Updated on 2026-09-21 GMT+08:00
Creating a CustomedHPA Policy
HPA can automatically adjust the number of pods based on the CPU usage and memory usage. However, as application complexity increases and service requirements diversify, enterprises and developers find that this basic policy may not meet needs in some specific scenarios. For example, the loads of some applications may change sharply in a specific period of time, or more refined control (such as the scaling step) is required based on metrics.
Enhanced based on HPA, CustomedHPA provides more flexible, diverse auto scaling capabilities to meet complex, changing service requirements. It scales Deployment pods based on metrics (CPU usage and memory usage) or periodically (daily, weekly, monthly, or yearly at a specific time).
Supported functions:
  • Scaling based on the percentage of the current number of pods: You can configure the scaling percentage to adjust the number of pods for different loads more flexibly.
  • Minimum step for a scaling action: You can configure the minimum step to avoid frequent scaling adjustments, reducing system overhead and resource fluctuations.
  • Different scaling actions based on actual metric values: You can define multiple metric thresholds and corresponding scaling policies, so that the system can handle different loads.
To use CustomedHPA policies, you must install CCE Advanced HPA. If the add-on version is earlier than 1.2.11, prometheus must be installed. If the add-on version is 1.2.11 or later, you must install an add-on that provides the Metrics API. Select one of the following add-ons based on your cluster version and requirements:
  • CustomedHPA policies apply only to clusters v1.15 or later.
  • For clusters earlier than v1.19.10, if a CustomedHPA policy is used to scale out a workload with an EVS volume mounted, existing pods lose access to the volume while it is being unmounted and mounted to the node where a new pod is scheduled.
    For clusters v1.19.10 and later, if a CustomedHPA policy is used to scale out a workload with an EVS volume mounted, new pods cannot start because the EVS volume cannot be mounted to multiple nodes simultaneously.
  • The specifications of the CCE Advanced HPA add-on are determined based on the total number of containers in the cluster and the number of scaling policies. Configure 500m and 1,000 MiB of memory for every 5,000 containers, and 100m and 500 MiB of memory for every 1,000 scaling policies.
  • After a CustomedHPA policy is created, the type of its associated workload cannot be changed.
  2. Choose Workloads in the navigation pane. Locate the target workload and choose More > Auto Scaling in the Operation column.
  3. Set Policy Type to CustomedHPA and configure policy parameters.
    Table 1 CustomedHPA policy parameters
    Pod Range
    Minimum and maximum numbers of pods.
    When a policy is triggered, the workload pods are scaled within this range.
    NOTICE:
    In CCE Turbo clusters, if you use a dedicated load balancer for your workload, the number of pods cannot exceed the backend server group quota of the load balancer, which is 500 by default. If you exceed this limit, you will not be able to add any more pods to the load balancer backend.
    Cooldown Period
    Enter an interval, in minutes.
    This parameter indicates the interval between consecutive scaling operations. The cooldown period ensures that a scaling operation is initiated only when the previous one is completed and the system is running stably.
    If you are using CCE Advanced HPA of v1.3.10 or later, the cooldown period will only apply to metric policies. Periodic policies will not be affected by the cooldown period.
    Rule
    Click . In the dialog box displayed, configure the scaling policy parameters.
    • Type: You can select Metric-based (Table 2) or Periodic (Table 3). Then, configure trigger conditions and actions.
    • Enable: Enable or disable the policy rule.
    After configuring the preceding parameters, click OK. Then, the added policy rule is displayed in the rule list.
    Table 2 Metric-based rules
    Trigger
    Select CPU usage or Memory usage, choose > or <, and enter a percentage.
    Usage = Average resource usage of all pods in a workload/Requested resources
    Action
    Set an action to be performed when the trigger condition is met. Multiple actions can be added.
    • Scale To: Adjust the number of pods to the specified value. Both a number and a percentage will do. This action can be used to scale in or out pods. If the current number of pods is less than the target value or the target percentage is greater than 100%, the number of pods will be scaled out to the target value. If the current number of pods is greater than the target value or the target percentage is less than 100%, the number of pods will be scaled in to the target value.
    • Add: Configure this parameter when Trigger is set to >. Add the number of pods. You can specify a number or a percentage. This action can only be used to scale out pods.
    • Reduce: Configure this parameter when Trigger is set to <. Reduce the number of pods. You can specify a number or a percentage. This action can only be used to scale in pods.
    You can enter a number or a percentage for the preceding actions.
    When entering a percentage, you are required to specify the minimum number of available pods. Final number of pods = Current number of pods x Percentage. The result is rounded up. If the result is smaller than the minimum number of available pods, the preset value is used. Otherwise, the calculation result is used.
    As shown below, when the CPU usage exceeds 50%, the number of pods is scaled out to 5. When the CPU usage exceeds 70%, the number of pods is scaled out to 8. When the CPU usage exceeds 90%, the number of pods is scaled out to 18 (adding 10 more pods). These rules also work for scale-in operations.
    Figure 1 Setting a trigger condition
    Table 3 Periodic-based rules
    Trigger Time
    You can select a specific time every day, every week, every month, or every year.
    Action
    Set an action to be performed at the Triggered Time. As shown below, one pod will be added at 17:00 every day.
    • Add: Add the number of pods. You can specify a number or a percentage. This action can only be used to scale out pods.
    • Reduce: Reduce the number of pods. You can specify a number or a percentage. This action can only be used to scale in pods.
    Figure 2 Periodic triggering (Daily)
  4. Click Create.
Using kubectl
A CustomedHPA policy is a CustomResourceDefinition (CRD) and can be defined as follows in YAML:
apiVersion: autoscaling.cce.io/v1alpha1
kind: CustomedHorizontalPodAutoscaler
  namespace: default
  coolDownTime: 3m             # Cooldown period
  maxReplicas: 10              # Maximum number of pods
  minReplicas: 1               # Minimum number of pods
  rules:
    - actions:                          # Policy rules
        - metricRange: 0,0.1            # Metric range: 0 to 10% (exclusive)
          operationType: ScaleDown      # Scaling type. ScaleDown indicates downsizing.
          operationUnit: Task           # Operation unit. Task indicates the number of tasks.
          operationValue: 1             # Resource quantity in each scaling
        - metricRange: 0.1,0.3          # Metric range: 10% to 30% (exclusive)
          operationUnit: Task
          operationValue: 2
      disable: false                    # Whether to disable this rule
      metricTrigger:                    # Trigger condition
        hitThreshold: 1
        metricName: CPURatioToRequest   # Metric name, where CPURatioToRequest indicates the CPU usage, and MemoryRatioToRequest indicates the memory usage.
        metricOperation: <              # Metric expression operator, indicating that the rule is triggered when the metric value is less than metricValue.
        metricValue: 0.3                # Value on the right of the metric expression
        periodSeconds: 60
        statistic: instantaneous
      ruleName: low                     # Rule name
      ruleType: Metric                  # Rule type, indicating that the rule is triggered by metric
    - actions:
        - metricRange: 0.7,0.9
          operationType: ScaleUp
          operationUnit: Task
          operationValue: 1
        - metricRange: 0.9,+Infinity
          operationUnit: Task
          operationValue: 2
      disable: false
      metricTrigger:
        hitThreshold: 1
        metricOperation: '>'
        metricValue: 0.7
        periodSeconds: 60
      ruleName: high
      ruleType: Metric
  scaleTargetRef:                # Associated workload
    apiVersion: apps/v1
    kind: Deployment
Helpful Links
