Updated on 2026-09-21 GMT+08:00
Agency Permissions
Cloud Native Cost Governance works closely with cloud services such as CCE, AOM, OBS, and CBC for cost governance. When you use Cloud Native Cost Governance for the first time, you need to use an account with the Security Administrator permissions to grant the cloud resource permissions of the current region to CCE.
To minimize authorization, CCE fine-grained permissions are optimized. The permissions defined by system policies are now defined using API actions. (Each API has one API action.) If you have authorized the cloud services, you can optimize the permissions in one click.
After you agree to the authorization, agencies are automatically created in IAM to delegate required resource operation permissions in your account to Huawei Cloud CCE and Huawei Cloud AOM. For details about agencies, see Cloud Service Agency. The following are agencies automatically created in IAM:
  • cia_admin_trust
    This agency is used to delegate the permissions required by the O&M modules to access other cloud services.
    To use O&M modules in multiple regions, you need to apply for the Tenant Guest, CCE Administrator, and SWR Administrator permissions in each region. (Go to the IAM console, choose Agencies, and click cia_admin_trust to view the authorization records in each region.)
  • aom_admin_trust
    For details about this agency, see Authorizing AOM to Access Other Cloud Services.
O&M modules may fail to run as expected if the required permissions are not granted. When using O&M modules, do not delete or modify cia_admin_trust and aom_admin_trust.
Permissions Before Optimization
Table 1 cia_admin_trust permissions
Granted To
Policy/Role
CCE
IAM ReadOnlyAccess
IAM users need to be able to access Monitoring Center and Alarm Center.
CCE
Tenant Guest
Monitoring Center and Alarm Center check the configurations of global resources (for example OBS or DNS) associated with clusters to identify invalid or inappropriate configurations.
CCE
CCE Administrator
Monitoring Center and Alarm Center need to be able to access CCE to obtain information about clusters, nodes, workloads, and other resources, so that they can help ensure resource health.
CCE
SWR Administrator
Monitoring Center and Alarm Center need to be able to access SWR to obtain image information.
CCE
SMN Administrator
Monitoring Center and Alarm Center need to be able to access SMN to obtain contact groups.
CCE
AOM Administrator
Monitoring Center and Alarm Center need to be able to access AOM to obtain metrics.
CCE
LTS Administrator
Monitoring Center and Alarm Center need to be able to access LTS to obtain logs.
Table 2 aom_admin_trust permissions
Granted To
Policy/Role
AOM
DMS UserAccess
AOM obtains subscription data from DMS.
AOM
ECS CommonOperations
AOM obtains system metrics and logs using UniAgents and ICAgents installed on ECSs.
AOM
CES ReadOnlyAccess
AOM synchronizes metrics from Cloud Eye.
AOM
CCE FullAccess
AOM synchronizes container metrics from CCE.
AOM
RMS ReadOnlyAccess
AOM CMDB manages cloud service instances.
AOM
ECS ReadOnlyAccess
AOM
LTS FullAccess
AOM obtains logs from LTS.
AOM
CCI FullAccess
AOM synchronizes container metrics from CCI.
Permissions After Optimization
Table 3 cia_admin_trust permissions
Policy Name
Policy Type
Policy Scope
Permission Set
CCE Administrator
System-defined policy
Project
cce:*:*
CCE administrator permissions
CIACostGlobalPolicy
Custom policy
Global
obs:object:GetObject
Obtains object content and metadata.
obs:bucket:HeadBucket
Obtains bucket metadata.
obs:bucket:CreateBucket
Creates a bucket.
obs:bucket:ListBucket
Lists objects in a bucket.
OBS:*:*:object:cost/daily_cost_{region_id}
Resource object path restriction
OBS:*:*:bucket:cce-cost-{region_id}-{domain_id}
Resource bucket limit
CIACostProjectPolicy
Custom policy
Project
cce:cluster:get
Obtains details about a cluster.
cce:cluster:list
Lists all clusters.
cce:addonInstance:list
Lists all add-on instances.
cce:addonInstance:create
Creates an add-on instance.
cce:addonInstance:delete
Deletes an add-on instance.
cce:addonInstance:update
Updates an add-on instance.
cce:node:get
Obtains details about a node.
cce:node:list
Lists nodes.
cce:nodepool:list
Lists all node pools in a cluster.
aom:metric:set
Modifies monitoring configuration.
aom:metric:get
Queries details about a metric.
aom:metric:list
Lists metrics.
aom:agency:get
Queries AOM authorization.
bss:costtag:update
Activates or deactivates cost tags.
bss:costtag:view
Views cost tags.
bss:costdetailreport:view
Views the task list for exporting cost details to OBS.
bss:costdetailreport:update
Creates, modifies, or deletes the tasks of exporting cost details to OBS.
apm:icmgr:get
Obtains AOM 2.0 permissions.
apm:icmgr:create
Grants AOM 2.0 permissions.
Table 4 aom_admin_trust permissions
Policy Name
Policy Type
Policy Scope
Permission Set
AOM Global Access
Custom policy
Global
rms:*:list
Lists RMS resources.
rms:*:get
Queries details about an RMS resource.
rms:resources:listTagsForResource
Lists resource tags.
Lists project tags.
rms:resources:listResourcesByTag
List resource instances.
AOM UserAccess
Custom policy
Project
lts:topics:*
Full permissions for performing operations on log topics
lts:groups:*
Full permissions for performing operations on log groups
aom:metric:*
Full permissions for performing operations on a metric (AOM)
aom:cmdbSubApplication:*
Full permissions for performing operations on a sub-application (AOM)
aom:cmdbResources:*
Full permissions for performing operations on resources (AOM)
aom:cmdbEnvironment:*
Full permissions for performing operations on the environment (AOM)
aom:cmdbComponent:*
Full permissions for performing operations on a component (AOM)
aom:cmdbApplication:*
Full permissions for performing operations on an application (AOM)
ecs:cloudServers:showServer
Queries details about an ECS.
ecs:cloudServers:list
Lists ECSs.
dms:instance:get
Queries details about a DMS instance.
ces:metrics:list
Lists metrics (Cloud Eye).
ces:metricData:list
Queries metrics (Cloud Eye).
cci:namespace:list
Lists all namespaces.
cce:cluster:list
Lists all clusters.
cce:cluster:get
cce:node:list
List nodes.
cce:node:get
apm:icmgr:*
Full permissions for performing operations on the APM collection component
lts:*:*
Full permissions for performing operations on LTS logs
aom:*:list
Lists AOM instances.
