Updated on 2026-09-21 GMT+08:00
Cloud Native Cluster Monitoring
Introduction
The Cloud Native Cluster Monitoring add-on (formerly kube-prometheus-stack) uses Prometheus operator and Prometheus and provides easy-to-use, end-to-end Kubernetes cluster monitoring.
This add-on enables the connection of monitoring data and the monitoring center, so that you can view monitoring data and configure alarms on the console.
Open-source community: https://github.com/prometheus/prometheus
  • By default, the kube-state-metrics component of the add-on does not collect labels and annotations of Kubernetes resources. To collect these labels and annotations, manually enable the collection function in the startup parameters and check whether the corresponding metrics are added to the collection trustlist of ServiceMonitor named kube-state-metrics. For details, see Collecting All Labels and Annotations of a Pod.
  • In 3.8.0 and later versions, component metrics defined using annotations in the kube-system and monitoring namespaces are not collected by default after Auto Service Discovery is enabled. If you have workloads in the two namespaces, use PodMonitors or ServiceMonitors to collect their metrics.
  • In 3.8.0 and later versions, etcd-server, kube-controller, kube-scheduler, autoscaler, fluent-bit, volcano-agent, volcano-scheduler and otel-collector metrics are not collected by default. Enable the collection as required.
    To enable the collection, choose Settings in the navigation pane, click the Monitoring tab, find ServiceMonitor Policies or PodMonitor Policies, click Manage, and enable the collection of related metrics as required.
  • In versions later than 3.9.0, Grafana is removed from Cloud Native Cluster Monitoring and has become an independent Grafana add-on. Therefore, before rolling Cloud Native Cluster Monitoring from a version later than 3.9.0 to a version earlier than 3.9.0, uninstall Grafana from the add-on.
Permissions
The node-exporter component of the Cloud Native Cluster Monitoring add-on needs to read the Docker info data from the /var/run/docker.sock directory on the host for monitoring the Docker disk space.
The following permission is required for running node-exporter:
  • cap_dac_override: reads the Docker info data.
Installing the Add-on
The Cloud Native Cluster Monitoring add-on automatically selects a deployment mode based on Data Storage Configuration. This is supported by Cloud Native Cluster Monitoring 3.7.1 or later.
  • Original agent mode: Disable Local Data Storage and enable at least one of Report Monitoring Data to AOM and Report Monitoring Data to a Third-Party Platform.
  • Original server mode: Enable Local Data Storage and at least one of Report Monitoring Data to AOM or Report Monitoring Data to a Third-Party Platform.
  2. In the navigation pane, choose Add-ons. Locate Cloud Native Cluster Monitoring on the right and click Install.
  3. On the Install Add-on page, enable at least one item in the Data Storage Configuration area.
    • Reporting Monitoring Data to AOM: Prometheus data is reported to AOM. After this function is enabled, you can select the corresponding AOM instance. Basic container metrics are monitored for free. For details, see Basic Metrics: Container Metrics. Custom metrics are billed by AOM. For details, see Product Pricing Details. To access AOM, you must have required permissions. Only Huawei Cloud accounts, Huawei accounts, or users in the admin user group can perform this operation.
    • Reporting Monitoring Data to a Third-Party Monitoring Platform: To report Prometheus data to a third-party monitoring system, you need to enter the address and token of the third-party monitoring system and determine whether to skip certificate authentication.
    • Local Data Storage: Select the type and size of a disk for storing monitoring data to store Prometheus data in PVCs in the cluster. Storage volumes are not deleted along with the add-on. If Local Data Storage is enabled, all components will be deployed. For details, see Components.
      An available PVC named pvc-prometheus-server-0 exists in namespace monitoring and will be used as the storage source.
  4. Configure the add-on specifications as needed.
    • Add-on Specifications:
      • If you selected Preset, the system will configure the number of pods and resource quotas for the add-on based on the preset specifications. You can see the configurations on the console.
      • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on pod runs, the add-on will fail.
    • Prometheus HA: The Prometheus server, Prometheus operator, thanos-query, custom-metrics-apiserver, alertmanager, and kube-state-metrics components are deployed in multi-instance mode in the cluster.
    • Number of collected shards (available after Local Data Storage is disabled): When there is a lot of Prometheus data, you can configure this parameter to spread the data across a specific number of Prometheus instances. This will help with storage and querying. Increasing the number of shards reduces the data volume carried by each shard. This can increase the upper limit of the metric collection throughput and cause more resources to be consumed. By default, CCE automatically determines the number of shards based on the cluster scale. It is advised to allocate one shard for every 50 nodes. If you want to enhance collection performance by increasing the number of shards, carefully assess resource utilization and optimize based on your monitoring needs. To ensure system stability, keep the master node's memory usage below 50%.
    • Install Grafana: Use Grafana to visualize monitoring data. Grafana creates a 5 GiB storage volume by default. Uninstalling the add-on will not delete this volume. You can use the default username and password to log in to Grafana for the first time. For details, see Sign in to Grafana. After the login is successful, the system prompts you to change the password.
      In versions later than 3.9.0, Grafana is removed from Cloud Native Cluster Monitoring and has become an independent Grafana add-on. So this option is no longer displayed.
  5. Configure the add-on parameters.
    • Auto Service Discovery: After this function is enabled, the add-on automatically collects application metrics using annotation-based service discovery. By default, applications in the kube-system and monitoring namespaces are excluded. For details about how to configure automatic collection of annotations, see Configuring Pod Annotations and Configuring Service Annotations.
    • Collection Interval: Configure the collection interval.
    • Data Retention (available only after Local Data Storage is enabled): Configure how long the monitoring data can be kept.
    • node-exporter Listening Port: This port uses the host network to listen to and expose metrics on the node for Prometheus collection. The default port number is 9100, but it can be modified if there is a conflict with an existing port.
  6. Click Install.
    After the add-on is installed, you may need to perform the following operations:
    • To use custom metrics to create an auto scaling policy, ensure that Local Data Storage is enabled for the add-on and then take the following steps:
      1. Collect custom metrics reported by applications to Prometheus. For details, see Monitoring Custom Metrics Using Cloud Native Cluster Monitoring.
      2. Aggregate these custom metrics collected by Prometheus to the API server for the HPA policy to use. For details, see Creating an HPA Policy Using Custom Metrics.
    • To provide system resource metrics (such as CPU and memory usage) for workload auto scaling using this add-on, ensure that Local Data Storage is enabled for the add-on and then enable the Metrics API. For details, see Providing Basic Resource Metrics Through the Metrics API. After the configuration, you can use Prometheus to collect system resource metrics. (This operation is not recommended because it may conflict with the Kubernetes Metric Server add-on.)
Components
All Kubernetes resources created during Cloud Native Cluster Monitoring add-on installation are created in the namespace named monitoring.
Table 1 Add-on components
Component
Supported Deployment Mode
Resource Type
prometheusOperator
(workload name: prometheus-operator)
The control center of the entire system. It deploys and manages Prometheus server based on Prometheus CustomResourceDefinitions (CRDs), and monitors and processes the changes of these CRDs.
All
Deployment
prometheus
(If the local data storage is used, the workload name is prometheus-server. If the local data storage is not used, the workload name is prometheus-lightweight.)
The core component of the Prometheus monitoring system. It is used to collect and store metrics and report the metrics to AOM or a third-party monitoring platform. If local storage is enabled, the metric data can be stored in local PVCs.
All
StatefulSet
alertmanager
(workload name: alertmanager-alertmanager)
Alarm center of the add-on. It receives alarms sent by Prometheus and manages alarm information by deduplicating, grouping, and distributing.
Local data storage enabled
StatefulSet
thanosSidecar
Available only in HA mode. Runs with prometheus-server in the same pod to implement persistent storage of Prometheus metric data.
