Updated on 2026-09-21 GMT+08:00
CCE Node Problem Detector
Introduction
The CCE Node Problem Detector add-on (formerly NPD) monitors abnormal events of cluster nodes and can connect to a third-party monitoring platform. It is a daemon running on each node. It collects node issues from different daemons and reports them to the API server. It can run as a DaemonSet workload or separately.
The CCE Node Problem Detector add-on is developed based on the open-source project node-problem-detector. For details, see node-problem-detector.
  • When using CCE Node Problem Detector, do not format or partition node disks.
  • Each CCE Node Problem Detector process occupies 30m CPUs and 100 MiB of memory.
  • If the CCE Node Problem Detector version is 1.18.45 or later, the EulerOS version of the host machine must be 2.5 or later.
Permissions
To monitor kernel logs, the CCE Node Problem Detector add-on needs to read the host /dev/kmsg. Therefore, the privileged containers must be enabled. For details, see privileged.
In addition, CCE mitigates risks according to the least privilege principle. Only the following privileges are available for CCE Node Problem Detector running:
  • cap_dac_read_search: permission to access /run/log/journal.
  • cap_sys_admin: permission to access /dev/kmsg.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. In the right pane, find the CCE Node Problem Detector add-on and click Install.
  3. On the Install Add-on page, configure the specifications as needed.
    You can adjust the number of add-on pods and resource quotas as required. High availability is not possible with a single pod. If an error occurs on the node where the add-on pod runs, the add-on will fail.
  4. Configure the add-on parameters.
    Maximum Number of Isolated Nodes in a Fault: specifies the maximum number of nodes that can be isolated to prevent avalanches in case of a fault occurring on multiple nodes. You can configure this parameter either by percentage or quantity.
  5. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
    Table 1 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, the add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on pods.
    • Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
      If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
    Toleration
    Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
    The add-on applies default tolerations for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints. The toleration time window is 60 seconds.
    For details, see Configuring Tolerance Policies.
  6. Click Install.
Components
Table 2 Add-on components
Component
Resource Type
node-problem-controller
Isolate faults basically based on fault detection results.
Deployment
Detect node faults.
DaemonSet
The node-problem-detector add-on consists of three workloads: cceaddon-npd (for detecting faults on Huawei Cloud EulerOS nodes), euler23-cceaddon-npd (for detecting faults on EulerOS nodes), and ubuntu22-cceaddon-npd (for detecting faults on Ubuntu 22.04 nodes). After the add-on is installed and running properly, if the pod count of these three workloads is displayed as 0/0 in the DaemonSet workload in the kube-system namespace, this is normal.
This add-on uses dynamic affinity scheduling. This indicates only that no node of the corresponding OS type (such as Huawei Cloud EulerOS or Ubuntu 22.04) exists in the current cluster. When nodes of the target OS type are added, the corresponding components automatically start pods. This does not affect the overall running status of the add-on.
CCE Node Problem Detector Check Items
Check items are supported only in the add-on 1.16.0 and later versions.
Check items cover events and statuses.
  • Event-related
    For event-related check items, when a problem occurs, CCE Node Problem Detector reports an event to the API server. The event type can be Normal (normal event) or Warning (abnormal event).
    Table 3 Event-related check items
    Check Item
    Function
    OOMKilling
    Listen to the kernel logs and check whether there are any OOM events. If there is an OOM event, the component will report it.
    Typical scenario: The memory used by the process in the container exceeds the limit, triggering OOM and terminating the process.
    Warning event
    Listening object: /dev/kmsg
    Matching rule: "Killed process \\d+ (.+) total-vm:\\d+kB, anon-rss:\\d+kB, file-rss:\\d+kB.*"
    TaskHung
    Listen to the kernel logs and check whether there are any taskHung events. If there is a taskHung event, the component will report it.
    Typical scenario: Disk I/O suspension causes process suspension.
    Warning event
    Matching rule: "task \\S+:\\w+ blocked for more than \\w+ seconds\\."
    ReadonlyFilesystem
    Listen to the kernel logs and check whether there is a Remount root filesystem read-only error in the system kernel.
    Typical scenario: A user detaches a data disk from a node by mistake on the ECS, and applications continuously write data to the mount point of the data disk. As a result, an I/O error occurs in the kernel and the disk is remounted as a read-only disk.
    If a node's rootfs uses Device Mapper and the data disk is detached from the node, the thin pool will malfunction. This will affect CCE Node Problem Detector, and the add-on will not be able to detect node faults.
