Configuring Redirection Rules for an Nginx Ingress
Configuring a Permanent Redirection Rule
To permanently redirect an access request to a target website (status code 301), use the nginx.ingress.kubernetes.io/permanent-redirect annotation. For example, to permanently redirect all access requests to www.example.com, run the following command:
nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com
The configuration in an Nginx Ingress is as follows:
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com spec: rules: - host: '' http: paths: - path: / backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginxFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com spec: rules: - host: '' http: paths: - path: / backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with your target Service port. - Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress.networking.k8s.io/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test nginx * 121.**.**.** 80 10s
- Access the ingress. ${ELB_IP} specifies the IP address of the load balancer associated with the Nginx ingress.
curl -I ${ELB_IP}The access path will be redirected to www.example.com.
HTTP/1.1 301 Moved Permanently Date: Sat, 20 Jul 2024 07:55:49 GMT Content-Type: text/html Content-Length: 162 Connection: keep-alive Location: https://www.example.com
Configuring the Returned Status Code for the Permanent Redirection Rule
When configuring a permanent redirection rule, you can use the nginx.ingress.kubernetes.io/permanent-redirect-code annotation to modify its returned status code. For example, to set the status code for the permanent redirection to 308, run the following command:
nginx.ingress.kubernetes.io/permanent-redirect-code: '308'
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com nginx.ingress.kubernetes.io/permanent-redirect-code: '308' spec: rules: - host: '' http: paths: - path: / backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginxFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com nginx.ingress.kubernetes.io/permanent-redirect-code: '308' spec: rules: - host: '' http: paths: - path: / backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with your target Service port. - Create an ingress.
kubectl get ingress
curl -I ${ELB_IP}The access path will be permanently redirected to www.example.com, and the status code is 308.
HTTP/1.1 308 Moved Permanently Date: Sat, 20 Jul 2024 07:55:49 GMT Content-Type: text/html Content-Length: 162 Connection: keep-alive Location: https://www.example.com
Configuring a Temporary Redirection Rule
To temporarily redirect an access request to a target website (status code 302), use the nginx.ingress.kubernetes.io/temporal-redirect annotation. For example, to temporarily redirect all access requests to www.example.com, run the following command:
nginx.ingress.kubernetes.io/temporal-redirect: https://www.example.com
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: nginx.ingress.kubernetes.io/temporal-redirect: https://www.example.com spec: rules: - host: '' http: paths: - path: / backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginxFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx nginx.ingress.kubernetes.io/temporal-redirect: https://www.example.com spec: rules: - host: '' http: paths: - path: / backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with your target Service port. - Create an ingress.
kubectl get ingress
curl -I ${ELB_IP}The access path will be temporarily redirected to www.example.com, and the status code is 302.
HTTP/1.1 302 Moved Temporarily Date: Sat, 20 Jul 2024 08:01:02 GMT Content-Type: text/html Content-Length: 138 Connection: keep-alive Location: https://www.example.com
Redirecting HTTP to HTTPS
By default, if an ingress uses TLS, requests will be redirected (status code 308) to HTTPS when HTTP is used for access. You can configure the redirection by using the nginx.ingress.kubernetes.io/ssl-redirect annotation.
- If the value of this annotation is set to true, an HTTP access is redirected to HTTPS (status code 308) when the TLS certificate is used.
- If the value of this annotation is set to false, an HTTP access cannot be redirected to HTTPS when the TLS certificate is used.
If you need to forcibly redirect an HTTP access to HTTPS without a TLS, you can configure the redirection by setting the value of nginx.ingress.kubernetes.io/force-ssl-redirect to true.
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: nginx.ingress.kubernetes.io/force-ssl-redirect: 'true' spec: rules: - host: '' http: paths: - path: / backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginxFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx nginx.ingress.kubernetes.io/force-ssl-redirect: 'true' spec: rules: - host: '' http: paths: - path: / backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with your target Service port. - Create an ingress.
kubectl get ingress
curl -I ${ELB_IP}The access path will be redirected to HTTPS, and the status code is 308.
HTTP/1.1 308 Permanent Redirect Date: Sat, 20 Jul 2024 08:03:36 GMT Content-Type: text/html Content-Length: 164 Connection: keep-alive Location: https://${ELB_IP}
