Monitoring Overview
CCE works with AOM to comprehensively monitor clusters. When a node is created, the ICAgent (the DaemonSet named icagent in the kube-system namespace of the cluster) of AOM is installed by default. The ICAgent collects monitoring data of underlying resources and workloads running on the cluster. It also collects monitoring data of custom metrics of the workload.
- Resource metrics
Basic resource monitoring includes CPU, memory, and disk monitoring. For details, see Resource Metrics. You can view these metrics of clusters, nodes, and workloads on the CCE or AOM console.
- Custom metrics
The ICAgent collects custom metrics of applications and uploads them to AOM. For details, see Custom Monitoring.
- NPD monitoring
node-problem-detector (npd for short) is an add-on that monitors and reports a node's health. It can connect to a third-party monitoring platform. It is a daemon running on each node. It collects node problems from different daemons and reports them to the API server. The npd add-on can run as a DaemonSet or a daemon.
CCE enhances npd in version 1.16.0, which now supports checks on node resources, components, and events, as well as fault isolation. For details, see npd.
In addition, you can install the Prometheus add-on in a cluster and use Prometheus to collect and display monitoring data. For details, see Monitoring by Using the prometheus Add-on.
Resource Metrics
On the CCE console, you can view the following metrics.
Metric |
Description |
CPU Allocation Rate |
Indicates the percentage of CPUs allocated to workloads. |
Memory Allocation Rate |
Indicates the percentage of memory allocated to workloads. |
CPU Usage |
Indicates the CPU usage. |
Memory Usage |
Indicates the memory usage. |
Disk Usage |
Indicates the disk usage. |
Down |
Indicates the speed at which data is downloaded to a node. The unit is KB/s. |
Up |
Indicates the speed at which data is uploaded from a node. The unit is KB/s. |
Disk Read Rate |
Indicates the data volume read from a disk per second. The unit is KB/s. |
Disk Write Rate |
Indicates the data volume written to a disk per second. The unit is KB/s. |
On the AOM console, you can view host metrics and container metrics. For details, see Metric Overview.
Viewing Cluster Monitoring Data
Click the cluster name and access the cluster console. In the navigation pane, choose Cluster Information. In the right pane, you can view the CPU and memory usage of all nodes (excluding master nodes) in the cluster in the last hour.
The cluster monitoring page displays the monitoring status of cluster resources, CPU, memory, and disk usage of all nodes in a cluster, and CPU and memory allocation rates.
Explanation of monitoring metrics:
- CPU allocation rate = Sum of CPU quotas requested by pods in the cluster/Sum of CPU quotas that can be allocated of all nodes (excluding master nodes) in the cluster
- Memory allocation rate = Sum of memory quotas requested by pods in the cluster/Sum of memory quotas that can be allocated of all nodes (excluding master nodes) in the cluster
- CPU usage: Average CPU usage of all nodes (excluding master nodes) in a cluster
- Memory usage: Average memory usage of all nodes (excluding master nodes) in a cluster
Allocatable node resources (CPU or memory) = Total amount – Reserved amount – Eviction thresholds. For details, see Formula for Calculating the Reserved Resources of a Node.
CCE provides the status, availability zone (AZ), CPU usage, and memory usage of master nodes.
Viewing Monitoring Data of Worker Nodes
In addition to viewing monitoring data of all nodes, you can also view monitoring data of a single node. Click the cluster name and access the cluster console. Choose Nodes in the navigation pane and click Monitor in the Operation column of the target node.
Monitoring data comes from AOM. You can view the monitoring data of a node, including the CPU, memory, disk, network, and GPU.
Viewing Workload Monitoring Data
You can view monitoring data of a workload on the Monitoring tab page of the workload details page. Click the cluster name and access the cluster console. Choose Workloads in the navigation pane and click Monitor in the Operation column of the target workload.
Monitoring data comes from AOM. You can view the monitoring data of a workload, including the CPU, memory, network, and GPU, on the AOM console.
- Workload CPU usage = Maximum CPU usage in each pod of the workload
- Workload memory usage = Maximum memory usage in each pod of the workload
You can also click View More to go to the AOM console and view monitoring data of the workload.
Viewing Pod Monitoring Data
You can view monitoring data of a pod on the Pods tab page of the workload details page.
- Pod CPU usage = The used CPU cores/The sum of all CPU limits of the pods (If not specified, all node CPU cores are used.)
- Pod memory usage = The used physical memory/The sum of all memory limits of pods (If not specified, all node memory is used.)
Provide feedbackFor any further questions, feel free to contact us through the chatbot.
