Updated on 2026-09-21 GMT+08:00
Creating a VPA Policy
Kubernetes Vertical Pod Autoscaler (VPA) scales pods vertically. It does this by analyzing the historical usage of container resources and automatically adjusting the CPU and memory resources requested by pods. VPA can adjust container resource requests within a specific range to match the service load. It increases the resource requests when the service load increases and reduces them when the service load decreases to conserve computing resources. Additionally, VPA can provide recommendations on CPU and memory requests to optimize container resource utilization while ensuring that the containers have enough resources to function properly.
Overview
VPA collects and analyzes resource metrics for each container, adjusts the requested resources based on actual usage, and maintains the ratio of resource limit to request before and after the adjustment. VPA can increase or decrease CPU and memory resources as needed.
The rules are as follows:
  • VPA generates the CPU and memory resource recommendations using the data collected by the Metrics API.
  • VPA, in theory, recommends a minimum of 250 MiB of memory for each pod and 250 MiB divided by the number of containers in the pod for each container. It also recommends a minimum of 25m vCPUs for each pod and 25m divided by the number of containers in the pod for each container.
    When setting up a VPA, you can establish the minimum and maximum number of elastic resources in containers by configuring the containerPolicies field.
  • If a container has both resource request and limit configured, VPA will provide resource recommendations. It will adjust the requested resources of the container to match the recommendations and generate recommended resource limit based on the ratio of the original resource request to the limit set during the container's initial creation.
    Assume that the requested vCPUs of a container are 100m and the limit is 200m (with a ratio of 1:2). If VPA recommends a requested vCPU of 80m, the container's vCPU limit will be 160m.
  • VPA ensures its recommendations align with other resource limits. If the VPA recommendations conflict with a resource limit, they will not be adjusted to fit the limit. This means that the resource configuration suggested by VPA may go beyond other resource limits.
    Assume that the requested memory of a namespace cannot exceed 2 GiB. If VPA recommends a high memory configuration for a pod in that namespace, the total memory requested by the namespace may exceed 2 GiB after the pod's resource configuration is updated. This means the pod will not be scheduled.
  • VPA introduces the InPlaceOrRecreate policy, which first attempts to adjust a pod's requested resources in place without restarting it. Pod recreation is triggered only when necessary, such as, when an in-place upgrade fails, minimizing service interruption. During an in-place upgrade, all containers in the pod are updated simultaneously. Partial updates that change only some containers are not supported.
    After the in-place upgrade feature is enabled, VPA will try to perform in-place updates in scenarios where:
    • Containers experience rapid OOM events.
    • The requested resources exceed the recommended range.
    • A pod has been running for a long time (over 12 hours by default), and the difference between its current and recommended resource values exceeds 10%.
    Although in-place upgrades reduce service downtime, some pods may not support in-place upgrades during resizing. In such cases, VPA falls back to the Recreate policy, which still cannot guarantee zero interruption.
    An in-place upgrade may fail, causing VPA to fall back to the Recreate policy, in the following situations:
    • A pod's in-place upgrade status becomes Infeasible (for example, the requested resources exceed the node capacity).
    • A pod's in-place upgrade status remains in Deferred for more than 5 minutes.
    • A pod upgrade takes longer than 1 hour.
    • The resource adjustment causes a QoS class change for a pod (for example, from BestEffort to Guaranteed).
    • If a pod's resizePolicy is set to PreferNoRestart (the default), the memory limit cannot be decreased.
  • The Vertical Pod Autoscaler (VPA) add-on has been installed in the cluster.
  • To use VPA's in-place pod upgrades, the cluster version must be v1.33 or later, and the VPA add-on of 1.1.1 or later must be installed.
Precautions
The container vertical scaling feature is currently in beta. Exercise caution when applying it to actual services after evaluation and testing.
  • When VPA adjusts a pod's resource configuration dynamically, the pod may be recreated, and the recreated pod could be scheduled to a different node. However, VPA cannot ensure that the scheduling will be successful.
  • VPA can dynamically adjust the resource configuration of pods managed by replication controllers (such as Deployments and StatefulSets), but not for pods that are not managed by replication controllers.
  • VPA and HPA that monitor CPU and memory metrics cannot be used together.
  • VPA admission webhooks update the pod resource configuration. If there are other admission webhooks present in the cluster, make sure they do not conflict with the VPA admission webhooks.
  • VPA handles the majority of OOM events, but it may not handle all of them.
  • VPA performance has not yet been tested in large clusters.
  • VPA may recommend more resources than what is currently available, such as exceeding the maximum limit or resource quotas of nodes. This can result in recreated pods being stuck in a pending state and unable to be scheduled.
  • Configuring multiple VPAs for the same workload can lead to inconsistent behavior.
  • By default, VPA updates resource requests and limits (controlled by controlledValues). However, on Kubernetes v1.33, if spec.updatePolicy.updateMode is set to InPlaceOrRecreate and VPA's recommendations require changing a container's limits value, the kube-apiserver will intercept the change and VPA falls back to Recreate mode. You can set controlledValues to RequestsOnly so that VPA does not change the value of limits.
  • VPA policies do not support the PodLevelResources feature in clusters v1.34.
