Updated on 2026-09-21 GMT+08:00
Cloud Native Log Collection
Introduction
The Cloud Native Log Collection add-on (formerly log-agent) is developed based on Fluent Bit and OpenTelemetry for collecting logs and Kubernetes events. This add-on supports CRD-based log collection policies. It collects and forwards standard output logs, container file logs, node logs, and Kubernetes events in a cluster based on configured policies. It also reports Kubernetes events to AOM for configuring event alarms. By default, all abnormal events and some normal events are reported.
In versions 1.3.2 and later, Cloud Native Log Collection reports all warning events and some normal events to AOM by default. These events can be used to configure alarms.
If the cluster version is 1.19.16, 1.21.11, 1.23.9, 1.25.4, or later, after Cloud Native Log Collection is installed, the control plane components no longer report events to AOM. Instead, this add-on reports events to AOM. When uninstalling the add-on: If the add-on version is earlier than 1.7.3, the control plane will not resume event reporting, and events will no longer be reported to AOM. If the add-on version is 1.7.3 or later, the control plane will resume event reporting and continue to report events to AOM.
Log Collection Reliability
The log system's main purpose is to record all stages of data for service components, including startup, initialization, exit, runtime details, and exceptions. It is primarily employed in O&M scenarios for tasks like checking component status and analyzing fault causes.
Standard streams (stdout and stderr) and local log files use non-persistent storage. However, data integrity may be compromised due to the following risks:
  • Log rotation and compression potentially deleting old files
  • Temporary storage volumes being cleared when Kubernetes pods end
  • Automatic OS cleanup triggered by limited node storage space
While the Cloud Native Log Collection add-on employs techniques like multi-level buffering, priority queues, and resumable uploads to enhance log collection reliability, logs could still be lost in the following situations:
  • The service log throughput surpasses the collector's processing capacity.
  • The service pod is terminated and immediately reclaimed by the container runtime.
  • The log collector pod experiences exceptions.
The following lists some recommended best practices for cloud native log management. You can review and implement them thoughtfully.
  • Use dedicated, high-reliable streams to record critical service data (for example, financial transactions) and store the data in persistent storage.
  • Avoid storing sensitive information like customer details, payment credentials, and session tokens in logs.
This add-on is available only in clusters v1.17 or later.
Add-on Performance
Item
Remarks
Size of a log
Each individual log must not exceed 512,000 bytes. For multi-line logs, each line is counted separately toward this limit.
None
Maximum number of collected files
On a single node, the total number of files that can be monitored by all log collection rules is limited to 4,095.
None
Log collection rate
  • If the add-on version is earlier than 1.5.0, in each cluster, no more than 10,000 single-line logs can be collected per second, and no more than 2000 multi-line logs can be collected per second.
  • If the add-on version is 1.5.0 or later, on each node, no more than 20,000 logs or 10 MB of logs can be collected per second.
Service quality cannot be ensured if any of these limits is exceeded.
Configuration update
Configuration updates take effect in 1 to 3 minutes.
None
Permissions
The fluent-bit component of the add-on reads and collects the stdout logs on each node, file logs in pods, and node logs based on the collection configuration.
The following permissions are required for running the fluent-bit component:
  • CAP_DAC_OVERRIDE: ignores the discretionary access control (DAC) restrictions on files.
  • CAP_FOWNER: ignores the restrictions that the file owner ID must match the process user ID.
  • DAC_READ_SEARCH: ignores the DAC restrictions on file reading and catalog search.
  • SYS_PTRACE: allows all processes to be traced.
The Cloud Native Log Collection add-on enhances the log reading capability based on these permissions. However, if log files are stored in an external file system (such as SFS), these permissions may not take effect. To ensure that logs can be collected properly, ensure that the paas user (UID 10000) has the read and execute permissions on the directory where the logs are stored and the read permissions on the files in the directory.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate Cloud Native Log Collection and click Install.
  3. On the Install Add-on page, configure the specifications as needed.
    • If you select Preset, choose Small or Large based on the log volume on your node. CCE automatically configures the number of add-on pods and resource quotas according to the selected specification. You can view these configurations on the console.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on pod runs, the add-on will fail.
  4. Configure Agency Settings. This configuration is supported by the add-on of 1.7.9 or later.
    Add-ons require runtime access to other cloud services. You need to configure an add-on agency to authorize these operations. For details, see Custom Agencies for Add-ons.
    • Create automatically: CCE automatically creates a default agency and uses this agency for the add-on. If there is a default agency, CCE will not create one again.
    • Use existing: Select one from the drop-down list. Ensure that the created agency has been assigned the required permissions. Otherwise, the add-on functions may be unavailable.
  5. Configure add-on parameters, which are supported by the add-on of v1.6.1 or later. For details, see Tail.
    Default Value
    Large Specification
    Other Specification
    Initial Buffer Size (Buffer_Chunk_Size)
    The size of the initial buffer used to read files.
    256k
    128k
    Maximum Buffer Size (Buffer_Max_Size)
    Limit on the buffer size for each monitored file. When a buffer is added, the number of memory buffers that can be added is restricted by this value. If the limit is exceeded, the file will be removed from the monitored file list.
