Help Center/ Cloud Container Engine/ User Guide/ O&M/ Logging/ Collecting Container Logs/ Collecting Container Logs Using the Cloud Native Log Collection Add-on
Updated on 2026-09-21 GMT+08:00
Cloud Native Log Collection is built on the open-source Fluent Bit and OpenTelemetry and can collect cloud native logs and Kubernetes events. This add-on supports CRD-based log collection policies. It collects and forwards stdout logs, container file logs, node logs, and Kubernetes events in a cluster based on configured policies.
  • A maximum of 100 log rules can be created for each cluster.
  • The Cloud Native Log Collection add-on cannot collect .gz, .tar, and .zip logs and cannot access symbolic links of logs.
  • If the node storage driver is Device Mapper, container file logs must be collected from the path where the data disk is attached on the node.
  • If the container runtime is containerd, each stdout log cannot be in multiple lines. (This does not apply to the Cloud Native Log Collection add-on of version 1.3.0 or later.)
  • If a volume is mounted to the directory of a service container, the add-on cannot collect data from the parent directory. In this case, you need to configure a complete data directory.
  • If the lifetime of a container is less than 1 minute, logs cannot be collected in a timely manner. As a result, logs may be lost.
  • When you create a log stream using a collection policy, ensure that the log stream name is unique because LTS does not allow log streams with the same name (both before and after renaming), even in different log groups.
  • Do not mount hostPath and emptyDir volumes to paths that have a nesting relationship (for example, /var/log and /var/log/share) in the same pod. If you do this, log file collection may be abnormal due to the mounting sequence or path overwriting.
Billing
LTS does not charge you for creating log groups and offers a free quota for collecting logs every month. You pay only for the log volume exceeding the quota. For details, see Price Calculator.
Configuring Log Collection
You can configure log collection using the console or YAML.
  1. Enable logging.
  2. View and configure log collection policies.
    1. In the navigation pane, choose Logging.
    2. Click View Log Collection Policies in the upper right corner.
      All log collection policies reported to LTS are displayed.
      Figure 3 Viewing log collection policies
    3. Click Create Log Collection Policy.
      Policy Template: If the default log collection policy provided by CCE is not enabled when log collection is enabled or the default log collection policy is deleted, you can use this option to create a default log collection policy.
      Custom Policy: You can use this option to create a custom log collection policy.
      Figure 4 Custom policy
      • To keep the logs organized, you are advised to select different log streams for different types of logs when configuring the log collection policies.
      • The following are requirements for configuring the container and node file log paths:
        • Log directory: Enter an absolute path, for example, /log. The path must start with a slash (/) and contain a maximum of 512 characters. Only uppercase letters, lowercase letters, digits, hyphens (-), underscores (_), slashes (/), asterisks (*), and question marks (?) are allowed.
        • Log file name: It can contain only uppercase letters, lowercase letters, digits, hyphens (-), underscores (_), asterisks (*), question marks (?), and periods (.). Logs in the format of .gz, .tar, and .zip are not supported.
        The directory and file names must be complete and support asterisks (*) and question marks (?) as wildcards. A maximum of three levels of directories can be matched using wildcards. The level-1 directory does not support wildcards. An asterisk (*) can match multiple characters. A question mark (?) can match only one character. For example:
        • If the directory is /var/logs/* and the file name is *.log, the match expression is /var/logs/*/*.log, indicating that any files with the extension .log in all level-1 directories in the /var/logs directory are matched. Note that this expression cannot match any files with the extension .log in the /var/logs directory and multi-level directories in the /var/logs directory.
        • If the directory is /var/logs/app_* and the file name is *.log, any log files with the extension .log in all directories that match app_* in the /var/logs directory will be reported.
      Table 1 Custom policy parameters
      Log Type
      Container stdout Log
      Container File Log
      Node File Log
      Log Type
      Used to collect container stdout logs. You can create a log collection policy by namespace, workload name, or instance label.
      Used to collect text logs. You can specify a workload or instance label to create a log collection policy.
      Used to collect logs from a node. Only one file path can be configured for a log collection policy.
      Log Source
      • All containers: You can specify all containers in a namespace. If this parameter is not specified, logs of containers in all namespaces will be collected.
        • Blocklist: The Cloud Native Log Collection add-on 1.7.4 or later supports this function. You can exclude pods from log collection based on pod label groups. Labels in the same label group are in the AND relationship, and labels in different label groups are in the OR relationship. If a pod matches all labels in any label group, the pod is excluded. You can create up to 10 label groups, and each label group can contain up to five labels.
