Default) Forward to a backend server group: The following supplementary actions are supported: URL rewrite, CORS, header modification and removal, and rate limiting. Load balancers apply these actions before forwarding requests to backend server groups. Rate limiting takes precedence over all other actions.
  • Redirect to another listener: HTTP requests can be redirected to an HTTPS listener.
  • Return a specific response body: Additional actions such as limit request are supported.
  • Forward to custom backend server group: This action is mutually exclusive with grayscale release, fixed response, and URL redirect actions.
Table 2 ELB advanced forwarding actions
Forwarding Action
Additional Action
Reference
Cluster Version
Rewrite
Rewrite the request paths.
kubernetes.io/elb.rewrite-target: /rewritepath
For details about the configuration example and parameters, see Configuring URL Rewriting for a LoadBalancer Ingress.
  • v1.23: v1.23.14-r0 or later
  • v1.25: v1.25.9-r0 or later
  • v1.27: v1.27.6-r0 or later
  • v1.28: v1.28.4-r0 or later
CORS
Support cross-origin access of resources.
Annotation examples are as follows:
kubernetes.io/elb.cors-allow-origin: 'http://example.com'  # The origin that can be accessed
kubernetes.io/elb.cors-allow-headers: 'fake-header-1' # The allowed request header
kubernetes.io/elb.cors-expose-headers: 'fake-header-2' # The response header to be exposed
kubernetes.io/elb.cors-allow-methods: 'GET,POST' # The allowed HTTP request methods
kubernetes.io/elb.cors-allow-credentials: 'true' # Credentials can be sent.
kubernetes.io/elb.cors-max-age: '3600' # The cache duration of a pre-check request
For details about the configuration example and parameters, see Configuring Cross-Origin Access for LoadBalancer Ingresses.
Write/Remove header
Write or delete the configured header in a request before accessing the backend server.
kubernetes.io/elb.actions.<svc-name>: |
      "type": "InsertHeader",
      "InsertHeaderConfig": {
        "key": "insertkey",
        "value_type": "USER_DEFINED",
        "value": "insertvalue"
      "type": "RemoveHeader",
      "RemoveHeaderConfig": {
        "key": "removekey"
For details about the configuration example and parameters, see Example 1: Configuring Write/Remove Header for a LoadBalancer Ingress.
Limit request
Limit request rates.
     "type": "TrafficLimit",
     "trafficLimitConfig": {
       "QPS": 4,
       "perSourceIpQps": 2,
       "burst": 2
For details about the configuration example and parameters, see Example 3: Configuring Limit Request for a LoadBalancer Ingress.
  • v1.27: v1.27.16-r10 or later
  • v1.28: v1.28.15-r0 or later
  • v1.29: v1.29.10-r0 or later
  • v1.30: v1.30.6-r0 or later
Redirect to another listener (HTTP requests redirected to an HTTPS listener)
None
Forward HTTP access requests to an HTTPS listener.
kubernetes.io/elb.ssl-redirect: 'true'
kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]' # Forward HTTP requests to an HTTPS port.
For details about the configuration example and parameters, see Redirecting HTTP to HTTPS for a LoadBalancer Ingress.
Redirect to another URL
None
Redirect specific requests to a specified URL and return a 3xx return code.
kubernetes.io/elb.redirect-url: https://example.com/testa   # Information about the redirection to a URL
kubernetes.io/elb.redirect-url-code: '301' # Code returned after requests are redirected to a URL
For details about the configuration example and parameters, see Configuring URL Redirection for a LoadBalancer Ingress.
None
Return a specific response and do not continue to forward the request to the backend server.
     "type": "FixedResponse",
     "fixedResponseConfig": {
       "contentType": "text/plain",
       "statusCode": "503",
       "messageBody": "503 error text"
For details about the configuration example and parameters, see Example 2: Configuring a Specific Response Body for a LoadBalancer Ingress.
  • v1.25: v1.25.16-r10 or later
Limit request
       "QPS": 4,
       "burst": 2
Forward to a custom backend server group
Forward requests to the LoadBalancer ingress to both pods in the CCE cluster (default backend server group) and an ECS group (custom backend server group) outside the cluster.
     "type": "ForwardPool",
     "forwardConfig": [{
       "serviceName": "test",
       "servicePort": 80,
       "weight": 90,
       "type": "service"
       "poolID": "53d8516e-xxxx-xxxx-xxxx-b15ffd6b3cca",
       "weight": 70,
       "type": "pool"
For details about the configuration example and parameters, see Example 4: Configuring the Forward to a Custom Backend Server Group Action for a LoadBalancer Ingress.
  • v1.25: v1.25.16-r20 or later
  • v1.27: v1.27.16-r20 or later
  • v1.28: v1.28.15-r10 or later
  • v1.29: v1.29.10-r10 or later
  • v1.30: v1.30.6-r10 or later
  • v1.31: v1.31.4-r0 or later
Mirror traffic to a backend server group
Mirror traffic to the specified backend server group for traffic inspection, audit analysis, and troubleshooting.
If you have configured additional actions, traffic will first be processed by these actions before being mirrored to the specified backend server group.
