Situation Awareness
Creating a Node Scaling Policy
Updated on 2024-01-26 GMT+08:00
CCE provides auto scaling through the autoscaler add-on. Nodes with different specifications can be automatically added across AZs on demand.
If a node scaling policy and the configuration in the autoscaler add-on take effect at the same time, for example, there are pods that cannot be scheduled and the value of a metric reaches the threshold at the same time, scale-out is performed first for the unschedulable pods.
  • If the scale-out succeeds for the unschedulable pods, the system skips the metric-based rule logic and enters the next loop.
  • If the scale-out fails for the unschedulable pods, the metric-based rule is executed.
Before using the node scaling function, you must install the autoscaler add-on of v1.13.8 or later in the cluster.
  • Auto scaling policies apply to node pools. When the number of nodes in a node pool is 0 and the scaling policy is based on CPU or memory usage, node scaling is not triggered.
  • Node scale-in will cause PVC/PV data loss for the local PVs associated with the node. These PVCs and PVs cannot be restored or used again. In a node scale-in, the pod that uses the local PV is evicted from the node. A new pod is created and stays in the pending state. This is because the PVC used by the pod has a node label, due to which the pod cannot be scheduled.
  • When autoscaler is used, some taints or annotations may affect auto scaling. Therefore, do not use the following taints or annotations in clusters:
    • ignore-taint.cluster-autoscaler.kubernetes.io: The taint works on nodes. Kubernetes-native autoscaler supports protection against abnormal scale outs and periodically evaluates the proportion of available nodes in the cluster. When the proportion of non-ready nodes exceeds 45%, protection will be triggered. In this case, all nodes with the ignore-taint.cluster-autoscaler.kubernetes.io taint in the cluster are filtered out from the autoscaler template and recorded as non-ready nodes, which affects cluster scaling.
    • cluster-autoscaler.kubernetes.io/enable-ds-eviction: The annotation works on pods, which determines whether DaemonSet pods can be evicted by autoscaler. For details, see Well-Known Labels, Annotations and Taints.
  2. Choose Node Scaling in the navigation pane.
    • If Uninstalled is displayed next to the add-on name, click Install, set add-on parameters as required, and click Install to install the add-on.
    • If Installed is displayed next to the add-on name, the add-on has been installed.
  3. Click Create Node Scaling Policy in the upper right corner and set the parameters as follows:
    • Policy Name: name of the policy to be created, which can be customized.
    • Associated Node Pools: Select the node pool to be associated. You can associate multiple node pools to use the same scaling policy.
    • Rules: Click Add Rule. In the dialog box displayed, set the following parameters:
      Rule Name: Enter a rule name.
      Rule Type: You can select Metric-based or Periodic. The differences between the two types are as follows:
      • Metric-based:
        Condition: Select CPU allocation rate or Memory allocation rate and enter a value. The value must be greater than the scale-in percentage configured in the autoscaler add-on.
        • Resource allocation (%) = Resources requested by pods in the node pool/Resources allocatable to pods in the node pool
        • If multiple rules meet the conditions, the rules are executed in either of the following modes:
          If rules based on the CPU allocation rate and memory allocation rate are configured and two or more rules meet the scale-out conditions, the rule that will add the most nodes will be executed.
          If a rule based on the CPU allocation rate and a periodic rule are configured and they both meet the scale-out conditions, one of them will be executed randomly. The rule executed first (rule A) changes the node pool to the scaling state. As a result, the other rule (rule B) cannot be executed. After rule A is executed and the node pool status becomes normal, rule B will not be executed.
        • If rules based on the CPU allocation rate and memory allocation rate are configured, the policy detection period varies with the processing logic of each loop of the autoscaler add-on. Scale-out is triggered once the conditions are met, but it is constrained by other factors such as the cool-down interval and node pool status.
      • Periodic:
        Trigger Time: You can select a specific time point every day, every week, every month, or every year.
      Action: Set an action to be performed when the trigger condition is met.
      You can click Add Rule again to add more node scaling policies. You can add a maximum of one CPU usage-based rule and one memory usage-based rule. The total number of rules cannot exceed 10.
  4. Click OK.
Constraints on Scale-in
You can set node scale-in policies only when installing the autoscaler add-on.
Node scale-in can be triggered only by the resource allocation rate. When CPU and memory allocation rates in a cluster are lower than the specified thresholds (set when the autoscaler add-on is installed or modified), scale-in is triggered for nodes in the node pool (this function can be disabled).
Example YAML
The following is a YAML example of a node scaling policy:
apiVersion: autoscaling.cce.io/v1alpha1
kind: HorizontalNodeAutoscaler
  creationTimestamp: "2020-02-13T12:47:49Z"
  generation: 1
  namespace: kube-system
  resourceVersion: "11433270"
  selfLink: /apis/autoscaling.cce.io/v1alpha1/namespaces/kube-system/horizontalnodeautoscalers/xxxx
  uid: c2bd1e1d-60aa-47b5-938c-6bf3fadbe91f
  disable: false
  rules:
  - action:
      type: ScaleUp
      unit: Node
      value: 1
    cronTrigger:
      schedule: 47 20 * * *
    disable: false
    ruleName: cronrule
    type: Cron
  - action:
      type: ScaleUp
      unit: Node
      value: 2
    disable: false
    metricTrigger:
      metricName: Cpu
      metricOperation: '>'
      metricValue: "40"
      unit: Percent
    ruleName: metricrule
    type: Metric
  targetNodepoolIds:
  - 7d48eca7-3419-11ea-bc29-0255ac1001a8
Table 1 Key parameters
Type
spec.disable
Bool
Whether to enable the scaling policy. This parameter takes effect for all rules in the policy.
spec.rules
Array
All rules in a scaling policy.
spec.rules[x].ruleName
String
Rule name.
spec.rules[x].type
String
Rule type. Currently, Cron and Metric are supported.
spec.rules[x].disable
Bool
Rule switch. Currently, only false is supported.
spec.rules[x].action.type
String
Rule action type. Currently, only ScaleUp is supported.
spec.rules[x].action.unit
String
Rule action unit. Currently, only Node is supported.
spec.rules[x].action.value
Integer
Rule action value.
spec.rules[x].cronTrigger
Optional. This parameter is valid only in periodic rules.
spec.rules[x].cronTrigger.schedule
String
Cron expression of a periodic rule.
spec.rules[x].metricTrigger
Optional. This parameter is valid only in metric-based rules.
spec.rules[x].metricTrigger.metricName
String
Metric of a metric-based rule. Currently, Cpu and Memory are supported.
spec.rules[x].metricTrigger.metricOperation
String
Comparison operator of a metric-based rule. Currently, only > is supported.
spec.rules[x].metricTrigger.metricValue
String
Metric threshold of a metric-based rule. The value can be any integer from 1 to 100 and must be a character string.
spec.rules[x].metricTrigger.Unit
String
Unit of the metric-based rule threshold. Currently, only % is supported.
spec.targetNodepoolIds
Array
All node pools associated with the scaling policy.
spec.targetNodepoolIds[x]
String
ID of the node pool associated with the scaling policy.