    1024k
    512k
    Memory Buffer Limit (Mem_Buf_Limit)
    Memory limit when data is appended to the engine. When the limit is reached, the add-on will temporarily stop reading log file data. The reading will resume after the data is refreshed.
    300mb
    40mb
    The unit can be case-insensitive k, kb, m, mb, g or gb. If no unit is specified, the default unit of byte will be used.
  6. Configure deployment policies for the add-on pods.
    Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    Table 1 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Forcible: Add-on pods are strictly distributed across AZs, with at most one pod per AZ. If the cluster's nodes do not span multiple AZs, some add-on pods will remain unscheduled and fail to run. If a node is faulty, the add-on pods on it may fail to be migrated.
  7. Click Install.
Components
Table 2 Add-on components
Component
Resource Type
fluent-bit
Lightweight log collector and forwarder deployed on each node to collect logs. In 1.5.0 and later versions, logs are directly reported to LTS. In versions earlier than 1.5.0, logs are reported to otel-collector.
DaemonSet
cop-logs
Used to generate soft links for collected files. It runs in the same pod as fluent-bit.
DaemonSet
log-operator
Used to generate internal configuration files
Deployment
otel-collector
Used to collect Kubernetes events and report them to LTS and AOM, and receive and report logs to LTS.
The extent of log data reporting varies with the add-on version. In versions earlier than 1.5.1, this component reports logs of different applications and services. In 1.5.1 and later versions, this component reports only logs of workloads that are scaled to CCI.
In v1.7.5 and later versions, this component is used only to report logs of workloads that are scaled to CCI. If this component is not needed, set the number of its pods to 0.
Deployment
otel-collector-event
Added in v1.7.5 and later versions. It collects Kubernetes events and reports them to LTS and AOM.
Deployment
How to Use the Add-on
This add-on can collect container standard output logs, container file logs, node logs, and Kubernetes events. You can use LTS or AOM to store the collected logs. These services support different types of logs. For details, see Table 3.
Table 3 Log storage description
Log Storage Location
Supported Log Types
How to Use
LTS
  • Container standard output logs
  • Container file logs
  • Node logs
Go to Logging to create a policy. For details, see Collecting Container Logs Using the Cloud Native Log Collection Add-on.
Kubernetes events
Collecting Kubernetes Events
Control plane component logs
Collecting Control Plane Component Logs
Kubernetes audit logs
Collecting Audit Logs
NGINX Ingress Controller add-on logs
Collecting NGINX Ingress Controller Logs
AOM
Kubernetes events
If the cluster version is v1.19.16, v1.21.11, v1.23.9, v1.25.4, or later, all abnormal events and some normal events will be reported by default. For details, see Reporting Kubernetes Events to AOM.
Helpful Links
  • After installing the Cloud Native Log Collection add-on, you can use the Logging to collect Kubernetes logs. For details, see Overview.
  • During log collection, there may be issues like interrupted collection or data loss. To ensure log integrity and availability, you are advised to set log collection status monitoring and alarms. For details, see Configuring Metrics and Alarms for Log Collection Status.
Release History
Table 4 Cloud Native Log Collection updates
Add-on Version
Supported Cluster Version
New Feature
1.7.14
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
1.7.13
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
1.7.10
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
1.7.9
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
1.7.8
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
1.7.6
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
  • Supported CCE clusters v1.33.
  • Optimized the memory consumption of event collection.
1.7.4
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Blocklists can be applied to standard output log collection policies across all namespaces based on pod labels.
1.7.3
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
1.7.2
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Logs can be compressed in gzip format and sent to LTS.
1.7.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
1.7.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported clusters v1.31.
1.6.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
  • LTS log streams can be automatically created.
  • The Buffer_Chunk_Size, Buffer_Max_Size, and Mem_Buf_Limit parameters can be configured.
  • The pod_ip field has been added to the events reported to AOM.
1.6.0
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
  • Supported clusters v1.30.
  • Security hardening: The permissions of the add-on for accessing secrets are limited to the monitoring namespace.
1.5.2
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
The index function is added when the default log stream of container logs is created.
1.4.5
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
1.4.2
v1.21
v1.23
v1.25
v1.27
v1.28
  • Supported clusters v1.28.
  • Supported logging from on-premises clusters.
  • Supported special processing of AOM-related fields in GPU event reporting.
1.3.10
v1.17
v1.19
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed the Fluent Bit memory corruption vulnerability.
1.3.2
v1.17
v1.19
v1.21
v1.23
v1.25
Supported reporting Kubernetes events to AOM.
1.3.0
v1.17
v1.19
v1.21
v1.23
v1.25
Supported clusters v1.25.
1.2.3
v1.17
v1.19
v1.21
v1.23
None
1.2.2
v1.17
v1.19
v1.21
v1.23
log-agent is a cloud native log collection add-on built on open-source Fluent Bit and OpenTelemetry and supports CRD-based log collection policies. It collects and forwards standard container output logs, container file logs, node logs, and Kubernetes event logs in a cluster following your rules.