        "type": "TrafficMirror",
        "trafficMirrorConfig": {
              "mirrorRequestBodyEnable" : true,
              "targetIDs": ["fb1fbd39-xxxx-xxxx-xxxx-9da37704a4e7"]
For details about the configuration example and parameters, see Example 5: Configuring the Action to Mirror Traffic to a Backend Server Group for a LoadBalancer Ingress.
  • v1.28: v1.28.15-r70 or later
  • v1.29: v1.29.15-r30 or later
  • v1.30: v1.30.14-r30 or later
  • v1.31: v1.31.10-r30 or later
  • v1.32: v1.32.6-r30 or later
  • v1.33: v1.33.5-r20 or later
  • v1.34: v1.34.1-r0 or later
LoadBalancer ingresses can route traffic based on custom HTTP request methods, HTTP request headers, cookies, query strings, and CIDR blocks. In this example, traffic is routed to the svc-hello1 Service only when the request path is /hello1 and the following advanced forwarding rules are met:
  • The HTTP request method is GET or POST.
  • The key of the HTTP request header is gray-hello, and the value is value1 or value2.
  • The key of the cookie is cookiekey1 and the value is cookievalue1, or the key of the cookie is cookiekey2 and the value is cookievalue2.
  • The key of the query string is querykey, and the value is queryvalue.
  • The CIDR block is 192.168.0.0/16 or 172.16.0.0/16.
The operations and parameter settings are as follows:
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress created using an existing load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.class: performance      # Load balancer type
        kubernetes.io/elb.id: ab53c3b2-xxxx-xxxx-xxxx-5ac3eb2887be   # The load balancer ID. Replace it with the actual value.
        kubernetes.io/elb.port: '80'        # The load balancer port. Replace it with the actual value.
        # The following indicates that the advanced forwarding rules are configured for the svc-hello1 Service. The Service name must be the same as that in the backend field.
        kubernetes.io/elb.conditions.svc-hello1: |
                "type": "Method",
                "methodConfig": {
                  "values": [
                    "GET",
                    "POST"
                "type": "Header",
                "headerConfig": {
                  "values": [
                    "value1",
                    "value2"
                "type": "Cookie",
                "cookieConfig": {
                  "values": [
                  "key": "querykey",
                  "values": [
                    "queryvalue"
                "type": "SourceIp",
                "sourceIpConfig": {
                  "values": [
                    "192.168.0.0/16",
                    "172.16.0.0/16"
      ingressClassName: cce
      rules:
       - http:
          paths:
          - path: /hello1
            backend:
              service:
                port:
                  number: 80
    Table 3 Annotation for advanced forwarding rules
    Type
    kubernetes.io/elb.conditions.${svc_name}
    String
    Configure advanced forwarding rules. ${svc_name} indicates the Service name, which can contain a maximum of 48 characters.
    If the annotation value is set to [], the advanced forwarding rule will be deleted.
    The annotation value is a JSON array. For details, see Table 4.
    CAUTION:
    The rules in a conditions array are connected by an AND relationship, while the values in the same rule block are connected by an OR relationship. For example, if both Method and QueryString are configured, the target traffic can be distributed only when both rules are met. However, if the Method value is GET or POST, the target traffic can be distributed only when both rules are met and the Method value must be GET or POST.
    Table 4 Array structure
    Example
    type
    Matching type. Options:
    • Method: HTTP requests are forwarded based on the matched method. This parameter must be used with methodConfig. Method can be configured only once.
    • Header: HTTP requests are forwarded based on the matched header. This parameter must be used with headerConfig.
    • Cookie: HTTP requests are forwarded based on the matched cookie. This parameter must be used with cookieConfig.
    • QueryString: HTTP requests are forwarded based on the matched character string. This parameter must be used with queryStringConfig.
    • SourceIp: HTTP requests are forwarded based on the matched CIDR block. This parameter must be used with sourceIpConfig. SourceIp can be configured only once.
    None
    methodConfig
    An HTTP request method that is used to forward requests. This parameter is used only when type is set to Method.
    Multiple methods can be concurrently configured, including GET, POST, PUT, DELETE, PATCH, HEAD, and OPTIONS.
    You do not need to configure keys for methodConfig. You only need to configure values (an array) for methodConfig.
      "type": "Method",
      "methodConfig": {
         "values": [
            "GET",
            "POST"
    headerConfig
    An HTTP request header that is used to forward requests. This parameter is used only when type is set to Header.
    • A key can only contain letters, digits, underscores (_), and hyphens (-).
      The first letter of the User-agent and Connection HTTP request headers must be capitalized.
    • Multiple values can be configured for a key. A value can only contain letters, digits, and special characters !#$%&'()*+,.\/:;<=>?@[]^-_'{|}~. Asterisks (*) and question marks (?) can be used as wildcard characters.
    You can only configure one key for each headerConfig rule. If you need multiple keys, configure multiple headerConfig rules.
      "type": "Header",
      "headerConfig": {
         "values": [
            "value1",
            "value2"
    cookieConfig
    A cookie that is used to forward requests. This parameter is used only when type is set to Cookie. A cookie consists of a key and a value, which must be configured separately.
