Using DSS Through a Static PV
CCE allows you to create a PV using an existing DSS disk. After the PV is created, you can create a PVC and bind it to the PV. This mode applies to scenarios where underlying storage is available.
  • You have created a DSS disk that meets the following requirements:
    • The DSS disk cannot be a system disk or shared disk.
    • The DSS disk must be of the SCSI type (the default disk type is VBD when you create a DSS disk).
    • The DSS disk must be available and not used by other resources.
    • If the DSS disk is encrypted, the key must be available.
    • The DSS disk must be in the default enterprise project or the enterprise project to which the cluster belongs.
Notes and Constraints
  • DSS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If a DSS disk is attached to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, select only one pod when creating a Deployment that uses DSS.
  • If an HPA policy is used to expand the capacity of a workload with a DSS disk attached, new pods cannot be started because the DSS disk cannot attach to them.
Using an Existing DSS Disk on the Console
  2. Statically create a PVC and PV.
    1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
      PVC Type
      In this example, select DSS.
      PVC Name
      Enter the PVC name, which must be unique in a namespace.
      Creation Method
      • If underlying storage is available, create a PV or use an existing PV to statically create a PVC.
      • If no underlying storage is available, select Dynamically provision. For details, see Using DSS Through a Dynamic PV.
      In this example, select Create new to create both a PV and PVC on the console.
      PVa
      Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
      You do not need to specify this parameter in this example.
      DSSb
      Click Select DSS. On the displayed page, select the DSS volume that meets your requirements and click OK.
      PV Nameb
      Enter the PV name, which must be unique in the same cluster.
      Access Modeb
      DSS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode.
      Reclaim Policyb
      You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted.
      a: The parameter is available when Creation Method is set to Use existing.
      b: The parameter is available when Creation Method is set to Create new.
    2. Click Create to create a PVC and a PV.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tab pages, respectively.
  3. Create an application.
    1. Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
      Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing DSS volume.
      A DSS volume can be mounted to only one workload.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. Otherwise, containers will be malfunctional. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
      Subpath
      Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the DSS disk.
      A non-shared DSS disk can be attached to only one workload pod. If there are multiple pods, extra pods cannot start properly. Ensure that the number of workload pods is 1 if a DSS disk is attached.
      If multiple workload pods are needed, create a StatefulSet and dynamically mount a PV to each pod. For details, see Dynamically Mounting a DSS Disk to a StatefulSet.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
Using an Existing DSS Disk Through kubectl
  1. Use kubectl to access the cluster.
  2. Create a PV. If a PV has been created in your cluster, skip this step.
    1. Create the pv-dss.yaml file.
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: everest-csi-provisioner
          everest.io/reclaim-policy: retain-volume-only         # (Optional) The underlying volume is retained when the PV is deleted.
        name: pv-dss    # PV name
        labels:
          failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed
          failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed
        accessModes:
          - ReadWriteOnce     # Access mode, which must be ReadWriteOnce for DSS
        capacity:
          storage: 10Gi       # Disk capacity, in the unit of GiB. The value ranges from 1 to 32768.
        csi:
          driver: disk.csi.everest.io     # Dependent storage driver for the mounting
          fsType: ext4    # Must be the same as that of the original file system of the disk.
          volumeAttributes:
            everest.io/disk-mode: SCSI           # Device type of the DSS disk. Only SCSI is supported.
            everest.io/disk-volume-type: SAS     # Disk type
            everest.io/csi.dedicated-storage-id: <dss_id>     # ID of the DSS storage pool
            storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
            everest.io/crypt-key-id: <your_key_id>    # (Optional) Encryption key ID. Mandatory for an encrypted disk.
            everest.io/enterprise-project-id: <your_project_id>  # (Optional) Enterprise project ID. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
        persistentVolumeReclaimPolicy: Delete    # Reclaim policy
        storageClassName: csi-disk-dss              # Storage class name of the DSS disk
      Table 2 Key parameters
      Mandatory
      No
      Optional.
      Only retain-volume-only is supported.
      This parameter is valid only when the Everest version is 1.2.9 or later and the reclaim policy is Delete. If the reclaim policy is Delete and the current value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
      Yes
      Region where the cluster is located.
      For details about the value of region, see Regions and Endpoints.
      Yes
      AZ where the DSS volume is created. It must be the same as the AZ planned for the workload.
      For details about the value of zone, see Regions and Endpoints.
      fsType
      Yes
      File system type, which defaults to ext4.