Container
thanosQuery
Available only in HA mode. Entry for PromQL query when Prometheus is in HA scenarios. It can delete duplicate metrics from Store or Prometheus.
Deployment
adapter
(workload name: custom-metrics-apiserver)
Aggregates custom metrics to the native Kubernetes API Server.
Deployment
kubeStateMetrics
(workload name: kube-state-metrics)
Converts the status of Kubernetes resource objects (such as pods, Deployments, and nodes) into Prometheus-compatible time series metrics. By default, the kube-state-metrics component does not collect all labels and annotations of Kubernetes resources. To collect all labels and annotations, see Collecting All Labels and Annotations of a Pod.
If the components run in multiple pods, only one pod provides metrics.
All
Deployment
nodeExporter
(workload name: node-exporter)
Deployed on each node to collect node monitoring data.
All
DaemonSet
If Local Data Storage is enabled for the Cloud Native Cluster Monitoring add-on, basic resource metrics can only be provided through Metrics API.
If Kubernetes Metrics Server has been installed in the cluster, the Metrics API is provided by default. Skip this part.
Resource metrics of containers and nodes, such as CPU and memory usage, can be obtained through the Kubernetes Metrics API. Resource metrics can be directly accessed, for example, by using the kubectl top command, or used by HPA or CustomedHPA policies for auto scaling.
The add-on can provide the Kubernetes Metrics API that is disabled by default. To enable the Metrics API, create the following APIService object:
apiVersion: apiregistration.k8s.io/v1
kind: APIService
  labels:
    app: custom-metrics-apiserver
    release: cceaddon-prometheus
  group: metrics.k8s.io
  groupPriorityMinimum: 100
  insecureSkipTLSVerify: true
  service:
    namespace: monitoring
    port: 443
  version: v1beta1
  versionPriority: 100
You can save the object as a file, name it metrics-apiservice.yaml, and run the following command:
kubectl create -f metrics-apiservice.yaml
Run the kubectl top pod -n monitoring command. If information similar to the following is displayed, the Metrics API can be accessed:
NAME                                                      CPU(cores)   MEMORY(bytes)
custom-metrics-apiserver-d4f556ff9-l2j2m                  38m          44Mi
To uninstall the add-on, run the following kubectl command and delete the APIService object. Otherwise, residual APIService resources may prevent the installation of the Kubernetes Metrics Server add-on.
kubectl delete APIService v1beta1.metrics.k8s.io
HPA policies can only be used when Cloud Native Cluster Monitoring is deployed with Local Data Storage enabled. You can configure custom metrics required by HPA policies in the user-adapter-config ConfigMap.
To use Prometheus to monitor custom metrics, the application needs to provide a metric monitoring API. For details, see Prometheus Monitoring Data Collection.
In this section, the nginx metric (nginx_connections_accepted) in Monitoring Custom Metrics Using Cloud Native Cluster Monitoring is used as an example.
  2. In the navigation pane, choose ConfigMaps and Secrets. Switch to the monitoring namespace, click the ConfigMaps tab, locate the row containing user-adapter-config (or adapter-config), and click Update.
    Figure 1 Updating a ConfigMap
  3. In Data, click Edit for the config.yaml file to add a custom metric collection rule under the rules field. Click OK.
    You can add multiple collection rules by adding multiple configurations under the rules field. For details, see Metrics Discovery and Presentation Configuration.
    Example custom metric rule:
    rules:
    # Match the metric whose name is nginx_connections_accepted. The metric name must be verified. Otherwise, the HPA controller cannot get the metric.