    • A key can contain 1 to 100 characters and cannot start or end with a space.
    • A value can contain 1 to 100 characters. Configure a value for each key.
    You can enter multiple key-value pairs that can contain letters, digits, and special characters (!%'"()*+,./:=?@^-_`~).
    When configuring cookieConfig, you can configure multiple key-value pairs in values, and these pairs will have an OR relationship with each other.
      "type": "Cookie",
      "cookieConfig": {
         "values": [
    queryStringConfig
    A character string that is used to forward requests. If the character string in a request matches the one in the configured forwarding rule, the request will be forwarded. This parameter is used only when type is set to QueryString.
    A query string consists of a key and one or more values. Configure the key and values separately.
    • A key can only contain letters, digits, and special characters !$'()*+,./:;=?@^-_'.
    • Multiple values can be configured for a key. A value can only contain letters, digits, and special characters !$'()*+,./:;=?@^-_'. Asterisks (*) and question marks (?) can be used as wildcard characters.
    You can only configure one key for each queryStringConfig rule. If you need multiple keys, configure multiple QueryStringConfig rules.
          "key": "querykey",
          "values": [
              "queryvalue"
    sourceIpConfig
    A CIDR block that is used to forward requests. This parameter is used only when type is set to SourceIp.
    Example: 192.168.1.0/24 or 2001:db8::/64
    You do not need to configure keys for sourceIpConfig. You only need to configure values (an array) for sourceIpConfig.
       "type": "SourceIp",
       "sourceIpConfig": {
          "values": [
             "192.168.0.0/16",
             "172.16.0.0/16"
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
Scenario 2: Configuring Advanced Forwarding Actions for a LoadBalancer Ingress
The examples describe how to configure actions like write/remove header, return a specific response body, limit request, and forward to a custom backend server group for a LoadBalancer ingress.
Combined Application Scenarios
Advanced forwarding rules and actions can be combined to meet various requirements. Some examples are shown in the table below.
Rules to Be Applied When an Ingress Is Accessed
Actions to Be Taken
Target Service (Backend Service)
  • Domain name: example.com
  • Request path: /path1
  • Other advanced forwarding rules:
    • Request method: GET or POST
    • Request header: gray-hello:value1 or gray-hello:value2
    • Request cookie: cookiekey1:cookievalue1 or cookiekey2:cookievalue2
    • Query string: querykey:queryvalue
    • CIDR block: 192.168.0.0/16 or 172.16.0.0/16
The following actions will be taken during forwarding:
  • Write the user-defined request header aa:aa.
  • Delete the request header with the key dd.
test
  • Request path: /path2
  • Return a specific response with status code 503 and the content 503 error text.
  • Set the total QPS limit to 67 and limit the QPS per client source IP address to 3.
test2
  • Path: /path3
  • Forward to the backend server groups associated with the test Service (weight: 90) and test2 Service (weight: 10).
test and test2
The YAML file example is as follows:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.id: *****
    kubernetes.io/elb.listener-master-ingress: default/ingress-demo
    # The following annotation applies to the test Service and is used to add multiple load balancer forwarding matching conditions to it.
    kubernetes.io/elb.conditions.test: |
            "type": "Method",
            "methodConfig": {
              "values": [
                "GET",
                "POST"
            "type": "Header",
            "headerConfig": {
              "values": [
                "value1",
                "value2"
            "type": "Cookie",
            "cookieConfig": {
              "values": [
              "key": "querykey",
              "values": [
                "queryvalue"
            "type": "SourceIp",
            "sourceIpConfig": {
              "values": [
                "192.168.0.0/16",
                "172.16.0.0/16"
    # The following annotation applies to the test Service and is used to configure the write/remove header action for it.
    kubernetes.io/elb.actions.test: |
              "key": "aa",
              "value": "aa"
              "key": "dd"
    # The following annotation applies to the test2 Service and is used to configure returning a specific response body and limiting request actions for it.
    kubernetes.io/elb.actions.test2: |
         "TrafficLimItConfig": {
             "perSourceIpQps": 3,
             "qps": 67
    # The following annotation applies to the test3 Service and is used to configure the write header, limit request, and forward to custom backend server groups (associated with test and test2) actions for it.
    kubernetes.io/elb.actions.test3: |
              "key": "aa",
              "value": "aa"
       "forwardConfig": [{
            "servicePort": 80,
            "weight": 90,
            "type": "service"
            "serviceName": "test2",
            "servicePort": 80,
            "weight": 10,
            "type": "service"
           "qps": 67
  rules:
    - host: example.com
      http:
        paths:
          - path: /path1
            backend:
              service:
                port:
                  number: 80
            property:
          - path: /path2
            backend:
              service:
                port:
                  number: 80
            property:
          - path: /path3
            backend:
              service:
                port:
                  name: use-annotation  # If the forward to custom backend server group ("type": "ForwardPool") action is specified, port.name must be set to use-annotation.
            property:
Common Issues
If you have any questions, the following content may help you.