          For example, if you want to exclude all pods of a workload in a namespace, enter the workload label, for example, app:test.
      • Workload: You can specify containers in a workload. If no container names are specified, logs of all containers running the workload will be collected.
      • Workload with target label: You can specify a workload by label. If no container names are specified, logs of all containers running the workload will be collected.
      • Workload:
      You also need to specify the log collection path. For details, see the log path configuration requirements.
      Collection Path: used to configure the log collection path. For details, see the log path configuration requirements.
      Log Format
      • Single-line
        Each log contains only one line of text. The newline character \n denotes the start of a new log.
      • Multi-line
        Some programs (for example, Java programs) print logs that span multiple lines. By default, logs are collected by line. If you want to display logs as a single message, you can enable multi-line logging and use the regular pattern. When you select Multi-line, configure Log Matching Format.
        For example, if logs need to be collected by line and each log starts with a date and occupies three lines, you can set Log Matching Format to the regular expression of the date, for example, \d{4}-\d{2}-\d{2} \d{2}\:\d{2}\:\d{2}.*.
        The three lines starting with the date are regarded as a log.
        2022-01-01 00:00:00 Exception in thread "main" java.lang.RuntimeException: Something has gone wrong, aborting!
        at com.myproject.module.MyProject.badMethod(MyProject.java:22)
        at com.myproject.module.MyProject.oneMoreMethod(MyProject.java:18)
      Report to LTS
      This parameter is used to configure the log group and log stream for log reporting.
      • Default log groups/log streams: The default log group (k8s-log-{Cluster ID}) and default log stream (stdout-{Cluster ID}) are automatically selected.
      • Custom log groups/log streams: You can select any log group and log stream.
        • Log Group: A log group is the basic unit for LTS to manage logs. If you do not have a log group, CCE prompts you to create one. The default name is k8s-log-{Cluster ID}, for example, k8s-log-bb7eaa87-07dd-11ed-ab6c-0255ac1001b3.
        • Log Stream: A log stream is the basic unit for reading and writing logs. You can put different types of logs into different streams to ease management. When you install the add-on or create a log collection policy based on the policy template, the following log streams are automatically created:
          - stdout-{cluster-ID} for container logs, for example, stdout-bb7eaa87-07dd-11ed-ab6c-0255ac1001b3
          - event-{cluster-ID} for Kubernetes events, for example, event-bb7eaa87-07dd-11ed-ab6c-0255ac1001b3
          - cceaddon-nginx-ingress-{cluster-ID} for NGINX Ingress Controller logs, for example, cceaddon-nginx-ingress-bb7eaa87-07dd-11ed-ab6c-0255ac1001b3.
  3. View the logs.
    2. View different types of logs:
      • Container Logs: displays all logs in the default log stream stdout-{Cluster ID} of the default log group k8s-log-{Cluster ID}. You can search for logs by workload.
        Figure 5 Querying container logs
      • Kubernetes Events: displays all Kubernetes events in the default log stream event-{Cluster ID} of the default log group k8s-log-{Cluster ID}.
      • Control Plane Logs: displays all logs of components on the control plane in the default log stream {Component name}-{Cluster ID} of the default log group k8s-log-{Cluster ID}.
      • Control Plane Audit Logs: all control plane audit logs in the default log stream audit-{cluster-ID} of the default log group k8s-log-{cluster-ID}.
      • Global Log Query: You can view logs in the log streams of all log groups. You can specify a log stream to view the logs. By default, the default log group k8s-log-{Cluster ID} is selected. You can click the edit icon on the right of Switching Log Groups to switch to another log group.
        Figure 6 Global log query
      • Add-on Logs: displays the add-on logs in the default log group k8s-log-{Cluster ID}. You can view the cluster add-on logs.
    3. Click View Log Collection Policies in the upper right corner. Locate the log collection policy and click View Log to go to the log list.
      Figure 7 Viewing logs
The Cloud Native Log Collection add-on must be 1.6.1 or later.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named log-config.yaml. You can create a custom file name.
    vi log-config.yaml
    The following examples are for your reference. For details about the parameters, see Table 2.