For details about the known limitations of VPA, see Known limitations.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Deploy a sample workload. If a workload already runs in the cluster, skip this step.
    kubectl create -f hamster.yaml
    Example configuration of hamster.yaml:
    apiVersion: apps/v1
    kind: Deployment
      selector:
        matchLabels:
          app: hamster
      replicas: 2
      template:
          labels:
            app: hamster
          containers:
            - name: hamster
              image: registry.k8s.io/ubuntu-slim:0.1
              resources:
                requests:
                  cpu: 100m
                  memory: 50Mi
              command: ["/bin/sh"]
              args:
                - "-c"
                - "while true; do timeout 0.5s yes >/dev/null; sleep 0.5s; done"
  3. Create a VPA.
    kubectl create -f hamster-vpa.yaml
    Example configuration of hamster-vpa.yaml:
    apiVersion: autoscaling.k8s.io/v1
    kind: VerticalPodAutoscaler
      targetRef:
        apiVersion: "apps/v1"
        kind: Deployment
      updatePolicy:
        updateMode: "Off"
      resourcePolicy:
        containerPolicies:
          - containerName: '*'
            minAllowed:
              cpu: 100m
              memory: 50Mi
            maxAllowed:
              cpu: 1
              memory: 500Mi
            controlledResources: ["cpu", "memory"]
            controlledValues: RequestsAndLimits
    Table 1 Key fields of a VPA
    Field
    Mandatory
    spec.targetRef
    Yes
    The target workloads of the VPA
    Workload types such as Deployment, StatefulSet, and DaemonSet are supported.
    No
    Dynamic update policy of the VPA recommendations. The options include:
    • Off: VPA only generates recommendations and does not change the requested resources of pods.
    • Recreate: VPA generates recommendations and automatically updates a pod's requested resources, which requires recreating the pod and may cause a brief service interruption.
    • Initial: VPA generates recommendations, changes the requested resources upon pod creation, but leaves the requested resources of existing pods unchanged.
    • Auto: VPA behaves similarly to setting this parameter to Recreate. (It is discarded as recommended by the community. Use in-place upgrades.)
    • InPlaceOrRecreate: VPA prefers in-place upgrades and updates a pod's requested resources without restarting the pod. If an in-place upgrade fails, VPA falls back to the Recreate policy. This option requires clusters v1.33 or later and the VPA add-on 1.1.1 or later.
    spec.resourcePolicy.containerPolicies
    No
    Specified VPA policies for container resources, including the minimum and maximum number of resources allowed for containers
    For details, see Table 2.
    Table 2 Key fields in containerPolicy
    Field
    Mandatory
    containerName
    Yes
    Container name. If the value is *, the setting takes effect for all pods of a workload.
    minAllowed
    No
    The minimum number of resources allowed for a container. The VPA recommendations cannot be lower than the value of this parameter.
    Supported resources:
    • CPU
    • Memory
    maxAllowed
    No
    The maximum number of resources allowed for a container. The VPA recommendations cannot be higher than the value of this parameter.
    • CPU
    • Memory
    controlledResources
    No
    The types of container resources controlled by the VPA
    The default value is ["cpu", "memory"].
    • CPU
    • Memory
    mode
    No
    Whether the VPA policy of a container works. The default value is Auto.
    Options:
    • Auto: The VPA policy for the container is enabled.
    • Off: The VPA policy for the container is disabled.
    controlledValues
    No
    The resource values controlled by a VPA policy. The default value is RequestsAndLimits.
    • RequestsAndLimits: controls both the requests and limits values.
    • RequestsOnly: controls only the requests value.
  4. Wait for the VPA to generate the resource recommendations and run the following command to check the VPA recommendations:
    kubectl get vpa hamster-vpa -oyaml
    Command output:
      namespace: default
      resourcePolicy:
        containerPolicies:
          - cpu
          - memory
          maxAllowed:
            cpu: 1
            memory: 500Mi
          minAllowed:
            cpu: 100m
            memory: 50Mi
      targetRef:
        apiVersion: apps/v1
        kind: Deployment
      updatePolicy:
        updateMode: "Off"
    status:
      conditions:
      - lastTransitionTime: "2024-06-27T07:37:01Z"
        status: "True"
        type: RecommendationProvided
      recommendation:
        containerRecommendations:
        - containerName: hamster
          lowerBound:
            cpu: 475m
            memory: 262144k
          target:
            cpu: 587m
            memory: 262144k
          uncappedTarget:
            cpu: 587m
            memory: 262144k
          upperBound:
            cpu: 673m
            memory: 262144k
    The status.recommendation field specifies the resource recommendations generated by the VPA.
    If updateMode is set to Recreate or Auto, the VPA will change the requested resources of the pod based on the recommendations. This change will trigger the rebuilding of the pod.
    Table 3 Key fields in containerRecommendation
    Field
    containerName
    Name of the container for which the VPA policy takes effect
    target
    Recommended resources generated by the VPA. The resources are calculated based on the minimum and maximum number of resources configured in the containerPolicy field.
    The VPA uses these values to dynamically adjust the number of pod resources that can be requested.
    lowerBound
    The lower limit of VPA recommendations
    upperBound
    The upper limit of VPA recommendations
    uncappedTarget
    Actual recommendations generated by the VPA. The resources are not calculated based on the minimum and maximum number of resources configured in the containerPolicy field.
Helpful Links