    Warning event
    Matching rule: Remounting filesystem read-only
  • Status-related
    For status-related check items, when a problem occurs, CCE Node Problem Detector reports an event to the API server and changes the node status synchronously. This function can be used together with Node-problem-controller fault isolation to isolate nodes.
    Table 4 Checking system components
    Check Item
    Function
    Container network component error
    CNIProblem
    Check the status of the CNI components (container network components).
    None
    Container runtime component error
    CRIProblem
    Check the status of Docker and containerd of the CRI components (container runtime components).
    Check object: Docker or containerd
    Frequent restarts of kubelet
    FrequentKubeletRestart
    Periodically review system logs to check whether kubelet restarts frequently.
    • Default threshold: 4 restarts within 4 minutes
      If kubelet restarts 4 times within 4 minutes, a fault alarm will be generated.
    • Listening object: logs in the /run/log/journal directory
    Ubuntu and Huawei Cloud EulerOS 2.0 do not support these check items due to incompatible log formats.
    Frequent restarts of Docker
    FrequentDockerRestart
    Periodically review system logs to check whether Docker restarts frequently.
    Frequent restarts of containerd
    FrequentContainerdRestart
    Periodically review system logs to check whether containerd restarts frequently.
    kubelet error
    KubeletProblem
    Check the status of kubelet.
    None
    kube-proxy error
    KubeProxyProblem
    Check the status of kube-proxy.
    None
    PodIdentityAgent error
    PodIdentityAgentProblem
    Check the status of PodIdentityAgent. This check item is valid for the add-on 1.19.50 or later.
    If the cluster version does not support pod identities (available in v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, and later versions), the alarm configuration for PodIdentityAgent errors in CCE Node Problem Detector will not take effect.
    PodIdentityAgent on the node is used to obtain temporary credentials for accessing cloud services (such as EVS) based on the configured agency of the add-on or workload. If PodIdentityAgent is abnormal, access to the cloud services will be abnormal. This may affect services of the entire cluster. In this case, you need to evict the workloads on the node.
    Table 5 Checking system metrics
    Check Item
    Function
    Conntrack table full
    ConntrackFullProblem
    Check whether the conntrack table is full.
    • Default threshold: 90%
    • Usage: nf_conntrack_count
    • Maximum value: nf_conntrack_max
    Insufficient disk resources
    DiskProblem
    Check the usage of the system disk and CCE data disks (including the CRI logical disk and kubelet logical disk) on nodes.
    • Source:
      df -h
    Data disks other than system and CCE data disks (including CRI and kubelet logical disks) cannot currently be checked on nodes.
    Insufficient file handles
    FDProblem
    Check if the FD file handles are used up.
    • Usage: the first value in /proc/sys/fs/file-nr
    • Maximum value: the third value in /proc/sys/fs/file-nr
    Insufficient node memory
    MemoryProblem
    Check whether memory is used up.
    • Default threshold: 80%
    • Usage: MemTotal-MemAvailable in /proc/meminfo
    • Maximum value: MemTotal in /proc/meminfo
    Insufficient process resources
    PIDProblem
    Check whether PID process resources are exhausted.
    • Usage: denominator of the fourth value in /proc/loadavg, which indicates the total number of processes that can run
    • Maximum value: smaller value between /proc/sys/kernel/pid_max and /proc/sys/kernel/threads-max.
    Table 6 Checking the storage
    Check Item
    Function
    Disk read-only
    DiskReadonly
    Periodically perform write tests on the system disk and CCE data disks (including the CRI logical disk and kubelet logical disk) on nodes to check the availability of key disks.
    Detection paths:
    • /mnt/paas/kubernetes/kubelet/
    • /var/lib/docker/
    • /var/lib/containerd/
    • /var/paas/sys/log/kubernetes
    The temporary file npd-disk-write-ping is generated in the detection path.
    Other data disks except the system and CCE data disks, including the CRI and kubelet logical disk, on nodes cannot be checked currently.
    emptyDir storage pool error
    EmptyDirVolumeGroupStatusError
    Check whether the ephemeral volume groups on nodes are normal.
    Impact: Pods that depend on the storage pool cannot write data to the temporary volume. The temporary volume is remounted as a read-only file system by the kernel due to an I/O error.
    Typical scenario: When creating a node, a user configures two data disks as an ephemeral volume storage pool. Some data disks are deleted by mistake. As a result, the storage pool becomes abnormal.
    • Check period: 30s
    • Source:
      vgs -o vg_name, vg_attr
    • Principle: Check whether the VG (storage pool) is in the P state. If yes, some PVs (data disks) are lost.