      Yes
      Disk type. All letters are in uppercase.
      • SAS: high I/O
      • SSD: ultra-high I/O
      Yes
      ID of the DSS storage pool where the DSS disk resides.
      To obtain a DSS storage pool ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Storage Pools and click the name of the target storage pool. On the resource pool details page, copy the pool ID.
      No
      Mandatory when the disk is encrypted. Enter the encryption key ID selected during disk creation.
      To obtain an encryption key ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Disks. Click the name of the target disk to go to its details page. On the Summary tab page, copy the value of KMS Key ID in the Configuration Information area.
      No
      Optional.
      Enterprise project ID of DSS. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
      To obtain an enterprise project ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Disks. Click the name of the target disk to go to its details page. On the Summary tab page, click the enterprise project in Management Information to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the DSS disk belongs.
      Yes
      The Delete and Retain reclaim policies are supported. If high data security is required, select Retain to prevent data from being deleted by mistake.
      Delete:
      • If everest.io/reclaim-policy is not specified, both the PV and DSS disk will be deleted when a PVC is deleted.
      • If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the DSS disk will be retained.
      Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
      storageClassName
      Yes
      The storage class for DSS disks is csi-disk-dss.
    2. Run the following command to create a PV:
      kubectl apply -f pv-dss.yaml
  3. Create a PVC.
    1. Create the pvc-dss.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
        labels:
        accessModes:
        - ReadWriteOnce               # The value must be ReadWriteOnce for DSS.
        resources:
          requests:
            storage: 10Gi             # Disk capacity, ranging from 1 to 32768. The value must be the same as the storage size of the existing PV.
        storageClassName: csi-disk-dss    # StorageClass is DSS.
        volumeName: pv-dss            # PV name
      Table 3 Key parameters
      Mandatory
      Yes
      Yes
      AZ where the disk is created. It must be the same as the AZ planned for the workload.
      Yes
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      volumeName
      Yes
      PV name, which must be the same as the PV name in 1.
      storageClassName
      Yes
      Storage class name, which must be the same as the storage class of the PV in 1.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-dss.yaml
  4. Create an application.
    1. Create a file named web-dss.yaml. In this example, the disk is mounted to the /data path.
      apiVersion: apps/v1
      kind: StatefulSet
        namespace: default
        replicas: 1
        selector:
          matchLabels:
            app: web-dss
        serviceName: web-dss   # Headless Service name
        template:
            labels:
              app: web-dss
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-disk-dss    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-disk-dss    # Volume name, which can be customized
                persistentVolumeClaim:
                  claimName: pvc-dss    # Name of the created PVC
      apiVersion: v1
      kind: Service
        name: web-dss   # Headless Service name
        namespace: default
        labels:
          app: web-dss
        selector:
          app: web-dss
        clusterIP: None
        ports:
          - name: web-dss
            targetPort: 80
            nodePort: 0
            port: 80
            protocol: TCP
        type: ClusterIP
    2. Run the following command to create a workload to which the DSS volume is mounted:
      kubectl apply -f web-dss.yaml
  1. View the deployed application and DSS volume files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep web-dss
      Expected output:
      web-dss-0                  1/1     Running   0               38s
    2. Run the following command to check whether the DSS volume has been mounted to the /data path:
      kubectl exec web-dss-0 -- df | grep data
      Expected output:
      /dev/sdc              10255636     36888  10202364   0% /data
    3. Run the following command to check the files in the /data path:
      kubectl exec web-dss-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-dss-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-dss-0:
    kubectl delete pod web-dss-0
    Expected output:
    pod "web-dss-0" deleted
  5. After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
    Expected output:
    lost+found
    static
    The static file is retained, indicating that the data in the DSS volume can be stored persistently.
Related Operations
You can also perform the operations listed in Table 4.
Table 4 Related operations
Operation
Creating a storage volume (PV)
Create a PV on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVs tab. Click Create PersistentVolume in the upper right corner. In the dialog box displayed, configure parameters.
    • Volume Type: Select DSS.
    • DSS: Click Select DSS. On the displayed page, select the disk that meets your requirements and click OK.
    • PV Name: Enter the PV name, which must be unique in a cluster.
    • Access Mode: DSS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode.
    • Reclaim Policy: Delete or Retain is supported.
  2. Click Create.
Expanding the capacity of DSS storage
Quickly expand the capacity of an attached DSS disk on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click More in the Operation column of the target PVC and select Scale-out.
  2. Enter the capacity to be added and click OK.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
