Updated on 2026-09-21 GMT+08:00
Overview
Kubernetes logs allow you to locate and rectify faults. This section describes how to manage Kubernetes logs using different methods.
Comparison Between ICAgent and Cloud Native Log Collection
Table 1 Comparison between ICAgent and Cloud Native Log Collection
Collection Tool
ICAgent
Log Storage Location
LTS
AOM 1.0 (not recommended)
LTS
AOM 2.0
Content to Be Collected
- Container stdout logs
- Container file logs
- Node logs
- Kubernetes events
- Node logs
- Kubernetes events
- Kubernetes audit logs
- Control plane component logs
- Add-on logs
Kubernetes events
Advantages and Disadvantages
- Log collection policies and workloads are configured separately. Modifying policies does not affect pod running.
- You can specify a container whose logs are to be collected.
- Docker and containerd are supported. Nodes using containerd require ICAgent v5.12.130 or later.
- Container file log collection supports overlay2, not Device Mapper.
- Each workload needs to be configured separately.
- Log collection policies are coupled with pods. Modifying policies will restart the pod.
- If the node storage driver is Device Mapper, container file logs must be collected from the path where the data disk is attached on the node.
All warning events and some normal events are reported by default. The reported events can be used to configure alarms.
Configuration Method
Create a collection policy in LTS. For details, see Ingesting CCE Application Logs to LTS.
For details, see Reporting Kubernetes Events to AOM.
Monitored Directories
Up to five levels of directories, with up to 1,000 files
Up to three levels of directories by fuzzy match
N/A
Monitored Files
  • Up to 20 logs from a volume mounting directory
  • Up to 1,000 stdout logs in JSON format
Up to 4,096 logs collected based on log policies on each node
N/A