    • Joint scheduling: The scheduler can automatically identify a PV storage pool error and prevent pods that depend on the storage pool from being scheduled to the node.
    • Exceptional scenario: CCE Node Problem Detector cannot detect VG (storage pool) loss caused by the loss of all PVs (data disks). In this case, kubelet automatically isolates the node, detects the loss of VGs (storage pools), and updates the corresponding resources in nodestatus.allocatable to 0. This prevents pods that depend on the storage pool from being scheduled to the node. Damage to a single PV cannot be detected by this check item, but it can be detected by the ReadonlyFilesystem check item.
    LocalPvVolumeGroupStatusError
    Check the PV groups on nodes.
    Impact: Pods that depend on the storage pool cannot write data to the persistent volume. The persistent volume is remounted as a read-only file system by the kernel due to an I/O error.
    Typical scenario: When creating a node, a user configures two data disks as a persistent volume storage pool. Some data disks are deleted by mistake.
    Mount point error
    MountPointProblem
    Check the mount points on nodes.
    Definition: You cannot access a mount point by running the cd command.
    Typical scenario: An NFS file system, such as OBSFS or S3FS, is mounted to a node. If the connection becomes abnormal due to network issues or peer NFS server exceptions, all processes that access the mount point are suspended. For example, during a cluster upgrade, the kubelet is restarted, and all mount points are scanned. If the abnormal mount point is detected, the upgrade fails.
    Alternatively, you can run the following command:
    for dir in `df -h | grep -v "Mounted on" | awk "{print \\$NF}"`;do cd $dir; done && echo "ok"
    Suspended disk I/O
    DiskHung
    Check whether I/O suspension occurs on all nodes' disks, that is, whether I/O read and write operations are not responded.
    Definition of I/O suspension: The system does not respond to disk I/O requests, and some processes are in the D state.
    Typical scenario: Disks cannot respond due to abnormal OS hard disk drivers or severe faults on the underlying network.
    • Check object: all data disks
    • Source:
      /proc/diskstat
      iostat -xmt 1
    • Thresholds: (All following conditions must be met.)
      • Average usage (ioutil) ≥ 0.99
      • Average I/O queue length (avgqu-sz) ≥ 1
      • Average I/O transfer volume ≤ 1
        Average I/O transfer volume = Number of writes completed per second (iops, unit: w/s) + Amount of data written per second (ioth, unit: wMB/s)
      In some OSs, no data changes during I/O suspension. In this case, calculate the CPU I/O time usage (iowait > 0.8).
    Slow disk I/O
    DiskSlow
    Check whether all nodes' disks have slow I/Os, that is, whether I/Os respond slowly.
    Typical scenario: EVS disks have slow I/Os due to network fluctuation.
    • Source:
      /proc/diskstat
      iostat -xmt 1
      Average I/O latency (await) ≥ 5000 ms
    This check item is invalid during I/O suspension. It is because CCE does not respond to any I/O requests and await is not updated.
    Table 7 Other check items
    Check Item
    Function
    Abnormal NTP
    NTPProblem
    Check whether the node clock synchronization service ntpd or chronyd is running properly and whether there is a system time drift.
    Default clock offset threshold: 8000 ms
    Process D error
    ProcessD
    Check whether there is any process in the D state on nodes.
    Default threshold: 10 abnormal processes detected for three consecutive times
    Source:
    • /proc/{PID}/stat
    • Alternately, you can run the ps aux command.
    Exceptional scenario: The ProcessD check item ignores the resident D processes (heartbeat and update) on which the SDI drivers on BMS nodes depend.
    Process Z error
    ProcessZ
    Check whether there is any process in the Z state on nodes.
    RDMA network interface error
    Check the RDMA network interface status.
    CCE Node Problem Detector 1.19.37 and later versions support RDMA network interface error detection and mark the RDMAProblem status on the node. The status is automatically written to the node object. If the add-on is rolled back to an earlier version that does not support this function, CCE Node Problem Detector cannot clear the status, and the marked status is retained.
    Default threshold: a single RDMA network interface error
    Source:
    • Command: rdma link show
    ResolvConf error
    ResolvConfFileProblem
    Check whether the ResolvConf file is lost.
    Check whether the ResolvConf file is normal.
    Definition: No upstream domain name resolution server (nameserver) is included.
    Check object: /etc/resolv.conf
    Existing scheduled event
    ScheduledEvent
    Check whether there is any live migration event on nodes. A live migration event is usually triggered by a hardware fault and is an automatic fault rectification method at the IaaS layer.
    Typical scenario: The host is faulty. For example, the fan is damaged or the disk has bad sectors. As a result, a live migration is triggered for VMs.