    • Scenario 1: Collecting stdout logs of all workloads
      apiVersion: logging.openvessel.io/v1
      kind: LogConfig
        name: test-log-01  # Change the rule name as needed.
        namespace: kube-system  #Namespace of the collection rule. The value is fixed at kube-system.
        inputDetail  : # Input configuration
          type: container_stdout   # Input type. container_stdout indicates stdout logs.
          containerStdout:  # stdout log configuration. This parameter is valid only when type is set to container_stdout.
            allContainers: true  # Whether to collect the logs of all containers.
            namespaces: []  # Namespace list, which is of array type. This parameter is valid only when allContainers is set to true. The stdout logs of containers in specified namespaces will be collected. An empty array indicates that the stdout logs of containers in all namespaces will be collected.
            excludePodLabels:  # This parameter is available in Cloud Native Log Collection v1.7.4 and later. It enables pod-level log collection exclusion based on label selectors. Labels within the same group are evaluated with AND logic, and groups are evaluated with OR logic. A pod is excluded if it matches all labels in any single group.
            - key1: value1    # Label group 1
              key2: value2
            - key3: value3    # Label group 2
        outputDetail:  # Output configuration
          type: LTS    # Output type. The value is fixed at LTS.
          LTS:
            ltsGroupID: abf5f0ad-627e-41cc-8d3f-61c9e1f57f5a      # LTS log group ID. The specified ID must exist.
            ltsStreamID: f7ed71e9-6b9d-4ba3-86e4-b1b9d22ef4fb     # LTS log stream ID. The specified ID must exist.
    • Scenario 2: Collecting container file logs of a specified workload
      kind: LogConfig
        name: test-log-02  # Change the rule name as needed.
          type: container_file   # Input type. container_file indicates container file logs.
          containerFile:    # Container file log configuration. This parameter is valid only when type is set to container_file.
            workloads:        # Modify the workload information as needed.
            - namespace: monitoring  # Namespace that the workload belongs to
              kind: Deployment  # Workload type. The value can be Deployment, DaemonSet, StatefulSet, Job, or CronJob.
              name: prometheus-lightweight  # Workload name
              container: prometheus  # Container name
              files:
              - logPath: "/var/log"  # Log directory, which is an absolute path.
                filePattern: "*.log"  # Log file name, which supports wildcard characters.
          processors:    # Multi-line log definition. If multiple lines are not required, delete processors.
            type: multiline # Log type, which is optional. The value can be singleline or multiline. The default value is singleline.
            multilineRegulation: '\d+:\d+:\d+.*?'  # Multi-line regular expression, which is optional. This field is valid only when type is set to multiline.
          LTS:
    • Scenario 3: Collecting container file logs of pods with specified labels
      kind: LogConfig
        name: test-log-03  # Change the rule name as needed.
            podLabels:      # Modify the value based on the CRD description.
            - includeLabels: # Label set. The logs of pods with the following labels will be collected. At least one label must be specified. Note that the pod label is not the label of the workload.
                foo: bar
              namespaces:  # Namespace list, which is of array type. An empty array indicates all namespaces.
              - monitoring
              - kube-system
              containers: []  # Container name list, which is of array type. An empty array indicates all containers.
              files:
          LTS:
    • Scenario 4: Collecting node logs
      kind: LogConfig
        name: test-log-04  # Change the rule name as needed.
          type: host_file   # Input type. host_file indicates node logs.
          hostFile:    # Node log configuration. This parameter is valid only when type is set to host_file.
            file:
              logPath: "/var/log"    # Log directory, which is an absolute path. Change it as needed.
              filePattern: "messages" # Log file name, which supports wildcard characters and can be modified as needed.
          LTS:
    Table 2 Parameters
    Type
    Example
    spec.inputDetail.type
    String
    Input type. The options are as follows:
    • container_stdout: indicates stdout logs. This field must be used together with the containerStdout field.
    • container_file: indicates container file logs. This field must be used together with the containerFile field.
    • host_file: indicates node logs. This field must be used together with the hostFile field.
    N/A
    spec.inputDetail.containerStdout
    Object
    It contains the following fields:
    • allContainers: Whether to collect the logs of all containers. If the value is true, the logs of all containers will be collected. In this case, you need to specify the namespaces field. If the value is false, the logs of specified workloads will be collected. In this case, you need to specify the workloads field.
    • namespaces: namespace list, which is of array type and is valid only when allContainers is set to true. The stdout logs of containers in specified namespaces will be collected. An empty array indicates that the stdout logs of containers in all namespaces will be collected.
    • excludePodLabels: (supported by the Cloud Native Log Collection add-on of 1.7.4 or later) used to exclude pods from log collection based on pod label groups. This field is available only when allContainers is set to true. Labels in the same label group are in the AND relationship, and labels in different label groups are in the OR relationship. If a pod matches all labels in any label group, the pod is excluded. You can create up to 10 label groups, and each label group can contain up to five labels.
    • workloads: workload list, which is of array type and is valid only when allContainers is set to false.
      • namespace: Namespace that a workload belongs to.
