Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Buying a Cluster/ Comparing iptables, nftables, and IPVS
Updated on 2026-09-21 GMT+08:00
kube-proxy is a key component of a Kubernetes cluster. It is used for load balancing and forwarding data between a Service and its backend pods.
CCE supports the following Service forwarding modes: iptables, nftables (v1.35 and later), and IPVS. The table below summarizes the key characteristics of each option.
Feature Difference
nftables
iptables
IPVS
Positioning
A high-performance kube-proxy mode that eliminates iptables' performance bottlenecks and scalability limitations at scale. It provides a unified configuration framework for multi-protocol rule management. For details, see nftables.
A mature, stable kube-proxy mode, but its performance is average. It applies to scenarios where the number of Services is small (less than 3,000) or there are a large number of short concurrent connections on the client. For details, see iptables.
A high-performance kube-proxy mode. This mode is suitable for large cluster scales or when there are a large number of Services. For details, see IPVS.
Throughput
Relatively high
Relatively low
Relatively high
Complexity
O(1) or O(log n). Rule processing overhead typically remains constant regardless of cluster size.
O(n). n increases with the number of Services and backend pods in the cluster.
O(1). In most cases, the connection processing efficiency is irrelevant to the cluster scale.
Load balancing algorithm
Random, round-robin
Random, round-robin
Round-robin, shortest expected delay, least connection, and various hashing methods
ClusterIP connectivity
ClusterIP addresses cannot be pinged.
ClusterIP addresses can be pinged.
The IP address in clusters of v1.27 or later cannot be pinged due to security hardening.
Additional restrictions
Available in CCE clusters v1.35 and later.
When there are more than 3000 Services in a cluster, network delay may occur.
  • If you have an IPVS-backed cluster, kube-proxy mounts the Service's load balancer address to the ipvs-0 bridge, which will intercept the traffic from within the cluster to the load balancer. In this case, there may be the following access exceptions:
    • If you use the same load balancer for both a LoadBalancer ingress and Service, the ipvs-0 bridge will intercept the traffic from the cluster to the ingress and redirect it to the Service, resulting in an access failure.
    • If you use the same load balancer for a Service in the current cluster and a Service in another cluster, the ipvs-0 bridge will intercept the traffic to the Service in another cluster and redirect the traffic to the Service in the current cluster, resulting in an access failure.
    • If a range of listening ports is configured for a Service (for example, the port range is 30000–30005), only the port (30000) configured in spec.ports can be accessed in the cluster. The other ports (30001–30005) cannot be accessed because the ipvs-0 bridge intercepts the traffic.
    You can perform the operations in Configuring Passthrough Networking for a LoadBalancer Service to prevent kube-proxy from forwarding the Service's load balancer traffic from the cluster.
  • EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04 are not recommended. For details, see What Should I Do If There Is a Service Access Failure After a Backend Service Upgrade or a 1-Second Latency When a Service Accesses a CCE Cluster?
nftables
nftables is a high-performance packet filtering and management framework built into the Linux kernel, designed to replace iptables. It eliminates performance bottlenecks and scalability limitations while providing more efficient and flexible network traffic control. Built on the Netfilter hook mechanism, nftables uses a unified configuration framework to integrate rule management across multiple protocols (IPv4, IPv6, ARP, and others), eliminating the need for separate per-protocol rule sets. It also optimizes rule matching through hash-based data structures, improving efficiency in high-concurrency scenarios.
In nftables mode, kube-proxy uses nftables instead of iptables to configure packet forwarding and NAT rules. Compared with iptables, nftables offers simpler syntax and more flexible rule organization. It supports incremental rule updates by modifying individual rules without replacing the entire rule set, thereby optimizing rule management performance in large-scale service scenarios and better accommodating Kubernetes cluster growth. For details, see nftables proxy mode.
To enable kube-proxy to use nftables for packet forwarding, nodes must run kernel version 5.13 or later and nftables version 1.0.1 or later.
iptables
iptables is a Linux kernel function for processing and filtering a large number of data packets. It allows flexible sequences of rules to be attached to various hooks in the packet processing pipeline. When iptables is used, kube-proxy implements NAT and load balancing in the NAT pre-routing hook. For each Service, kube-proxy installs an iptables rule which captures the traffic destined for the Service's ClusterIP and ports and redirects the traffic to one of the backend pods. By default, iptables randomly selects a backend pod. For details, see iptables proxy mode.
IPVS
IPVS is constructed on top of Netfilter and balances transport-layer loads as part of the Linux kernel. IPVS can direct requests for TCP- or UDP-based services to the real servers, and make services of the real servers appear as virtual services on a single IP address.
In the IPVS mode, kube-proxy uses IPVS load balancing instead of iptables. IPVS is designed to balance loads for a large number of Services. It has a set of optimized APIs and uses optimized search algorithms instead of simply searching for rules from a list. For details, see IPVS proxy mode.
Helpful Links