    Source:
    • http://169.254.169.254/meta-data/latest/events/scheduled
    This check item is an Alpha feature and is disabled by default.
    The spot price node is being reclaimed.
    SpotPriceNodeReclaimNotification
    Check whether any spot price node is interrupted and reclaimed due to preemption.
    Default check interval: 120 seconds
    Default fault handling policy: Evict some workloads on the nodes.
    The kubelet component has the following default check items, which have bugs or defects. You can fix them by upgrading the cluster or using CCE Node Problem Detector.
    Table 8 Default kubelet check items
    Check Item
    Function
    Insufficient PIDs
    PIDPressure
    Check whether PIDs are sufficient.
    • Interval: 10 seconds
    • Threshold: 90%
    • Defect: In community version 1.23.1 and earlier, this check item becomes invalid when over 65,535 PIDs are used. For details, see issue 107107. In community version 1.24 and earlier, thread-max is not considered in this check item.
    Insufficient memory
    MemoryPressure
    Check whether the allocatable memory for the containers is sufficient.
    • Threshold: Maximum value – 100 MiB
    • Allocatable memory = Total memory on a node – Reserved memory on a node
    • Defect: This check item checks only the allocatable memory of containers and does not check that on the node.
    Insufficient disk space
    DiskPressure
    Check the disk usage and inode usage of the kubelet and Docker disks.
    • Threshold: 90%
Node-problem-controller Fault Isolation
Fault isolation is supported only by CCE Node Problem Detector of 1.16.0 and later.
By default, if multiple nodes become faulty, node-problem-controller (NPC) adds taints to up to 10% of the nodes. You can set npc.maxTaintedNode to increase the threshold.
The open-source NPD provides fault detection but not fault isolation. CCE enhances the NPC based on the open-source NPD. NPC is based on the Kubernetes node controller. For faults reported by NPD, NPC automatically adds taints to the nodes with faults to isolate them.
Table 9 Parameters
Default Value
npc.enable
Whether to enable NPC
This parameter is not supported in 1.18.0 or later versions.
true
npc.maxTaintedNode
The maximum number of nodes that NPC can taint simultaneously when multiple nodes share the same fault. This can minimize the impact.
The value can be in int or percentage format.
10%
Value range:
  • The value is in int format and ranges from 1 to infinity.
  • The value ranges from 1% to 100% as a percentage. The minimum value of this parameter multiplied by the number of cluster nodes is 1.
npc.nodeAffinity
Node affinity of the controller
N/A
Viewing CCE Node Problem Detector Events
Events reported by the CCE Node Problem Detector add-on can be queried on the Nodes tab.
  2. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, locate the row containing the target node, and click View Events in the Operation column.
    Figure 1 Viewing node events
Configuring CCE Node Problem Detector Metric Alarms
For CCE Node Problem Detector status-related check items, you can configure alarm rules to notify you of exceptions by SMS message or email. For details about how to create a custom alarm rule, see Configuring Alarms in Alarm Center.
To use CCE Node Problem Detector check items to configure alarm rules, you need to install the Cloud Native Cluster Monitoring add-on in the cluster and interconnect the add-on with an AOM instance.
Collecting Prometheus Metrics
The DaemonSet pods of CCE Node Problem Detector expose Prometheus metrics over port 19901. By default, the add-on pods are added with the annotation metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"prometheus","path":"/metrics","port":"19901","names":""}]'. You can build a Prometheus collector to identify and obtain CCE Node Problem Detector metrics from http://{{CCE-Node-Problem-Detector-pod-IP-address}}:{{CCE-Node-Problem-Detector-pod-port}}/metrics.
If the CCE Node Problem Detector add-on version is earlier than 1.16.5, the exposed port of Prometheus metrics is 20257.
The metric data includes problem_counter and problem_gauge, as shown below.
# HELP problem_counter Number of times a specific type of problem has occurred.
# TYPE problem_counter counter
problem_counter{reason="DockerHung"} 0
problem_counter{reason="DockerStart"} 0
problem_counter{reason="EmptyDirVolumeGroupStatusError"} 0
# HELP problem_gauge Whether a specific type of problem is affecting the node or not.
# TYPE problem_gauge gauge
problem_gauge{reason="CNIIsDown",type="CNIProblem"} 0
problem_gauge{reason="CNIIsUp",type="CNIProblem"} 0
problem_gauge{reason="CRIIsDown",type="CRIProblem"} 0
problem_gauge{reason="CRIIsUp",type="CRIProblem"} 0
Helpful Links
After installing the CCE Node Problem Detector add-on, you can customize the node fault detection policies, such as filtering node detection scope or adjusting the fault threshold. For details, see Configuring Node Fault Detection Policies.