    - seriesQuery: '{__name__=~"nginx_connections_accepted",container!="POD",namespace!="",pod!=""}'
      resources:
        # Specify pod and namespace resources.
        overrides:
          namespace:
            resource: namespace
          pod:
            resource: pod
      name:
        # Use nginx_connections_accepted.
        matches: "nginx_connections_accepted"
        # Use nginx_connections_accepted_per_second to represent the metric. The name is the custom metric name in a custom HPA policy.
        as: "nginx_connections_accepted_per_second"
        # Calculate rate(nginx_connections_accepted[2m]) to specify the number of requests received per second.
      metricsQuery: 'rate(<<.Series>>{<<.LabelMatchers>>,container!="POD"}[2m])'
    Figure 2 Modifying ConfigMap data
  4. Redeploy the custom-metrics-apiserver workload in the monitoring namespace.
    Figure 3 Redeploying custom-metrics-apiserver
  5. In the navigation pane, choose Workloads. Locate the workload for which you want to create an HPA policy and choose More > Auto Scaling. In the Custom Policy area, you can select the preceding parameters to create an auto scaling policy.
    Figure 4 Creating an HPA policy
  2. In the navigation pane, choose Workloads. Switch to the monitoring namespace, click the Deployments tab, and click the name of the kube-state-metrics workload. On the page displayed, click the Containers tab and click Edit on the right.
  3. In the Lifecycle area of the container settings, edit the startup command.
    Figure 5 Editing the startup command
    To collect labels, add the following information to the end of the original kube-state-metrics startup parameter:
    --metric-labels-allowlist=pods=[*],nodes=[node,failure-domain.beta.kubernetes.io/zone,topology.kubernetes.io/zone]
    To collect annotations, add parameters to the startup parameters in the same way.
    --metric-annotations-allowlist=pods=[*],nodes=[node,failure-domain.beta.kubernetes.io/zone,topology.kubernetes.io/zone]
    When editing the startup command, do not modify other original startup parameters. Otherwise, the component may malfunction.
  4. kube-state-metrics starts to collect the labels/annotations of pods and nodes and checks whether kube_pod_labels/kube_pod_annotations is in the collection task of Prometheus.
    kubectl get servicemonitor kube-state-metrics -nmonitoring -oyaml | grep kube_pod_labels
For more kube-state-metrics startup parameters, see kube-state-metrics/cli-arguments.
Helpful Links
Release History
Table 2 Cloud Native Cluster Monitoring updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
3.12.16
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
2.53.2
3.12.12
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
2.53.2
3.12.9
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
2.53.2
3.12.8
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
2.53.2
3.12.2
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
2.53.2
3.12.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
2.53.2
3.12.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
  • Supported CCE clusters v1.31.
  • Upgraded Prometheus.
2.53.2
3.11.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Supported CCE clusters v1.30.
2.37.8
3.10.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Upgraded NodeExporter to 1.8.0.
2.37.8
3.10.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Supported clusters v1.29.
2.37.8
3.9.5
v1.21
v1.23
v1.25
v1.27
v1.28
  • Added the option for collecting custom metrics. This function is enabled by default.
  • Removed support for clusters v1.17 and v1.19.
  • Removed Grafana. Grafana has been split into an independent add-on.
  • Collected only free metrics and custom service discovery metrics by default.
  • Upgraded the open-source components.
2.37.8
3.8.2
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
Fixed some issues.
2.35.0
3.7.3
v1.17
v1.19
v1.21
v1.23
v1.25
None
2.35.0
3.7.2
v1.17
v1.19
v1.21
v1.23
v1.25
Supported collection of Virtual Kubelet pod metrics.
2.35.0
3.7.1
v1.17
v1.19
v1.21
v1.23
v1.25
Supported the Prometheus agent mode.
2.35.0
3.6.6
v1.17
v1.19
v1.21
v1.23
v1.25
  • Upgraded Grafana to 7.5.17.
  • Supported containerd nodes.
2.35.0
3.5.1
v1.17
v1.19
v1.21
v1.23
None
2.35.0
3.5.0
v1.17
v1.19
v1.21
v1.23
Updated the add-on to its community version 2.35.0.
2.35.0