      • kind: workload type. The value can be Deployment, DaemonSet, StatefulSet, Job, or CronJob.
      • name: workload name.
      • containers: container name list, which is of array type. An empty array indicates all containers.
    • podLabels: pod labels, which is of array type and is valid only when allContainers is set to false and workloads is left empty.
      • includeLabels: label set. The logs of pods with the following labels will be collected. At least one label must be specified. Note that the pod label is not the label of the workload.
      • namespaces: namespace list, which is of array type. An empty array indicates all namespaces.
    Example 1: Collecting the stdout logs of all containers in a namespace
      inputDetail:
        containerStdout:
          allContainers: true
          namespaces:
          - monitoring
    Example 2: Collecting the stdout logs of a workload
      inputDetail:
        containerStdout:
          allContainers: false
          workloads:
            kind: Deployment
    Example 3: Collecting the stdout logs of a pod
      inputDetail:
        containerStdout:
          workloads: []
          podLabels:
          - includeLabels:
              foo: bar
            namespaces:
            - monitoring
            containers: []
    Example 4: Collecting the stdout logs of all containers in a namespace, excluding the pods of multiple workloads from log collection (based on multiple groups of labels)
      inputDetail:
        containerStdout:
          allContainers: true
          namespaces:
          - monitoring
          excludePodLabels:
            key2: value2
    spec.inputDetail.containerFile
    Object
    • workloads: workload list, which is of array type.
      • namespace: namespace that a workload belongs to.
      • container: container name.
      • files: file list, which is of array type and contains the logPath and filePattern fields.
        - logPath: log directory, which is an absolute path, for example, /var/log.
        - filePattern: log file name, which supports wildcard characters, for example, *.log.
    • podLabels: pod labels, which is of array type and is valid only when workloads is left empty.
    Example 1: Collecting container file logs of a workload
      inputDetail:
        containerFile:
          workloads:
            kind: Deployment
            files:
    Example 2: Collecting container file logs of a pod
      inputDetail:
        containerFile:
          workloads: []
          podLabels:
          - includeLabels:
              foo: bar
            namespaces:
            - monitoring
            containers: []
            files:
    spec.inputDetail.hostFile
    Object
    • file:
      • - logPath: log directory, which is an absolute path, for example, /var/log.
      • - filePattern: log file name, which supports wildcard characters, for example, *.log.
      inputDetail:
        type: host_file
        hostFile:
          files:
            logPath: "/var/log"
    spec.inputDetail.processors
    Object
    • type: log type, which is optional. The value can be singleline or multiline. The default value is singleline.
    • multilineRegulation: multi-line regular expression. This parameter is optional and is valid only when type is set to multiline.
        processors:
          type: multiline
    spec.outputDetail.type
    String
    N/A
    spec.outputDetail.LTS
    Object
    The following fields are supported:
    • ltsGroupID: LTS log group ID. The specified ID must exist.
    • ltsStreamID: LTS log stream ID. The specified ID must exist.
      Either ltsStreamID or ltsStreamName must be configured.
    • ltsStreamName: LTS log stream name. If the specified log stream name does not exist, it will be automatically created.
    • ltsStreamCreateParam: log stream creation parameter. This parameter is optional and is valid only when ltsStreamName is specified and an LTS log stream is automatically created.
      • enterpriseProjectID: enterprise project ID of the LTS log group. This parameter is optional and is only available for enterprise accounts with enterprise projects enabled. If this parameter is not specified, the enterprise project ID of the cluster is used.
    Example 1: Specifying an existing log group ID and log stream ID
        LTS:
          ltsGroupID: *****
          ltsStreamID: *****
    Example 2: Specifying an existing log group ID and an existing log stream name
        LTS:
          ltsGroupID: *****
          ltsStreamName: test-stream-name-1
    Example 3: Specifying an existing log group ID and a new log stream name to automatically create a log stream
        LTS:
          ltsGroupID: *****
          ltsStreamName: test-stream-name-2
            enterpriseProjectID: ""
  3. Create a LogConfig.
    kubectl create -f log-config.yaml
    If information similar to the following is displayed, the LogConfig has been created:
    logconfig.logging.openvessel.io/test-log-xx created
  4. Check the created LogConfig.
    kubectl get LogConfig -n kube-system
    If information similar to the following is displayed, the log collection policy has been created.
    NAME                AGE
    test-log-xx         30s
Helpful Links
During log collection, interruptions or data loss may occur. To ensure log integrity and availability, configure collection status monitoring and alarms. For details, see Configuring Metrics and Alarms for Log Collection Status.