Release History
Table 10 CCE Node Problem Detector updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.19.63
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
0.8.10
1.19.58
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
0.8.10
1.19.56
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Fixed some issues.
0.8.10
1.19.54
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
0.8.10
1.19.52
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
0.8.10
1.19.39
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
0.8.10
1.19.37
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported RDMA network interface status detection.
0.8.10
1.19.33
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
0.8.10
1.19.29
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
0.8.10
1.19.25
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
0.8.10
1.19.20
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
0.8.10
1.19.16
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
0.8.10
1.19.11
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Fixed some issues.
0.8.10
1.19.8
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
  • Compatible with a single system disk.
  • Supported anti-affinity scheduling of add-on pods on nodes in different AZs.
  • Certain taints can be added to a spot price ECS before its release for the node to evict its pods.
  • Synchronized time zones used by the add-on and the nodes.
  • Supported CCE clusters v1.30.
0.8.10
1.19.1
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Fixed some issues.
0.8.10
1.19.0
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
0.8.10
1.18.48
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
0.8.10
1.18.46
v1.21
v1.23
v1.25
v1.27
v1.28
Supported CCE clusters v1.28.
0.8.10
1.18.22
v1.19
v1.21
v1.23
v1.25
v1.27
None
0.8.10
1.18.14
v1.19
v1.21
v1.23
v1.25
0.8.10
1.18.10
v1.19
v1.21
v1.23
v1.25
  • Optimized the configuration page.
  • Added threshold configuration to the DiskSlow check item.
  • Added threshold configuration to the NTPProblem check item.
  • Interruption of spot price ECSs can be detected, which allows the pods on these nodes to be evicted before the interruption.
0.8.10
1.17.4
v1.17
v1.19
v1.21
v1.23
v1.25
Optimized DiskHung check item.
0.8.10
1.17.3
v1.17
v1.19
v1.21
v1.23
v1.25
  • The maximum number of nodes that can be tainted by NPC can be configured as a percentage.
  • Added the ProcessZ check item.
  • Added the time deviation detection to the NTPProblem check item.
  • Fixed the process that is consistently in a D state on BMS nodes.
0.8.10
1.17.2
v1.17
v1.19
v1.21
v1.23
v1.25
  • Added the DiskHung check item to disk I/O suspension.
  • Added the DiskSlow check item to disk I/O suspension.
  • Added the ProcessD check item.
  • Added MountPointProblem to check the health of mount points.
  • To avoid conflicts with the Service ports, the default health check listening port is changed to 19900, and the default Prometheus metric exposure port is changed to 19901.
  • Clusters 1.25 are supported.
0.8.10
1.16.4
v1.17
v1.19
v1.21
v1.23
  • Added the beta check item ScheduledEvent to detect cold and live VM migration events caused by host machine exceptions using the metadata API. This check item is disabled by default.
0.8.10
1.16.3
v1.17
v1.19
v1.21
v1.23
Added the function of checking the ResolvConf configuration file.
0.8.10
1.16.1
v1.17
v1.19
v1.21
v1.23
  • Added node-problem-controller for basic fault isolation.
  • Added the PID, FD, disk, memory, temporary volume pool, and PV pool check items.
0.8.10
1.15.0
v1.17
v1.19
v1.21
v1.23
  • Strengthened check items comprehensively in order to prevent false positives.
  • Supported kernel checks and reporting of OOMKilled and TaskHung events.
0.8.10
1.14.11
v1.17
v1.19
v1.21
Supported CCE clusters v1.21.
0.7.1
1.14.5
v1.17
v1.19
Fixed the issue where monitoring metrics cannot be obtained.
0.7.1
1.14.4
v1.17
v1.19
  • Supported containerd nodes.
0.7.1
1.14.2
v1.17
v1.19
  • Supported CCE clusters v1.19.
  • Supported Ubuntu OS and secure containers.
0.7.1
1.13.8
v1.15.11
v1.17
  • Fixed the CNI health check issue in a container tunnel network.
  • Adjusted resource quotas.
0.7.1
1.13.6
v1.15.11
v1.17
Fixed the issue where zombie processes are not reclaimed.
0.7.1
1.13.5
v1.15.11
v1.17
Added taints and tolerations.
0.7.1
1.13.2
v1.15.11
v1.17
Added resource limits and enhanced the detection capability of the CNI add-on.
0.7.1
